Past hour
2017 Octavia vRS 2.0 TSI 245 - non-runner
Attached the erWin rundown if anyone wants to check spec. erWin Online _ Škoda Auto _ Vehicle-specific information.pdf
Tazdaz started following 2017 Octavia vRS 2.0 TSI 245 - non-runner
Make & Model: Skoda Octavia vRS 2.0 TSI 245 6spd manual Colour: Meteor Grey (Primer) Mileage: ~74,600 Price: £4200ono - testing if anyone wants a project car before chopping it in at a scrappy Description: 2017 67 plate. One of the early 245 editions with memory heated front seats, heated mirrors etc. 19" Xtreme alloys have been powder coated gunmetal, now showing some signs of wear but still very presentable. Alcantara suede type seats in good condition, needs a valet but no tears or damage. Everything on the car was working as expected until a low oil pressure warning and subsequent garage visit. 2x sets of keys and V5 present. I'm the second or third keeper (log book in the car so can confirm shortly). Spent quite a bit on it this year so decided to cut my loses and move on (probably to a newer vRS). If you need any further details please let me know. Needs to be collected by Monday 30th November ideally. Non-runner - ea888 crank walk/thrust washer issue and some swarf in sump. Garage suggesting easier to replace whole engine rather than tear down and inspect/flush. Condition: Non-runner - otherwise in good used condition. No crash damage. Service History/Receipts/Recent Service work: Full service history through an extended warranty period (first 5 years). Home serviced since warranty expired, but has not wanted for anything. Oil and filters and other consumables all changed every 12 months or sooner. Bilstein B4 shocks and OEM springs all corners fitted in February 2026 (by VAG specialist - receipts available) Sachs Performance Clutch and LUK DMF flywheel fitted in February 2026 (by VAG specialist - receipts available) VAQ serviced twice in my ownership, last in February 2026 when clutch being installed. Rear callipers and hoses replaced August 2026 Brembo pads and discs all round January 2026 Water pump/housing replaced by Skoda in 2021 Extras: None that I'm aware of. It's the special early 245 that has heated front memory seats but don't think they are technically an extra. Mods: <OEM+ Stage 1, Sach Performance Clutch (organic). Wheels powdercoated gunmetal gloss.> Shipping: Collection only - central belt Scotland (Denny). Non-runner so needs a flatbed. Collection: <Collection only - central belt Scotland (Denny). Non-runner so need a flatbed. > Pictures: Some early pictures in my profile posts. It's broadly same condition, but needs a good valet inside and out as wasn't expecting to sell! >
1.4 TDi Spluttering and Loss of Power When Up to Temp
Hi all, Not strictly a Skoda but a VW with the same engine. My wife's Polo suffers from kagaroo-ing and loss of power when up to temp, but is perfectly fine when not to temp. No fault codes stored. 1.4 TDi BMS 2007. Starts and idles fine. Pulls well. All seems fine until the engine is at operating temp. Then the problems begin. Seems to take ages to warm up too but with this cooler weather I'm not sure it is a problem. However Gauge shows around 50-70 most of the time. Called AA when it first happened. Couldn't find a fault and recovered it to the VW Garage we use. Garage had it over 2 days and couldn't find a fault. Things I'm going to do this weekend. Change Thermostat Change Engine Temp Sender Remove and clean out EGR valve Replace rubber vacuum hoses with new silicone ones. Anything else I should be looking at?? TIA Nic.
2006 1.2 drivers door switch location?
Will fix it if I have to remove door card etc again. Will check wiring at pillar just in case but as fob works and everything else reckon its probably switch. Thanks again Alasdair
Yeah, not worth fixing if he's not bothered.
Wheel nut torque
it really doesnt mater, if thread is M14x1,5, all should have similar moment in Nm, on smaller cars M12x1.5 i used 110 Nm, on Karoq 125Nm. it depends massively of which material wheels are, steel wheels can be torqued much more, aluminium less. it really dont mind 120 or 140 Nm wont loose bolt in any way.
imart143 started following Wheel nut torque
Thanks for the quick reply pete.(Reckon thats a record in 2mins) At moment its just the lights on warning and no interior lights and he says hes not fussed. Have a spare set of rivets for door card so will have a look when weather better. Will maybe check the wiring at door pillar to see if theres anything obvious. Thanks again Alasdair
Coolant level warning mystery
I was hoping someone could give some help in tracing what's causing my coolant level warning on the dashboard. It's a 2008 2.0 diesel. The warning is the three beeps and the red light flashing on the dashboard. (1) The coolant level is correct; (2) I've replaced the expansion bottle which came with a new sensor which made no difference to the problem; (3) the contacts to the sensor in the expansion bottle look very clean; (4) the engine is not running hot, the warning usually comes on within a minute of starting from cold; (5) the temperature gauge is working as normal. Sometimes the warning doesn't happen, usually if I've driven the car, left it for an hour or so then started again. This could be random as I've only had the problem for a few weeks. Assuming the level sensor is working as I've replaced it, is there another sensor that can cause the warning, I'm thinking one that says the engine is too hot, that could be faulty? Or is this the same as the one that operates the water temperature gauge on the dashboard? Is there anything else that I can check? Thank you.
