  2. Unfortunately a few miles, even at low revs is many thousands of piston cycles in the cylinder - and yours is an 'interference' engine, meaning there is almost no clearance between piston crown and cylinder head!
  3. Update - I spoke to @Breezy_Pete over WhatsApp the other day, and he'd mentioned the PCV system being at fault. After procuring and fitting a known good one from a parts engine my mate has kicking about - I've still got the same issue. I get the fault codes as before, but also it feels almost like it's hunting at idle, and on light throttle it genuinely feels almost like it's misfiring. Throttle body has been swapped for the parts one too. There's no air leaks from the pipework now either as it's all new. Everything I seem to think would be wrong with it, just isn't or has been replaced already.
  4. A reputable dealer would have erased route history for privacy reasons I suspect. The second question depends on if it was specced from new by the buyer. That can be answered by getting the VIN decoded. Maybe the seller can answer that for you. Mine did.
  5. Gowna started following Route Data
  6. Just picked up my nearly new Octavia a couple of days ago and trying to find out what it can and can't do via the infotainment head unit. So a couple of quick ones of I may. is there a way of pulling historical route data to prove where the vehicle was at a particular time and date? I'd there a setting which picks up fixed speed cameras? Many thanks
  7. And one more question.. I want to sell the car. If the new owner makes a new account and Skoda ID, will he benefit again of the 3 month free Care Connect and Infotainment online service? Or is a VIN related one time free service? And secondly, is there anyone in the same position (after update via USB to 1989 the eManagement not working) that succeeded disabling Reduced charging current from the Skoda App? Thank you in advance!
  8. Worth checking these drainage holes as they are easily overlooked can get blocked. A few years back I had a small ingress of water and after clearing these I had no more problems. (It didn't make any logical sense but then when do these sort of problems ever make sense?). Not having a sunroof should be a big weight off your mind as leaks from the sunroof have always been a major problem coming up on this forum.
  9. Today
  10. A tough time for you but you now have a new chapter ahead of you, the new car is a nice way to get started in it. All the best.
  11. I could be interested to replace my Kodiaq Mk1, but 28mn to charge batteries from 10 to 80% (Skoda value for 90kW version) seems still quite long to me. Just for comparison Xpeng G9 says 12mn for the same WLTP range...
  12. 75000km service today: oil change + oil filter replacement + cabin filter replacement. Everything went fine. 🙂
  13. I will try a factory reboot again. 1. Turn on the ignition and switch on Infotainment. 2. Tap the Menu / settings icon (usually a gear or the MENU button). 3. Go to Reset to factory settings (or System → Factory settings / Restore factory settings). 4. Select and confirm the reset. 5. After it finishes, check that all user accounts have been deleted to confirm success. These are the steps, right?
  14. Evening all, Picked up my new (to me) 2022 Superb L&K yesterday. Really pleased with it, but am having one minor issue when trying to set myself up as the primary user on Škoda Connect. When I try to become the Primary User, the car asks me to authenticate using two of the three keys. The process consistently detects both keys successfully (0/2 → 1/2 → 2/2), but then the car sits on a loading screen and eventually brings up and root message. The MyŠkoda app eventually reports that the process has been ‘aborted’. I’ve tried quite a lot of troubleshooting, including: Trying all three keys, and every possible two-key combination/order Keeping the unused third key well away from the car Soft-resetting the infotainment system Removing the vehicle from the MyŠkoda app Closing my original Škoda account and creating a completely new one Deleting and reinstalling the MyŠkoda app from my phone Confirming that the only users shown in the car are my own profile and Guest Factory-resetting the infotainment system Reset all factory settings I occasionally also get a message saying that a vehicle key has already been detected and that I should use a different vehicle key, despite the Primary User activation never completing. The key authentication itself appears to work correctly every time, so I’m wondering whether there could be an issue with the Škoda Connect registration, infotainment software or online connectivity module. I appreciate there are a few threads on this (where I got most of the above troubleshooting advice from!) but nothing that solves it for me. Any other ideas? Otherwise I imagine it will be off to a dealer to see if they can resolve it. Thanks.
  15. Satuok started following Skoda Connect issue
  16. Problems on this car are like buses. You wait years for one and.......you know the rest. Mine was registered September 2015 but I've owned it since September 2017. In the last 4/6 weeks; Main car key snapped. Coolant tank drains in one day from full. Inner door handle snapped. Has your coolant tank sprung a leak and if so, what did you have to replace? I want to give a garage a heads up when explaining the issue. And I'm not going to Murray Group main dealer. They scammed me out of £860 on a brake job. Also, how simple is it to DIY replace the inner door handle? Need to find the part number. Same with the car key. Thank you.
  17. The policy lapses with the death of the policy holder, so she cannot be covered by the policy as it has lapsed.
  18. I suppose that’s the clutch hole for lhd. I’ll have a look and see if I have it too as I’d rather go behind the dash than through engine bay Edit: I can feel it through a gap in the carpet but engine bay side would have to take battery etc out again and I’m not sure I can be bothered!
  19. PMcGrath joined the community
  20. Es gibt unter der Haupt Durchführung noch eine mit der Gummi Tülle sogar welche sogar verschlossen ist. Sicherungskasten ist bei mir Höhe BCM aber davor. Hölle was nachpinnen. There's another one under the main cable gland, this one even has a rubber grommet and it's sealed. My fuse box is at the level of the BCM, but in front of it. What a pain to repin!
  21. grumpy65 joined the community
  22. Do you not have the fuse box crammed up above the pedals? Have you ever got cables through the main grommet? Are there any others to go through other than the clutch one?
  23. Great, thx for your info.
  24. I took the car to a garage to have it for a few days. They check if there was any oil in the cylinders after leaving the car overnight and there was no oil found using a camera. They checked for timing chain stretching and it was within tolerances. Then added injector cleaner and took it for an extended test drive from cold. They confirmed the rough idol was just from cold start up so most probable cause would be carbon build on the valves. As the rough idol is on start up only they advised leaving until it is noticeable when driving or there is a misfire that causes the engine light to come on. Until it does get worse they said it current state did not justify the cost of the carbon clean. As my Audi is due for collection in the next few weeks after a long period in the garage and the Skoda will be used less going forward I will leave doing any more work on it for now.
  25. Thank you, the update fixed my boot loop.
  26. @adamarchie you have it in your message
  27. Hi. If you need any help with insurance when your policy comes up for renewal then please feel free to drop me a line. Regards, Dan.
  28. Thank you Steve most appreciated, it was been a difficult few years for me with being forced to retire early by my company and the deaths of my dad, soul mate and last year mum, hopefully this new car will signify a new start for me and better luck 🙂
  29. My local dealer has both 1.5 and 2.0 in used stock, so i'll go and try both this week. My gut feel is the 1.5 will be fine, it's the same engine I have in my Golf and I won't be towing (just need towbar for bike mount) or off-roading, so can live without the extra 35bhp and 4x4 - but we'll see. I should be fine with the 19"ers, I had them on my last VRS and only yelped a few times when hitting potholes. I'd rather live with that and the sportline's styling than go for comfort in a plainer exterior. I'd also rather not have the pano roof but seems it's standard on sportlines since the 2022 facelift and with proper maintenance, it can be a non-issue (wishful thinking maybe?) They're good looking cars and I like that there's still proper buttons inside for the heating, auto stop/start etc... My wife will be happier driving it than the Octavia estates and the boot will be so much more usable than the Golf (which doesn't even take my GOLF clubs comfortably!) Thanks again for your help and guidance everyone, i'll report back. 🙂
