Past hour
I noticed my car records the minimum cranking voltage drop in the gateway module. Most mornings it reads 7.90-8v. I have seen it drop to 7.5v. Not sure how accurate that is I left my car in for ceramic coating and when i picked it up the next morning it dropped to 6,6v and a **** load of low voltage codes.( i’m sure they were opening and closing doors while cleaning)The lowest i have seen on a battery tester cranking test was 7.9v.
Skoda Rapid front left ABS sensor wiring replacement
Bridging it will be much easier than replacement.
Hi all. How difficult is it to replace the whole harness, cable, wiring for the front left ABS sensor? I stupidly bought the sensor only to discover something cut my wire. Around an inch is missing. Bridging it seems a bit tedious and risky. See attached image. Thanks Kris
Krisiacik started following Skoda Rapid front left ABS sensor wiring replacement
Today
turbomikee joined the community
Battery issue or?
Surprised the battery wasn't dropping below 10 volts if it's faulty. Check with them that the replacement is correctly adapted (coded) to the BCM.
Battery issue or?
Even if you don't use SS, the alternator charging algorithm stays the same - which can mean the battery SOC never gets above 75%, particularly if relatively short trips are common.
sandspider started following 2017 Octavia vRS 2.0 TSI 245 - non-runner
- Play in between outer and inner track rod end
Battery issue or?
UPDATE: this morning the engine wouldn’t turn over at first and then it started normally on the second go. Drove the car normally during the day but decided to visit the dealership. They ran diagnostics and the battery came back as faulty. Putting in a brand new one at this moment. I’m just a bit surprised that an original battery only lasted two years and one month, I don’t even live in an area that experiences extreme low temperatures and I’m wary of stuff such as start/stop system and such.
Incorrectly Identified NSL Speed Limits
@stepred I suspect we're stuck with it unless they manage to accidentally fix it in the same way that they accidentally broke it. What has become abundantly clear through this journey is that neither Skoda UK nor Skoda Connect have the faintest idea about the software running on the vehicles. And for good measure, neither give the proverbial flying **** that it's broken. If you want to pursue it with Skoda Connect, my original case number was 00410339, which then changed to 00473621. But they started ignoring my emails in August...
Battery issue or?
Cold start this morning, measured at the power outlet socket in the car. Initially 12.2, then 10.3 when cranking. Battery 14 months old, fully charged by external charge yesterday.
- Wheel nut torque
Attached the erWin rundown if anyone wants to check spec. erWin Online _ Škoda Auto _ Vehicle-specific information.pdf
Tazdaz started following 2017 Octavia vRS 2.0 TSI 245 - non-runner
Make & Model: Skoda Octavia vRS 2.0 TSI 245 6spd manual Colour: Meteor Grey (Primer) Mileage: ~74,600 Price: £4200ono - testing if anyone wants a project car before chopping it in at a scrappy Description: 2017 67 plate. One of the early 245 editions with memory heated front seats, heated mirrors etc. 19" Xtreme alloys have been powder coated gunmetal, now showing some signs of wear but still very presentable. Alcantara suede type seats in good condition, needs a valet but no tears or damage. Everything on the car was working as expected until a low oil pressure warning and subsequent garage visit. 2x sets of keys and V5 present. I'm the second or third keeper (log book in the car so can confirm shortly). Spent quite a bit on it this year so decided to cut my loses and move on (probably to a newer vRS). If you need any further details please let me know. Needs to be collected by Monday 30th November ideally. Non-runner - ea888 crank walk/thrust washer issue and some swarf in sump. Garage suggesting easier to replace whole engine rather than tear down and inspect/flush. Condition: Non-runner - otherwise in good used condition. No crash damage. Service History/Receipts/Recent Service work: Full service history through an extended warranty period (first 5 years). Home serviced since warranty expired, but has not wanted for anything. Oil and filters and other consumables all changed every 12 months or sooner. Bilstein B4 shocks and OEM springs all corners fitted in February 2026 (by VAG specialist - receipts available) Sachs Performance Clutch and LUK DMF flywheel fitted in February 2026 (by VAG specialist - receipts available) VAQ serviced twice in my ownership, last in February 2026 when clutch being installed. Rear callipers and hoses replaced August 2026 Brembo pads and discs all round January 2026 Water pump/housing replaced by Skoda in 2021 Extras: None that I'm aware of. It's the special early 245 that has heated front memory seats but don't think they are technically an extra. Mods: <OEM+ Stage 1, Sach Performance Clutch (organic). Wheels powdercoated gunmetal gloss.> Shipping: Collection only - central belt Scotland (Denny). Non-runner so needs a flatbed. Collection: <Collection only - central belt Scotland (Denny). Non-runner so need a flatbed. > Pictures: Some early pictures in my profile posts. It's broadly same condition, but needs a good valet inside and out as wasn't expecting to sell! >
1.4 TDi Spluttering and Loss of Power When Up to Temp
Hi all, Not strictly a Skoda but a VW with the same engine. My wife's Polo suffers from kagaroo-ing and loss of power when up to temp, but is perfectly fine when not to temp. No fault codes stored. 1.4 TDi BMS 2007. Starts and idles fine. Pulls well. All seems fine until the engine is at operating temp. Then the problems begin. Seems to take ages to warm up too but with this cooler weather I'm not sure it is a problem. However Gauge shows around 50-70 most of the time. Called AA when it first happened. Couldn't find a fault and recovered it to the VW Garage we use. Garage had it over 2 days and couldn't find a fault. Things I'm going to do this weekend. Change Thermostat Change Engine Temp Sender Remove and clean out EGR valve Replace rubber vacuum hoses with new silicone ones. Anything else I should be looking at?? TIA Nic.
