- Hi everyone
Crucian started following Hi everyone
Essexman1 joined the community
Key replacement
We lost a key. Went to a reputable independent local locksmith that specialises in car keys. Tried twice to get a new key working: First time with a third party fob Second time with a genuine Skoda fob Failed both times to generate a fully working key fob. Sounds like I will have to try the dealers. Anyone else had similar problems David
dacn started following Key replacement
Dani1980 joined the community
HandyHowie joined the community
Fabia Automatic
Thank you.
Cambelt / Timing Belt Quotes
As your in Glasgow try https://www.thecrossgarageltd.co.uk/ for a price.There in Kirkintilloch and are vw/skoda specialists. Bought a 1.9tdi from them a few years ago that had been looked after/serviced by them and had no problems for years. They were really good to deal with. Old school garage Father and Son. Alasdair
Alasdair1 started following Cambelt / Timing Belt Quotes
Fabia 2011 1.2 TSI - DSG 7 speed gearbox help
^^^ That is different from doing a DQ200 on a 1.2 or 1.4 TSI Fabia. Do not remove the starter motor. @Catwoman If your car is a 2011 than there was a Service Campaign after 2014 to change the oil from Synthetic to mineral & a software update. '34F7' Dide the car get that. Sticker in the spare tyre well. There are 2 oils to change, in the gearbox and in the MCU. If changing the oil best do both. Best know what you are actually doing.
Fabia Automatic
It is a DQ200 DSG which is a Twin Dry Clutch Gearbox. Skoda / VW call them a Semi Automatic. They are as far as matters a 2 pedal automatic gearbox. Best thing is go try one. You driving it like an Automatic, so 1 foot only. You can change gear manually. No Servicing Schedule with them.
Fabia Automatic
I am very happy with my MkIII Fabia estate so looking for a Fabia for my daughter. Sadly she only drives an automatic and I have no knowledge of automatics. I would be grateful for any advice from owners.
Mugwamp started following Fabia Automatic
I seem to recall there's some reasonable step by step guides on YT, e.g.: We've the same DSG in our Polo. I've considered changing the oils, but not yet made it past the considering stage. Gaz
Catwoman started following Fabia 2011 1.2 TSI - DSG 7 speed gearbox help
Hi all I am fairly new to this website and definately new to being a Skoda owner! I purchased the above car a few months ago and as we (my family and I) usually do all our own car maintenance although we are pretty clued up I purchased a Haynes manual for the car it covers the 'usual' stuff but unfortunately it doesn't cover certain areas like the DSG, I want to replace the oil in the gear box and need to find a definitive answer as to what oil type, the quantity and also how to change it. So if anyone out there is able to help with any advice or trusted web links it would very much be appreciated. Thanks 🙂
JD52 started following Strange flickering from inteface consul
Good morning Jamie, what is your mileage? Are you beginning to have issues with the pump?
Warrior193 started following Cambelt / Timing Belt Quotes
Hi, I have a Bolero enteratinment system with the CPU head unit in the glove box and a 5E0 919 605 B interface unit on the dash. Over the last year I have been getting periodic flickering on the screen until the summer when the screen packed up altogether but the buttons continued to work. I replaced the interface unit and whilst this worked for a couple of weeks, the dreaded flickering has returned and I'm worried the replacemed screen is going to go the same way as the last one. Does anyone know what might be going on here? Or quite happy to be pointed to another post that covers it. Thanks
Johnny_bravo_5 started following Strange flickering from inteface consul
- Hi everyone
Skoda Karoq 1.5 DSG gearbox
A final(hopefully) posting on my mate's 2019 VW T-Roc 1.5TSI 150PS DSG, WBAC happily took it off his hands, I don't know what sort of money he got for it, but maybe I managed to soften the blow by saying that I was worried that he was going to just get it repaired and then get hit by the much quoted DADA engine problems "quite soon after". So it's back to using some of his fleet of classic SAABs for now!
Johnny_bravo_5 joined the community
Windows
Thanks for your tip, I don't have a lot of faith in our local Skoda dealer. Which by the sounds of things is not unusual!!
