  2. hello hope all is well does anyone have the following: VW Polo 6C 3Q0035874A (MST2_EU_VW_ZR_P0241T) stuck in Emergency Download (Device: cpu Module: cpuboot%1 FileReadError). mibsolution.one is down and MIBVault's P0254T.7z is missing cpu/cpuboot_sec/12/default/Bootloader/init_mibstd2_cpu.dat (SHA1 ad9423fb38ff88c37e3521c58d161785c2ced62e). Can anyone share a working GDrive/MEGA link for MST2_EU_VW_ZR_P0253T.7z / P0252T.7z or that 45KB init_mibstd2_cpu.dat file? currently stuck in red emergency download. i used this file (3.5gb)MST2_EU_VW_ZR_P0254T.7z [21/11/2026 21:44] jessreadingx: https://mibsolution.one website is down and doesnt work also @pab567 @varooom
  3. Don't look for them physically, instead use a scanner like OBDeleven or VCDS. That's how u find out part numbers.
  4. fclx0 joined the community
  5. I think that that reason is acceptable when a car part does not cost much, but once the cost reaches a certain level, owners have a right to expect that parts are fit for use - and fit for use over a reasonable period over time/miles. I'm guessing that this part cost roughly £200 from Skoda UK. I replaced a Lambda sensor on my wife's 2015 VW Polo 1.2TSI this year at roughly 60,000miles, even although I was careful with the Lambda sensors connector support bracket, I broke a tang off it when removing the faulty Lambda sensor connector. I fitted a new support bracket this week and while removing the old bracket, I broke a tang of the "other" Lambda sensor mounting point, the new bracket only cost £6 I think, so no big deal - but that was due to the plastic becoming brittle with age and local heat. One annoying bit of this job was, the cable tie mounting that snaps into this bracket, partially broke up while I was removing it from the original bracket - again "not very suitable" plastic - the sort of thing that people used to complain about when buying/using stuff "made in China" - how standards have dropped in Europe, or even from suppliers that European manufacturers use!
  6. I understand. I had more doubts as well. In my country it costs me around 20 euros, which I will compensate by doing the oil change myself and saving in labour costs haha. Also, here’s an article about the reduced noise and vibration levels by using the product: https://www.team-bhp.com/forum/technical-stuff/196980-review-liqui-moly-cera-tec-friction-modifier-my-skoda-laura.html
  7. The last FEAD belt that I replaced was on my wife's 2015 VW Polo 1.2TSI and it was a Contitech (Continental) that I bought. The belt for her previous car, a 2002 VW Polo 1.4 16V, that I bought was a genuine VW Group part - and it was a Dayco "made in France", and it, when opened out and laid down on a flat surface it had a "bow" in it, ie it only touched the flat surface at 2 points - I examined it and discovered that it had been cut at an angle to the weave - or at least the smooth side material had been, I still fitted it and it lasted okay. I did expect better from VW Group, but there again, I've had failed front wheel bearing due to water ingress - and that bearing was "made in France"!
  8. Today
  9. yeah will do, we tried to get the belt off earlier today and the bit kept slipping off, gonna have to take it to a garage, which is rather annoying as i already bought the belt but im guessing they will want to use their own parts for insurance/warrenty purposes i guess i have a spare belt now 🤷‍♂️ or i could also return it as well as its still in its packaging
  10. Oh well, my mate's Autodoc parcel arrived, meant to be 2 rear callipers, but it seems he has been sent 3 Ridex callipers AND a Ridex radio! Hopefully he attempts to refurbish the 2 original rear callipers and just uses these Ridex cheapies to keep things moving!
  11. Not all modern engines can be repaired easily it seems.
  12. No, just a straight change of old for new. It turned over a bit to start and then the eml light came on. Just turned it off and restarted and eml light went out. My mate reckons it was due to low fuel pressure with changing the filter. Been fine since. :)
  13. Rear shocks, electric tailgate struts, rear discs, 2016 diesels had a bad batch of water pumps, others are ok I think. Some DQ381 7 speed dsg's have failed mechatronic units. Other than that full service history and overall condition.
  14. Replace complete tensioner, not just roller, 2 months ago I put on my 1.5 tsi INA tensioner and belt. Car had 100000 kms. Belt seems to be high quality. Shiny surface which suppose to be dayco or gates. Always choose belts with shiny surface, not matt, it is newer technology. More durable. Original was also shiny one.
