Maarten71 joined the community
Spyders over Brembo 4pots?
From memory, think is was a minimum of 5mm
Egr problem wiring ?
What year is the car and which engine type does it have?
GPS ISSUE: Software 330 vs 332?
My car is in the garage and its a very big garage connecting several building, and when I get out, it gets confused and the gps/navi is wrong. Basically it can even go into the wrong direction. Happened again today, drove 30min, parked car for 5h and on the journey home, everything worked perfectly.
Jcbbuk joined the community
Can’t complain about this mpg.
I should also add that I have previously ‘validated’ the ‘Since refuelling MPG’ with brim-to-brim fuelling and the figures were within 0.5 miles per gallon, so I that’s good enough for me.
Fitted a new egr valve , plug looked ok ,pins ok , still have egr code po 40300 and showing no live data , I need to check pins next but is there anywhere that the wiring rubs or breaks ect
woowoo started following Egr problem wiring ?
Skoda Yéti (2015 Manufacture Date) Infotainment Latest Firmware
MIB-Helper indicates that the latest official Firmware version is P0253T but there’s P0353T available (and I can see a ver: P0359T listed, too). My current version is P0241T. Is it safe to use the P0359T or should I just stick with P253T? Thx
woowoo joined the community
jeffgover joined the community
Enyaq Roof Rack - Inserting the rubber strip.
I'd have put the strip in warm soapy water, make it more flexible, not saying it would work but that's what I would have tried.
Cost of Mamiq service - year 2
If you intend to use Skoda main dealer 2 services have plans. Monthly payments with zero interest . They also have an all in plan form year three https://customer.vwfs.co.uk/service-plans/skoda.html?traci_c=UK|SI|GA|PM|SKODA:DM-P:&traci_s=SI:SKODA:SEA:Google:PerformanceMaxAd:2024-12:&traci_ee=22041507480::::::&traci_t=:::&s_kwcid=AL!10901!3!!!!x!!&gad_source=1&gad_campaignid=22051408243&gclid=CjwKCAjwyuDTBhB-EiwANCQhLCkFGobbhgE7ZfHM_hd8s4Q2bcibzWXgUH6bN2ly46HTm2MZD08GDBoCDL8QAvD_BwE
Stonekeeper started following Cost of Mamiq service - year 2
Timing of transition/implementation of the EU driver assist regs for different Skoda models
Kiss point is point in the clutch movement where the clutch faces touch. Used to determine clutch pressures/ release points when changing gear etc. might be that? Adaptation of the dsg includes configuring kiss points among other things.
I've just heard the use of the word KISS in relation to VAG automatic transmission.( Mechanitronic ?) any one familiar with it? Possibly to do with linking the transmission to the engine?
Can anyone please advise what main dealers charge for the second service on a 2 year old car, low mileage. I live in South Yorkshire
skoda998 started following Cost of Mamiq service - year 2
Visually etc. My car of the day -today
I popped to a classic car meet today and saw a couple of Ford Taunus's (Taunusi?) "Knudsens". We had them as the MkIII Cortina. Dad skipped the MkIII and went from a MkII to a MkIV but the neighbours had a MkIII in orange. Then I googled Taunus GXL and this video was the top hit. The very same car (the one with the Hamburg plates)
- Dropping a wheel size - 17" to 16"
Graeme started following Dropping a wheel size - 17" to 16"
MarvyD joined the community
Griff_The_Biff started following Audio, Electronics and Security
Is there something wrong with my airbag?
Hmm I guess it must have been an option. Rear heated seats and 3 zone climate was only standard on L&K models I think.
Sadey started following For Sale - 2000 Skoda Felicia GLXI 1.6 - Black - Low Genuine Mileage
For Sale - 2000 Skoda Felicia GLXI 1.6 - Black - Low Genuine Mileage I am selling my much loved black Skoda Felicia GLXi 1.6, year of manufacture 2000. MOT until 5th January 2027 Current Mileage : 67, 996 - Genuine Mileage I've owned and looked after this car carefully and it has had relatively light use. I've been lucky enough to be able to walk to work, which is one of the reasons the mileage has remained so low over the years. For its age, the car is tidy and has been well cared for. There is some rust around the wheel arches and a scratch across one side and signs of wear an tear which I've taken into account on the asking price and am completely up front about this. Its been a much loved and reliable little car and Im only selling because I'm buying a camper van for my next adventure. £1,750 ONO Happy to answer any questions or provide further photographs/details for anyone interested.