Geobrett joined the community
Front consul bush which way do they fit Mk1 1.2htp
Hi Got to change my sons front consul bushes on his mk1 1.2htp and the old bushes are so worn so not sure which way new ones fit. I think the narrow slotted section in rubber is vertical and hex section has to be horizontal but they are offset so is it the narrower side or thicker side that is nearest engine. Photo from internet as example and his are about the same. Going to replace swing arms etc at same time. Using Febi reinforced bushes. Alasdair
Photography Thread
I like this one
Hi Posting for information as most of the posts I could see by searching for timing belt pricing were a few years old. Have received the following quotes in and around the Glasgow area over the past week. All quotes are for the timing belt and water pump on a Mk3 (2018) 2.0 TDi. All inclusive of parts and labour. Skoda Dealer: £990 (plus £110 extra for auxiliary belt) Local garage: £770 not incl. auxiliary belt VAG Independent: £800 incl. auxiliary belt Of course prices likely to depend on where you are / engine etc but significantly more than what seems to have been quoted a few years ago may give an idea to any prospective buyers or those planning ahead. I assume prices have just gone up over the years as all quotes are in the same / expected ballpark but if I'm being ripped off let me know!
- Loss of power, black smoke
Photography Thread
Roge joined the community
Exhaust Backbox
That’s great detail thanks @JR RS sounds like @tombee and I will get what we’re after from the kind offer from @travs !
Slartibartfast80 joined the community
Cleaning Veritate wheels
Much appreciated! I bought the extras expecting to screw up with the first or second attempt. This kind of thing is quite amusing. You pay a considerable pile of cash for what must be the most software complex car we've ever owned and.....I am buying a pack of three toothbrushes for £3 on my Tesco Clubcard to help clean the intricate wheels! It could be worse. Our RR Velar cost us £71k back in 2017 and I found myself stuffing pipe insulation to pack out the tension for the driver's window to stop it rattling - one if several DIY fixes. Whether its been the Mercedes, the Volvo x 2 or our earlier Ford Galaxy..... DIY, John Bull solutions have had their place! I'll post a photo of my remodelling attempt later in the week when I get some time to do this. Thanks again for the suggestion. Best wishes.
Exhaust Backbox
This type of rear diffuser, known as the Sportline diffuser does not come with exhaust cutouts. It comes with or without towball cutouts, and it comes in chrome or black trims. I changed my basic non-Sportline diffuser with no exhaust cutout on my 220 to a Sportline diffuser with no exhaust cutout, bout 7 yrs ago. The Sportline 280 4x4 and non-Sportline 4x4 both get a different diffuser, which has the exhaust cutout. They don't get a Sportline diffuser. Also, it's the same diffuser regardless of wagon or sedan. The bumper itself though IS different between wagon and sedan.
MK4 2021 Octavia RS back climate control rattle/buzz noise
Hello everyone! I am long time lurker, this is my first post. I own a 2021 MK4 Skoda Octavia RS and I love it, but some things are annoying my autistic brain, mainly - rattles and interior random noises XD But ok, I managed to identify main culprits and solve the issues to somewhat satisfactory extend, but one kept on bugging me, until my buddy finally identified the culprit: the back seats vent controls. At higher speeds on highways (which are fairly good in Croatia, regarding the surface quality) this thing produces a high pitched rattle/buzzing noise, it is kinda hard to describe it, but imagine having a coin on a metal surface that is vibrating at high frequency. So he identified it and moved it and then it stopped. Then I tried it the next day and it worked, but I can't find a permanent solution, so I am asking you if anyone has any ideas? I do have felt tape, silicone spray and white grease spray (lithium grease), should I perhaps first try with small amounts of grease on the plastic joints and contact areas? Thanks,
Martin088 joined the community
Bodzio joined the community
- No crank no start
Amazed Skoda has become so BAD..
Unforunately the car developed electrical faults, Map detail disaappearing with an image of a car in a blank screen, an intermittent warning the active sign recognition wasn't working, a booming/resonance in the cabin plus others. Took it back and rejected it under the Consumer Rights act on monday 5 oct. After my Superb it was a disapointment.
