Improve VRS handling?
As others have said the bushes may pass an MOT but they really only fail when they tear, so overtime they degrade and crack and become soft (much like me it seems), refreshing the bushes is a good place to start. There are so many on these cars I would start with ARB bushes and then look at things like swing arms etc. I had mine on the ramp recently and I was looking at the state of the bushes and thinking I should probably start a refresh as they are looking a little worse for wear after 11 years.
Sharpy64 started following Improve VRS handling?
The bushes may look ok and get through MOT but overtime they get worn out with too much play. Did my old volvo years ago as it was like driving a boat. New bushes all round and it was like new again. Went for standard rather than poly mainly due to cost. Maybe start with antiroll bushes and take it from there. Alasdair
Alasdair1 started following Improve VRS handling?
Nice, do these replace the standard lights??? do you have a link for them please
Missfueling - Diesel in 2014 petrol car
We also have a diesel car hence the momentary lapse. Normally we would not be able to put the diesel nozzle in the petrol neck. Yes I thought of stickers but wanted a fool proof solution.
Reverse Camera Fitting Guide for mk4?
And 6C is coded to Octavia MK4 NX : 03032200A53000
I think you’ve answered your own question. You don’t need to improve the handling, you need to repair a component to restore handling. It’s likely a worn bushing - could be ARB, LCA, trailing arm, drop link, subframe, shocks, whatever. A common modification for these cars is to replace the stock RARB something 24mm or thicker - be it from a GTI CS or an aftermarket place like Hardrace, H&R, 034, IE, SuperPro, or Whiteline. It makes a big difference, but beware of going too stiff without changing other components to suit.
OccyVRS started following Improve VRS handling?
AlexNk started following Expansion tank contains silica? Skoda Fabia 2018
Hi, I have just unplugged to check if my Skoda Fabia 2018 1.0 TSI expansion tanks contain silica so as to replace it with silica free and completely change the anticoolant from G13 to G12evo. The OEM number is 6Q0121407B. Attached are the photos. I have asked three AI engines but all say is silica free. I just wanted a second opinion so as to proceed with only anti-coolant change to G12evo. PS. the level of coolant is low because I sucked out a bit in order to be easier to unplug to check the OEM.
O3 - 2015 - 1.2 TSI - Replacing splash guards at rear brake disks, how much trouble to expect?
Bearing out (prepare new axle bolt and protective cap, if old bearing will be re-used). 4 axle flange bolts out (prepare new bolts). Just recognized big crack in my '2016 Octy rear/right guard- so, it's upcoming job for next year. Maybe it's wise to prepare new bearing too. Don't know if they have tendency to bake on axle.
AlexNk joined the community
Surely just "knowing" the car and knowing the correct hose colour will work for you. Or stick a "PETROL ONLY" sticker on the outside of the fuel cover - or even the inside of that cover.
Coolant tank replacement - Should I be worried?
One thing that I will add, if you are keeping this car for "a while", if it still has G13 coolant in it, it should get replaced with G12 EVO as it was only G13 that needed the Silicate pouches to add Silicate back into the coolant as it was being depleted in use, especially with certain engines/temperatures. G12 EVO does not need this which is why "Mit Silikat" has disappeared from newer VAG car reservoirs. Some people will say that it's easy to work out which coolant is in the system by checking its colour - I can't say that I'm 100% certain that I can/could, I've replaced the G13 with G12 EVO in both our cars - more due to the car's/coolant's age than anything else.
Paint Protective FIlm
Thanks. Doesn't seem to list Skoda though.
Yeti - When to sell ... Or keep?
Right time is maybe before or during winter not after it, unless you need it through the winter.
Evolution13 started following Yeti - When to sell ... Or keep?
Hi thanks again for all your help. I have a 23 plate mk4 octavia and pro obd11. Is below the only coding required? 19 Gateway Configuration: Byte 15 : Change 02 to 12 Byte 16 : Change 01 to 51 Byte 18 : Change 10 to 20 Byte 20 : Change 00 to 02 5F — Adaptation Settings: function_configuration_unit → Select RVC_video_input Change FBAS to Ethernet Car_Funktion_List_BAP_Gen2_VPS_0x0B ------ Switch to activated Car_Funktion_List_BAP_Gen2_VPS_0x0B_msg_bus ------ Choose "terminal 15"
Yes,I think it could be a 'regretted selling' move for us. Might wait until the mileage is higher (it's 74k) or if the DPF/EGR show signs of playing up. The only car that might appeal is a used Audi Q4 e-tron (4x4 model), but they're still too much for us.
