the truth about electric cars
@lol-lol There has been for decades now, makers like Ford taking cars made by others and badging them. This is nothing new; it is not an EV thing. In many cases the cars are indeed a joint venture between 2 or more makers, where each will make various parts and then 1 will be nominated to do the final assembly. As for the owner taking their car to a firm like Cleevely EV, it is something that only a handful of car enthusiasts would think about, as most owners will stick with the brand's dealer network, especially while it is under warranty. Ford Capri is really a VW ID4 under the skin; hell, loads of people are unaware that Skoda, VW, Audi, Bentley, Bugatti, Seat, Cupra, Lamborghini, MAN, etc. are even in the same group and share many common parts and many cars beneath the skin have the same platform, running gear etc. Anyone following Mat Armstrong on his YouTube channel should be aware of how other brands take parts from others, stick their logos on them and sell them at massive markups, many times the original price.
Karoq gearbox doesn't creep?
Many thanks for taking the trouble to respond, folks. Very much appreciated. I now realise what seems to be happening as I did have the autohold activated. Best wishes
helloweenek joined the community
P176F00 "Clutch 2 closes unintentionally", returns after clearing. Sensor or mechatronic?
Hi all — car's currently with a Skoda independent specialist here in Bristol, and I wanted to sanity-check with the forum while they dig in. Car: Octavia RS 2.0 TSI Combi (245 PS), MY2022, 7-speed wet DSG (DQ381 / 0GC), 65000 miles. Service history: full Skoda / independent — DSG oil + filter service not done. What's happened: got the alert “ gearbox in emergency mode. No reverse possible”. Breakdown technician’s scan showed two codes: P27F500 (selector lever lock, Park position) and P176F00 (Clutch 2 closes unintentionally). P176F00 has a VAG TSB: if it's sporadic with a frequency counter of 2 or less, you clear and test drive; if it returns or is static, it's guided fault finding. Cleared the codes, drove ~5 min, and P176F00 came straight back with the counter now above 2. So it's persistent, not a one-off. Questions: Anyone had P176F00 on a DQ381 — root cause and fix? Clutch pressure sensor set, mechatronic, or clutch? Did a DSG oil + filter service ever clear it once the code was logged, or wishful thinking? Anyone managed to get Skoda to cover a DQ381 mechatronic as a goodwill job at ~4 years old? Thanks.
Amundsen MIB2 update
Sorry, I have no idea myself but maybe someone will have an answer.
Thought I saw this one a few weeks ago. VW, who make the Explorer for Ford, have a wholly owned subsidiary called PowerCo I gather, who puts together the power packs for the VAG Group and I can imagine the £33K price of the pack, including all its cooling elements, presumable over £10k for all the work to fit, sounds pricey, gets us to the £45k. So Ford would need to buy the pack from Powerco / VW and each make their margin including Ford hence the silly price. I would suppose one would actually go to a firm like Cleevely EV, or scrap the vehilce rather than go ahead with this ridiculous quote. Ford are getting themselves in a bad place for cars like the Explorer which is a VW production line vehicle as I understand it. What is interesting is that it is looking like Ford is set to do the same for the new Fiesta which is going to be a Renault 5 in drag, we already have the Nissan Micra doing this. Ford said many years ago that it wanted to concentrate on design etc and leave manufacturing to Toll car makers. Road to ruin I would have thought. Mr Farley brutally honest. Import tariffs can delay the apparent inevitable which is what US is doing. Dont know the cells within the Explorer ID* but probably Chinese or Korean. West slow to get on EV component production and hence the silly prices of EVs and their components..... https://www.cleevelyev.co.uk/
- Fabia 2012 timing belt Is it a forever belt ?
Robbys started following Fabia 2012 timing belt Is it a forever belt ?
- Karoq Instrument Panel & Servicing Generally
On the Karoq, that centre display is the MFD/trip computer, and the options are normally changed using the controls on the steering wheel or the buttons/rocker on the wiper stalk, depending on the exact wheel setup. The garage may simply have changed the display view while resetting the service information. For the brake fluid, I’d be a little more cautious about relying purely on a fluid test. Brake fluid absorbs moisture over time, so age is relevant even if the level and appearance look fine. If the manufacturer's schedule calls for replacement at that interval, I’d probably follow it rather than treating it like a “top-up” item. The pad rattle is a different issue. If there’s plenty of friction material left and braking is normal, it may simply be pad-to-carrier movement, but I’d get the garage to identify exactly where the movement is before replacing anything. A good quality pad with the correct hardware can make a noticeable difference.KendrickCD111 started following Karoq Instrument Panel & Servicing GenerallyRobbys joined the community- Noisy car ...