2006 1.2 drivers door switch location?
Will fix it if I have to remove door card etc again. Will check wiring at pillar just in case but as fob works and everything else reckon its probably switch. Thanks again Alasdair
Yeah, not worth fixing if he's not bothered.
Wheel nut torque
it really doesnt mater, if thread is M14x1,5, all should have similar moment in Nm, on smaller cars M12x1.5 i used 110 Nm, on Karoq 125Nm. it depends massively of which material wheels are, steel wheels can be torqued much more, aluminium less. it really dont mind 120 or 140 Nm wont loose bolt in any way.
imart143 started following Wheel nut torque
Thanks for the quick reply pete.(Reckon thats a record in 2mins) At moment its just the lights on warning and no interior lights and he says hes not fussed. Have a spare set of rivets for door card so will have a look when weather better. Will maybe check the wiring at door pillar to see if theres anything obvious. Thanks again Alasdair
Coolant level warning mystery
I was hoping someone could give some help in tracing what's causing my coolant level warning on the dashboard. It's a 2008 2.0 diesel. The warning is the three beeps and the red light flashing on the dashboard. (1) The coolant level is correct; (2) I've replaced the expansion bottle which came with a new sensor which made no difference to the problem; (3) the contacts to the sensor in the expansion bottle look very clean; (4) the engine is not running hot, the warning usually comes on within a minute of starting from cold; (5) the temperature gauge is working as normal. Sometimes the warning doesn't happen, usually if I've driven the car, left it for an hour or so then started again. This could be random as I've only had the problem for a few weeks. Assuming the level sensor is working as I've replaced it, is there another sensor that can cause the warning, I'm thinking one that says the engine is too hot, that could be faulty? Or is this the same as the one that operates the water temperature gauge on the dashboard? Is there anything else that I can check? Thank you.
If the nut is fully tight there should be no play unless as said thread on track rod is stripped and its loosening or the thread in track end is the same/wrong thread. I would remove end and inspect both ASAP and refrain from driving it. It may be the nut has seized before being completely home due to grit etc.Wouldnt be a good scenario if it came apart! Alasdair
Alasdair1 started following 2006 1.2 drivers door switch location? and Play in between outer and inner track rod end
- Battery issue or?
Yes, it's on the rear facing edge of the door lock. Pain to access on a rivetted-carrier facelift mk1. Can be microswitch itself or solder joints where it wires onto circuitboard within lock module.
Hi sons mk1 fabia 1.2 door switch or wiring seems to have failed. No warning sound when lights left on and no interior lights turning on. Car still locks and unlocks with fob. Had a quick look and cant see where the switch is. Is it part of door lock? and how to access. Only noticed as he left lights on last night. Alasdair
Hello Rbz5416 I have been having similar issues with incorrect speed notifications for about the same time as you. I use a lot of single track NSL roads. I am getting indications of 20 or 30MPH when the correct indication should be 60MPH. I have raised this with my Skoda dealer and basically they dont have an answer, other than the software has been outsourced and we are waiting for a fix from the 3rd party. My car is a 2024 Kamiq. I have attached a photo on a NSL road which shows the problem.
stepred started following Incorrectly Identified NSL Speed Limits
Car has been driven ~ 5,200 mils in past 6 months, readings taken today, below. 59AH EFB Battery Original from Jan 2019 11:41:09 Mileage: 31,734 miles IDE00019 Voltage terminal 30 12.4 V IDE01836 Battery current -4.372 A IDE01837 Temperature of battery sensor 24 °C IDE01839 Battery charge status 85 % IDE01841 Battery internal resistance 8.0 mOhm IDE01842 Usable battery charge 31 Ah IDE01843 Battery voltage at rest 12.6 V IDE01948 Battery internal resistance not normed 6.8 mOhm IDE07681-MAS06086 Battery total charging throughput-Total re-charge 4345.8 Ah IDE07681-MAS06087 Battery total charging throughput-Entire energy throughput 4535.9 Ah
stepred joined the community