2012 Octavia 1.6 high revs and fan on after switch off
They look like these for the DSG Service Recall, or any recall. Dealer Stamp and date. If you want to know if the Defeat Device Voluntary Recall action was done try the Skoda Recall site and see if still outstanding, or it might show on the MOT site for Recall actions. http://skoda.co.uk/owners/recall-campaigns
@pikpilot When did the upgrade happen? What does the sticker look like?
According to AI, some petrol cars left the factory with the wrong ie Diesel filler neck. This was proven when I put diesel in my 2014 Fabia. It drove normally for 5 miles then stuttered to a stop, restarted and pinked another mile then engine light came on, stopped and wouldn't restart. Is there an aftermarket restrictor or DIY work-around so I don't have to buy and fit a complete filler neck?
Diesel in 2014 petrol Fabia
According to AI, some petrol cars left the factory with the wrong ie Diesel filler neck. This was proven when I put diesel in my 2014 Fabia. It drove normally for 5 miles then stuttered to a stop, restarted and pinked another mile then engine light came on, stopped and wouldn't restart. Is there an aftermarket restrictor or DIY work around so I don't have to buy and fit a complete filler neck?
I just managed to fill diesel in my petrol car. Need some pointers.
According to AI, some petrol cars left the factory with the wrong ie Diesel filler neck. This was proven when I put diesel in my 2014 Fabia. It drove normally foe 5 miles then stuttered to a stop, restarted and pinked another mile then engine light came on, stopped and wouldn't restart.
Unfortunately I cannot see the images that you uploaded, however my experience is that the bags are pretty robust, I have removed a few from expansion tanks and never had one split (but I am aware that they can degrade over time). There is often some small amounts of residue in the expansion tank and if you have not had any issues to date and have replaced the expansion tank I would not expect you to suddenly have issues.
Sharpy64 started following Coolant tank replacement - Should I be worried?
gav_is_con started following Superb 2 rear suspension sitting too low with new parts
Actual v estimated mileage and charger anxiety
So I'm waiting for my elroq 85, I currently drive a 58kw id3, this has a simular range to the elroq 60, I have found the worst battery killers are HEATING (by a long way) if driving long distance in winter and can stand it just turn on your steering wheel and seat heating with a window slightly open to prevent windows steaming up. And turn off your heating SPEED drop your speed on motorways to 60 if poss makes a huge difference. Doing this allows me to get over 220 plus in winter and another 20-30 when car was new AIR CON has a much smaller effect on range in summer I am easily hitting 4-5kw in summer and 4 in winter doing this. I always charge to 100% for long journeys and main battery is fine I've lost around 20 to 30 miles from new where I was exceeding stated max range. This doesn't mean sitting in slow lane at 50mph but full heating at 70 kills range
Last night I replaced the coolant tank for one without the "mit silikat" statement. I couldn't actually see a silicone bag in the old tank but I have heard that some are double walled and you can't easily see. So for some cheap piece of mind I decided to replaced it. After installing the new tank and pouring in the contents of the old tank, I noticed some residue left over in the jug I used that looks very silicone like. I'm unsure of how to react to this, the car is now on 98k miles and the previous owner had owned from new looking after the car extremely well. Could I be safe in assuming he had removed the bag himself? Or do you think this has happened as a result of the bag exploding? The coolant is a nice clean bright pink colour and the old tank showed very little fouling which I suppose is reassuring. I do have a minor coolant leak, not sure from where but the water pump has not been replaced yet, which is the usual suspect. I am taking the car on a long 1000+ mile trip this weekend and need to avoid any car troubles. Is this amount of residue worth worrying about? is there anything I can check? Just looking for any sort of advice right now. Thanks in advance, Matt
Octavia IV Combi 2.0 TDI — 129 Hz droning above 125 km/h, temperature-dependent
The German Skoda forum also has a topic on this issue. Some of them have found seals around the radiator to be misaligned, however, not all report that it fixed the issue. https://www.skodacommunity.de/threads/octavia-neuwagen-2024-droehnen.151232/
OEM electric windows + mirrors retrofit on a 2001 Fabia Mk1 Classic – wiring / Comfort module questions
Pins 3 and 4 of black 6-pin connector at A-pillars is where I'm seeing A146, A147 in circuit diagrams. Other thing you may have to add is power wiring for windows, pins 1 and 2 of the black 4-way connectors at A-pillars, from fuses and earth points. Can't you just chop it in for a Fabia that already has all this? They're not exactly scarce.