  15. Just in case someone is interested: I have been running a JL Audio 10TW3-D4 (2x4 ohm) sub for a year hooked to the Canton sub channels. Works perfectly, no problems whatsoever and enough bass for me. I have cranked the stereo to the max and no issues. The enclosure is a car-model-specific from basser.pl. Installing 10TW3 to the enclosure requires some modification to the speaker hole, the original has to be enlarged a bit. Additionally, the mounting flange needs to filled up with plywood. I also took the trouble or lining the inside of the enclosure with 50/50 mixture of sand and poly resin. This made the walls rock-hard.
  16. Where are these modules located or how can I check if my car has the right ones? It's a 67 plate Sportline if it makes any difference. Thanks
  17. Excellent, well done @DerekU , I'll check that out in the morning when it's a bit warmer! You'd think something so basic would be mentioned in the infotainment part of the manual really!! FP
  18. A coating that can stick to oily metal? Hmm. It's your money.
  19. That’s bad. He should change the oil timely. I will follow this tour coach’s example lol. Anyway, I still have more time for the oil change but I will mostly use Ceratec. Have u spoken to anyone who has hsed engine additives from liqui moly? What was their feedback?
  20. It’s a 10 year old car which I bought and I would want to do all the possible preventative maintenance tasks which will keep the engine running for long. I do understand that the synthetic oil VW provide already provides protection to the engine, but I have seen cases where there will be metal shreds in the engine oil in an aged car. So, Ceratec basically provides a coating which will prolong the engines life. I have seen videos and reviews on YouTube where this product has received positive feedback.
  21. Bert joined the community
  22. I'm not too sure what they did to the ecu I think they could of reconditioned it The chain was changed about 6 months ago by a friend that is a mechanic. The cam to cam and crank to cam was checked and were all okay
  23. Please ignore. I'm a doofus. Had forgotten to peel sticker off new battery. Key works fine.
  24. VW group / Skoda refer to them as Semi Automatics just because that is what what DSG,s and S-Tronics are we them dry or wet clutch.
  25. Hi all, I tried to search the forum but couldn’t find anything that would help. Last month when I was about to leave for work, I noticed that rear licence plate lights were on (the car was locked). I unlocked the car and they turned brighter once the car was unlocked. I locked the car and they dimmed but remained on. I unlocked the car again and tried to open the boot, but nothing happened (it’s a manual tailgate), it was like it was still locked. I used the emergency release from the inside and it worked. After I arrived to work, I was able to open it, but the lights remained on. This went on for few more days and then it suddenly went back to normal - lights off when the car was locked and boot opened just fine, when unlocked. I should mention that this happened after driving in very heavy rain. Anyway, it was then ok till now. It started happening again and the last rain was on Wednesday. I managed to open the boot in the afternoon and I heard water splashing inside of the tailgate and then noticed water coming out from behind the plastic trim as I opened it fully. Google suggested to remove 3 rubber plugs at the bottom of the tailgate to let the water out, which I did. My guess is that water gets in somehow and messes with the cable harness causing the lights to remain on 24/7 and tailgate release not to work at all times. I checked everywhere and everything seems fine, so no idea where the water gets in. Has anyone else had similar issue? Thank you
  26. Hi, Self seal means that You do not have to reipair the tyre. Hoewvet, you still should remove the screw. I had such dituation and the screw was jyst simply removed. Then the tyre was pumped to higher pressure for few minutes an that was it. I have driven after that for 6 motnths and paid attention to pressure - there was no drop in the pressure at all. So it works. Regarding repairibg such tyre - yes it can be repaired. However, it is work and time consuming as they have to remove the sealant. As long as it is just small puncture - repair makes no sense as the self seal feature works ok.
  27. https://www.webuyanycar.com/?glbtrd_src_ind=wtxv-GDWlE-GZf8_oNVxXw%2F&utm_source=google&utm_medium=cpc&utm_campaign=Brand%20-%20London&utm_id=16880063734&utm_source_platform=Google%20Ads&utm_term=we%20buy%20any%20car&utm_content=Phrase&gclsrc=aw.ds&gad_source=1&gad_campaignid=16880063734&gbraid=0AAAAAD-VJQY5QLJFybJ9F7WumJmOZ80Bf&gclid=EAIaIQobChMIruakqNmZmAMVKpJQBh3BBh5SEAAYASAAEgKwS_D_BwE