Graeme joined the community
Exterior bulb warning light after car wash (2011 Octavia) - Wing mirror LED?
Thanks solved, Halfords 2 mins away so just replaced them and light has gone. Appreciated.
Kodiaq Seven seater and space saver spare wheel ?
There are two "foam and jack kits" (which includes everything except for the actual spare saver spare wheel, for the Kodiaq MK2. One of the "foam and jack kits" is for the Kodiaq MK2 5-seater and the other is for the Kodiaq MK2 7-seater. Neither will fit a hybrid version where the battery is in the spare wheel well. Both kits are only for a 145/85R18 4Jx18 ET28 space saver spare wheel. There is room for a space saver spare wheel with the Kodiaq MK2 mild-hybrid (NOT plug-in), because the batteries on these are tiny (probably less than 1kWh capacity) and are fitted under the front passenger seat rather than in the spare wheel well. Foam and jack kit (Kodiaq MK2 5-seater) 57H093860C https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola-18/p/57H093860C Foam and jack kit (Kodiaq MK2 7-seater) 57H093860D https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola-18/p/57H093860D Space saver spare wheel 145/85R18 4Jx18 ET28 (Kodiaq MK2) 57H601011G https://eshop.skoda-auto.cz/cs_CZ/rezervni-kolo-18---dojezdove/p/57H601011G
Carlston started following Kodiaq Seven seater and space saver spare wheel ?
Brake pads installed wrong in the past?
They are sided in that the one with crescent cut out go behind the disc and the one without goes in front of the disc.
Are the brake pads sided or are they all the same? Thanks. AG Falco
AGFalco started following Brake pads installed wrong in the past?
My 2024 1.5TSi SEL DSG Karoq averages 50+ when cruising on a not busy motorway at an indicated 70-75. My Leon FR 1.4TSi FR DSG would show 53-54. I suspect that's the affect of the Karoq's larger frontal area. Normal driving around the Cotswolds drops the Karoq to anywhere between 42 to 45. The Leon would be 45 - 50. The extra weight of the Karoq is against it when accelerating or climbing hills. It is noticeable that the Karoq is often 1 gear lower when climbing particular hills than the Leon would have been at the same speed. The 2 engines seem to have identical power & torque figures & curves although the 1.4 was smoother & quieter. Perhaps 50k miles against 10k may explain some of that.
VRS Mk1 crankcase ventilation system
Adding a Oil Catch Can is a great idea, it helps reduce oily air coating valves, piping, turbo impeller vanes and the intercooler. When I fitted mine in 2010 there were not many to choose from I opted for a Saikou Michi one from the USA. See my engine pic' its located bottom right, I made up a small bracket to mount it. 19mm diameter lined silicone hoses are the size recommended for the 1.8 turbo. Another useful mod is to replace the stainless charge pipe that dives down behind the engine on the drivers side. It has a push on connection & o ring retained with a c clip. My one kept leaking and coming off so I replaced the stainless pipe with 06A 145 731D , (there is one on e-bay). The lower end just pushes into a new silicone hose (Creation Motorsport). Dean quoted Bowders 1 post, he was a trail blazer for VRS mods for us all and posted many good "how to " posts and is a good source of reliable info. Good Luck Peter
Changing the front badge and rear lettering on 2020 Fabia colours edition
Thanks Everyone!! Great help, ordered everything and its all here..cheers again
- What does this symbol mean
MintyPanda started following What does this symbol mean
From memory I read there may be two w3w tail light bulbs in each cluster on rear think its the MK2/1z. Not entirely sure but worth a check. Perhaps one has blown. Alasdair
Griff_The_Biff joined the community
Thanks both, they were pretty corroded, once over with some contact cleaner, no change. (But they not looking great anyway so might change alongside the indicator and see what happens.
