Skoda Scala 1.0 TSI 2023 - Stiff Gear Change
Hi everyone. My son bought a 2023 Skoda Scala 1.0 TST Monte Carlo back in April. It's a beautifiul car. Early in the summer (on one of the days it was 35C) he said that it wouldn't go into gear after having it parked all day, although after a bit of trying it was fine. This didn't happen again until last month when the same issue occured. Over the last few weeks he says it's been happening more often, although it is still only intermittent. As there was no record of the car having it's brake fluid changed at 3 years he had this done at our local garage yesterday, along with the clutch fluid as we know it's shared. The garage said the fluid was low, and now that's all done. He was hopeful that that was the problem sorted but it happened again this afternoon. This time I was able to get into the car and feel it for myself. The gear change felt stiff and required more of a push than usual to get it into gear. Lifting and then reengaging the clutch resolves the issue. A quick search on the web suggests lubricating the linkages in the engine bay with lithium grease - that looks easily doable and worth a go, but I'd appreciate any other thoughts or suggestions. Car has 23,000 miles, full service history - and is no longer under warranty from the garage we bought it from (of course!) Thanks in advance for any advice.
dunder101 started following Skoda Scala 1.0 TSI 2023 - Stiff Gear Change
Skoda Superb Alloy Wheels 18 inch from 2013 Superb Elegance Mk2. Set of four. Plus steel spare.
Hello, I am interested. Please send me your number, and I will get in touch.
kokomm joined the community
- Tim
Converting the Superb 3 Pre FL to the Superb 3 FL Matrix Light any experience?
Here is the breakdown for the facelift LED fog light retrofit on Skoda Superb MK3. On the old pre-facelift fog lights, Pin 1 was the main power wire with a 1.5 mm² cross-section, and the other pin was ground. On the new facelift LED fog lights, the pin layout is different: Pin 1 is for the 0.5 mm² PWM signal wire, and Pin 3 is for the 1.0 mm² main power wire. Because of this, you must swap and re-route the pins during installation. Specifically, you take the original 1.5 mm² power wire from the old fog light harness and move it from Pin 1 to Pin 3 on the new connector. Then, you take the new 0.5 mm² signal wire coming from the headlight and connect it to Pin 1 on the new fog light connector. Because you are splitting the functions between two different pins and wires, you must also change the channel assignments in the BCM (09 Central Electrics) module accordingly. In the BCM adaptations, set Lampentyp for the Signal Channel (Pin 1, 0.5 mm² wire) to 6 - LED-Lichtmodul to deliver the low-current PWM control signal. For the Power Channel (Pin 3, 1.0 mm² wire on channel 55L), set Lampentyp to 32 - Allgemeine LED bis 12W or 36 - LED Kleinleistung to provide a constant 12V power supply without pulse modulation and ensure correct diagnostic fault monitoring.
Wheel spacers?
Yup, also probably need to use my glasses more than I do. Now to see if 10/11/12/13 is going to be the correct and if to do staggered
Wheel spacers?
It can happen ... sometimes I misread him too. Sometimes he misreads himself also 😁 Me to myself ... all the time! 🙃🤪
Suspension upgrade installed
Yes i agree about 034 stuff, very good quality. How does the ride feels with your set up? I'm quite happy with mine atm. Still want to fit Eibach springs but that will be after Christmas Yes mine went in dry 🪒💪🏻
Fuel Leak!
I got a similar reply from them when I asked the question, though they did say that they had talked to VW Group about this and were assured that the driver will get adequate warning indication and so so stop quickly. They did add, back then, that as it currently did not trigger any action going by their prescribed guidelines for taking action, they would still be keeping an eye on how often this was occurring - and considering any change on possible future action based on that. So I'll always advice that owners report to them every time this happens. Edit:- I'd hope that there will be a tipping point where/when DVSA do demand action from VW Group before someone gets fried.
Tim joined the community
Cedwing started following Constant creaking / rattling from the doors of my Kodiaq Mk2
Wheel spacers?
Well I said on the wish list. Doesn’t mean I’ll actually do it…
It’s already spitting with rain haha
Wheel spacers?
I am sure you said no more mods, somewhere on here, hahaha Yes will do fella, wanting to get my wheels refurbished too but need a spare set whilst they are getting done
Ash load in DPF
This is exactly what I am trying to say, the "accumulated ash mass" is just VW's / ECU's theory. In practice, actual DPF condition is OK until clogged enough to cause backpressure and related loss of performance and problems with completing regen or frequent regens. Can be well before 80g, can also be way after 80g. I stress that this is certainly the case for EU5 engines, perhaps EU6 ones have better pressure monitoring, but I doubt it. The only way to be sure would be to swap the DPF without resetting ECU, drive for a while and look at the accumulated ash mass reading sometime afterwards. On EU5 TDI, for sure the ECU would not notice new DPF and just keep increasing accumulated ash value in line with mileage / number of regens. I suspect it is the same for EU6 TDIs, but not 100% sure.
Wheel spacers?
Will be good to see some before and after pics. It’s something that might find its way onto my wish list.
Binx1310 started following Wheel spacers?
Got mine given a quick once over yesterday too. Makes it look so much better. Won’t last long I think!
2012 alarm issue
Should be behind a panel at end of dash drivers side between door and dash. Access when door is opened. There is a panel that clips in place. Careful removing so not to damage spring clips. https://www.startmycar.com/gb/skoda/octavia/info/fusebox/2012#anchorfusebox3 The above link I think is your car. Fuse 35 Alasdair
Wheel spacers?
This is what I had thought but must of misread what Travs had put in their reply Waiting till the service is done this week and then will order some spacers and bolts
Skoda superb sportive estate 2023 suspension to soft
I found this, doing 70mph and the rear got very lose and a little worried when the car went light. Along with how the A12 is currently with very bumpy in sections I am glad I have done new springs, tops mounts with B6’s all round, although it seemed to take a long time to bed in with a 4 wheel alignment it’s now on the money and super comfortable along with good control even on those parts of the A12. Only wish the car sat lower, about 15mm but it’s not sport or DCC suspension
tombee started following Skoda superb sportive estate 2023 suspension to soft
Saying hello again for the first time in many years
Welcome back, Manny. 🙂
DGW started following Saying hello again for the first time in many years
After months, last time was 25th of June before the car went in to Skoda for warranty work. I washed the car today, been putting it off but after France/Belgium, Devon/Cornwall in the summer and then some other trips the car was filthy, more the wheels than anything Wash it twice due to only buckets!!
- 2012 alarm issue
the truth about electric cars
The stats support it, more piwet and mire torque. My comoany Ceva was seeing several minutes quicker runs by the EV trucks running up from the Spanish ports that connect with Morocco up to Madrid and onwards. Ceva use Winrose EV truck for such runs.
2012 alarm issue
When the alarm backup battery fails it can leak and cause damage to circuit boards which can trigger alarm randomly. On a temp measure to silence it you could remove fuse for backup battery. It would stop the siren eventually once it goes flat. Indicators will probably still flash but at least it wont annoy neighbours. From memory its fuse 35 either 5amp or 20amp
Exactly, but those speed limits where put in place before EVs were as common as they are now.
What actually makes you think that electric trucks will out perform ICE ones in terms of towing etc? That certainly has not been demonstrated by the electric vans, or indeed cars towing caravans has it? Manuefacturers hyped up claims are never ever matched in reality and nowhere is that more evident than in the EV world.
- 2012 alarm issue