When was it last serviced? Have the Spark Plugs been changed at around 40,000 miles or since? Has the Air Filter been changed or looked at? Have the brakes been serviced, or inspected and has the brake fluid been changed? Is the AC used and has that been serviced?Evolution13 started following Noisy car ...KendrickCD111 joined the community- Today
- Amundsen MIB2 Firmware Update
it refuses to take 0369 in emergency- Amundsen MIB2 Firmware Update
Why 368?- Amundsen MIB2 update
Hello i have a 2015 mk3 lauren and klement octavia estate fitted with a columbus unit i have the ece2024 maps installed, i downloaded the latest map HIGH 12 F P350 EU 202345 from a link on here, when i installed the map it only lets me see the route from a distance of 25 miles and i cannot zoom in, any ideas???chrisreynolds1 started following Amundsen MIB2 updateVince69 joined the community- Faulty Infotainment System
My dad has a 2015 Octavia estate. His infotainment system has developed a fault. It won’t connect to his (or anyone’s) phone via Bluetooth. If we do either a manual delete of all paired phones or a hard reset all the old settings reappear the next to the system is booted up. Any ideas if this is fixable or a terminal problem? Also is there a cheap way of allowing Apple CarPlay etc… to run without visiting a main dealer (should it be repairable). ThanksJRWGTFC started following Faulty Infotainment System- Octavia Elegance 1.4 TSI - Very interested - Advice needed
JRWGTFC joined the community- Amundsen MIB2 Firmware Update
i have 369 need earlier one 0368 is corrupted on mib solutionMikeTheThinker started following Noisy car ...- Noisy car ...
yeah, not a helpful title. Its a 1.5 petrol Scala, with about 55,000 miles on the clock I've been aware of a drone from the engine/drivetrain for some while and now even the missus is mentioning it, and she's quite deaf ;-) Where to start with tying the problem down ? What questions should I be asking myself ? Can anybody recommend any garages in the NW (Wigan/Bolton) likely to be able to look at this (without first saying we'll want at least £120 for an hours diagnostics, and thats not an actual dealership)- PCV valve/assembly
Thanks for the replies. I'm used to the cars I've had in the past where removing the oil filler cap with engine running has produced the opposite to the Kamiq where crankcase pressure is released through the filler hole...Now i know it's normal.Thanks again- Blues radio replacement, plug and play?
OK. Thank you for the information. So easier and propably cheaper would be a standard din1 radio. Are these plug and play, or do I need to buy extra cables or adapters?- Blues radio replacement, plug and play?
Every OEM radio will require coding and component protection removal.- Buying a 2004 Superb ?
I've had mine over 10 years, serviced every year and I'd drive to Scotland tomorrow without hesitation. I'd get the cambelt done if you're going to buy it. Price no idea, it's not really special except to those who know how good that engine is. Mines on 240,000 and still pulls like a train.soulmover started following Buying a 2004 Superb ?- Misfire clears up after garage inspection and then comes back with different lights weeks later minus idle misfire!
My Blues radio broke. It powers on but no sound. If I turn the volume knob display shows volume level 7, but it won’t change. It also recognizes my phone if I plug it in the USB-port, but no sound still. Resetting a few times used to fix this volume problem occasionally, but now it doesn’t help anymore. Can I buy a second hand Blues unit and just swap it or does it need some coding or something? Or can I buy a Din1 adapter and just connect a standard Din1 radio? The car has no steering wheel button or reverse cameras or sensors so a basic radio unit would have all features needed.BbCc joined the community- Rear propshaft coupling
They usually start to go at around 70k miles from my experience and the tell tale sign seems to be a heavy vibration from the rear under load at about 2300rpm, heard more in higher gears.- Skoda Octavia mk3 fl cornering light coding
Picking up on this prior thread - My April 2020 (last of the MkIII Facelift) Scout, with full LED package, has cornering lights on by default. I sometimes would like the cornering lights to come on earlier in a turn; as configured from the factory, the cornering lights don't seem to turn on unless the steering wheel is rotated quite far from centre. In the screenshots above, I notice fields: Lenkradwinkel, offset (Steering wheel angle, offset): 0.3° Unterer Lenkradwinkel (Lower steering wheel angle) 40° Oberer Lenkradwinkel (Upper steering wheel angle) 65° Do these control when corner lights turn on and off? Are they configurable? Any warnings about setting them too low/high? thank you,- Rear propshaft coupling
Hi, What kind of play should be checked? Is it rotational or axial? How many km on the clock BTW? Thanks! 😉