Play in between outer and inner track rod end
If the nut is fully tight there should be no play unless as said thread on track rod is stripped and its loosening or the thread in track end is the same/wrong thread. I would remove end and inspect both ASAP and refrain from driving it. It may be the nut has seized before being completely home due to grit etc.Wouldnt be a good scenario if it came apart! Alasdair
Alasdair1 started following 2006 1.2 drivers door switch location? and Play in between outer and inner track rod end
- Battery issue or?
Yes, it's on the rear facing edge of the door lock. Pain to access on a rivetted-carrier facelift mk1. Can be microswitch itself or solder joints where it wires onto circuitboard within lock module.
Hi sons mk1 fabia 1.2 door switch or wiring seems to have failed. No warning sound when lights left on and no interior lights turning on. Car still locks and unlocks with fob. Had a quick look and cant see where the switch is. Is it part of door lock? and how to access. Only noticed as he left lights on last night. Alasdair
Today
stepred started following Incorrectly Identified NSL Speed Limits
Car has been driven ~ 5,200 mils in past 6 months, readings taken today, below. 59AH EFB Battery Original from Jan 2019 11:41:09 Mileage: 31,734 miles IDE00019 Voltage terminal 30 12.4 V IDE01836 Battery current -4.372 A IDE01837 Temperature of battery sensor 24 °C IDE01839 Battery charge status 85 % IDE01841 Battery internal resistance 8.0 mOhm IDE01842 Usable battery charge 31 Ah IDE01843 Battery voltage at rest 12.6 V IDE01948 Battery internal resistance not normed 6.8 mOhm IDE07681-MAS06086 Battery total charging throughput-Total re-charge 4345.8 Ah IDE07681-MAS06087 Battery total charging throughput-Entire energy throughput 4535.9 Ah
stepred joined the community
- Play in between outer and inner track rod end
Wheel nut torque
Our mk1 Tiguan was 120Nm - because it was 4Motion. FWD model was 140Nm. I can't imagine why it should have been different and the Karoq manual simply says 140. In practice there's hardly any angular difference between the two. I'm sure the Touareg is much higher - 180Nm rings a bell.
Warrior193 started following Play in between outer and inner track rod end
lizzz joined the community
1.2 TSi CZJC Lumpy, stalled, wouldn't restart
UK Gov departments do need to keep in with big foreign companies it seems - "let the plebs burn" - and so reduce the pension burden.
Hola, desde España
Welcome to the forum, Juan! Having an Octavia RS 1.8T since new is great, there can't be many original-owner cars left. How's it holding up? And have you done much to it over the years, or is it still mostly standard? There's plenty of knowledge on these engines here, so don't be shy about asking questions. Photos of the car are always welcome too.
AmeliaParker started following Hola, desde España
Zeko started following Skoda superb
Skoda superb
Hello everyone. I have a problem with camera on my superb 2022. When sensor are active I can hear only sound of them, can’t see the rear of car on display. No fault on dashboard. Does anyone had this problem?
Zeko joined the community
MartinLipert joined the community
^^^ My MY16 Octavia (1.4 TSI CZDA) experienced this issue two years ago - reported it to DVSA as a serious safety issue - the reply I received was 'No fire safety issue as there was no ignition source present'! There was a recall for exactly this issue in the US - the VW recall was 24GI.
Wheel nut torque
That used to be for the "biggest" 4X4s in VW Group world.
Chri Harris on Cars.
Yup, though best kept away from steam train enthusiasts!
Wheel nut torque
From the manual for the pre-facelift: Have the tightening torque of the wheel bolts of the mounted tyres checked with a torque wrench as soon as possible. The specified tightening torque is 140 Nm.
Rbz5416 started following Wheel nut torque
Wheel nut torque
120Nm is a good starting point!
Battery issue or?
9 volts is a bit low when cranking - I'd suggest a battery test if it's falling that low. From memory, around 10 volts is a healthy limit.
