Ash load in DPF
Not sure what the exact calc for ash loading is, but it involves both number of regens and mileage. What's the mileage on each car/engine? In any case, if there are no signs of restriction in the exhaust (power loss, increased fuel consumption, regen completion issues etc.), the large amount of "accumulated ash" is just imaginary, there is far less ash in reality, it is just a number in the ECU which by the way can be adapted to a smaller value with VCDS, at least on earlier engines like CAYC. I honestly think that ash number was just put there to cover backside in case of clogged DPFs over the car's life, and also to force replacing DPFs at most at a certain mileage. The correct way to evaluate amount of ash would be to measure and average pressure loss after completion of each regen, but my guess is that given varying temperatures and gas flow, the exhaust sensors used for it are either not accurate or not reliable enough, especially after many years of use / high mileage.
Constant app updates
We don't use our Karoq much between trips to the continent. Last time we went in June/July we got the update message virtually every day. There ws never a message to say updated complete. The only odd thing I found was that at some time the settings for the cruise control were changed, causing me some concern, but that was soon corrected. We have just returned from another trip when again we get the message virtually every day, someimes more than once a day. Always accepted but nothing else. Having reset the headlight aim in the Channel Tunnel train, and gone back into settings to ensure the change was actually set, when I came home and tried to set back for UK, it was already on left side running. Whether the 'updates'had reset something in both cases, who knows. We had l Iittle need of headlights apart from tunnels, but I did do two or three ~10 mile trips in the dark and nobody flashed me! I would like to ask my agent but while away I received an email saying that, as of 30th September, ie Wednesday, they are no longer Skoda agents and service is being transferred to a local VW agent. Great! So what to do next? Had an MOT booked but doesn't look like that will be happening!
Routemaster1461 started following Constant app updates
GroovyHedgehog9 joined the community
- Fabia MK2 RS Owner Australia
The Games Manufacturers Play
@Evolution13 that's a spammer, see link inserted into quoted text. Reported.
^^^ 4 years later.
Evolution13 started following The Games Manufacturers Play
samirajl joined the community
Door loom fix wiring
Bumping old topic but this video extremely useful in having an idea on best way to get door apart and give maximum length of loom to work with. Not a job for the faint of heart or unsure with electrical.
BloodWorm started following Door loom fix wiring
Moving over
Hi, I've been on Briskoda for just over 4 years but on the Superb forum. Tomorrow I am getting my 2026 Karoq 1.5 TSI SE L Edition delivered. 3 Months old ex demo, so will be on this forum now a lot, to learn about it, and perhaps contribute a bit.
Changing Cars
Best of luck with it!
Changing Cars
Well, been on here for over 4 years now, contributed some, and learnt a lot more. But time to say goodbye. But not to Briskoda, just this forum. I am getting a 2026 Skoda Karoq delivered tomorrow, so will be migrating over to that forum. Thanks for all advice given here, it's helped a lot.
Ash load in DPF
Could this 60g be a natural occurrence? The worst-case scenario is that oil gets into the DPF. If the 60 g is a value calculated from the regenerations, it could not have accumulated from the normal regeneration cycles. It is currently regenerating every 350 km.
- Superb 3V3 tailgate struts - Beware Autodoc
01276 ABS Pump
Why? If valves are not stuck all four ways it is easy. I did not do laptop magic. Just gravity. Blocking pedal in down position is important. I would check if cable allows to connect another pump or look for extension on ali. Maybe brushes in motor are dirty, worn. Probabbly circuit sensing too much resistance or intermittent power supply.
kokosal started following 01276 ABS Pump
Amundsen MIB2 Firmware Update
I have the Solution and dont need help
Ash load in DPF
DPF ash load primarily depends on mileage and the number of regens. While it is possible that on EU6 engines it is measured / derived from DPF pressure loss after regen (doubt it), at least on our 2012 Roomster's EU5 1.6TDI CAYC 105bhp engine the ash load is simply calculated and increased based on mileage and number of regens, no measurements involved. If you experience frequent regens, you will find ash load going up quickly even though there is no change in pressure readings around DPF, i.e. no actual ash.
- Yesterday
ThreeSpeedScottie started following Fabia MK2 RS Owner Australia
ThreeSpeedScottie joined the community
@mpg_cloud @Cairus If you need to update to version 0480 and activate CarPlay, send me a message.
Configuration function missing
I have the older Mk4 Octavia, so unfortunately I can't help you. But I wanted to add that disappearing functions from the infotainment menu is a problem which is suffered in the Mk4 too. Skoda really need to invest in some decent software techs
scotthugh3s started following Configuration function missing
I’ve had a 2026 Octavia Sportline (1.5 TSI) since August. The configuration option on the Virtual Cockpit display—used to add or remove data—has disappeared. I’ve reset the infotainment system, but I still haven't been able to get that function back. I’m attaching a photo showing my hardware and software details. Can anyone help me?
Chusan started following Configuration function missing
Upgrade Carplay on my Superb 3T
Is this the kind of upgrade that you can tutorialise?
BloodWorm started following Upgrade Carplay on my Superb 3T
red-ireland joined the community
Skoda Swing Firmware Update - MU 8755
PM sent
Upgrading Infotainment System To Get Android Auto
I sent you PM
infotainment system upgrade
Indeed, glove box unit must be replaced. I will send you PM.
I can do it for you, as I can see you are from Czech Republic and I am in Poland so shipping costs will not kill it... @CrazyWolf @Rocketeer125 check your PMs for MST2_EU_SK_ZR_P0480T download link
lucky987 joined the community
Notta762 joined the community
How-to Guide to Upgrade MIB2 to MIB2.5
I wrote a guide for connecting by UART should anyone need it in future.
