MST2_EU_SK_ZR_P0241T What is the current version? Is the link available?
mib helper is your friend for such info... https://mib-helper.com/index.php?train=MST2_EU_SK_ZR_P0241T
FakeRalph joined the community
Radio cutting out new starter motor
Radio wires - yes I checked with multimeter at time. AI says the aftermarket are susceptible to voltage drop and under 10.5v they shut down. Suggested I buy add on that has loom and small capacitor to take up the drop in voltage on cranking. Car wouldn't start now - the spade connector in starter motor had popped out. Any suggestions on holding it in? I crimped spade connector for tighter fit but it was already as tight as it would go. The aftermarket starter motor might have had some wear on its male spade end. I used duct tape but it came unstuck. Soldering a bit extreme and hard to get to. Don't think this is related to radio though. Thanks
igerecs joined the community
Which all-season tyres are you running on your Octavia?
Hi everyone, I have a 2018 Skoda Octavia and I'm thinking about getting a set of all-season tyres. I'm a bit tired of changing between summer and winter tyres every year, so I thought it might be worth giving them a try. I mostly drive around town, with occasional longer trips, so I need something that handles well in the rain and is also decent in colder weather and light snow. I've been looking at a few different brands and comparing prices online, but there are so many options that it's hard to decide. I also came across an autodoc review while looking for information about online parts and tyre shops. What tyres are you guys using? Any recommendations based on your own experience? I'd especially appreciate suggestions that offer a good balance between price, comfort and durability. Thanks!
JackTurner started following Which all-season tyres are you running on your Octavia?
Fob dead locked out? What if?
Could they have been changed as part of a service? Even if the Merc doesn't have kessy, 14 years from a single battery seems a stretch. Unless they're rechargeable? I had a 3 Series where the battery in the fob recharged wirelessly while driving. The car died after 15 years but the key was still going strong.
From memory the yellow wire I think is permanent live and red is from ignition. The yellow wire is there to keep settings etc. It may be that the Kenwood is more susceptible to voltage drop. Check that the yellow wire is getting 12v with ignition off. Alasdair
Alasdair1 started following Radio cutting out new starter motor
I hope Amazon Duracell are OK. BTW, we have a Mercedes 62 reg C180 with 20,000 miles showing and the key fobs have never been changed. Could Skoda fobs last that long?
mdasem started following Amundsen MIB2 Firmware Update
Throttle body actuator
Apologies, it’s for a 19td Skoda roomster 2 - 2007, I thought I had posted the details - thanks for looking
mdasem joined the community
JozsefK74 joined the community
Retrofit rear tailgate LEDs?
OK. So to enable both fog lamps only a coding/adaptation OR dataset change is required. I'm trying to figure them out. For sure there is a small difference between LHD and RHD cars, and merging them will results in both fog lamps on. Can you share a BCM backup of your current state? Thank you
VRS estate - opinions on selling/disposing
Long time no posting! I’ve recently moved over to the dark side and purchased a full electric ( not a Skoda…) In my driveway, I have my 2011 petrol VRS estate. Current state: Occasional ECU communication errors (mainly in very wet days!) Needs wheel speed sensor (traction control error warning) MOT expired (although I’m confident it will pass once the sensor is replaced) My question is: Replace wheel sensor, get MOT, sell through auto trader Get ridiculously low price from We Buy Anycar as is Scrap Other option? To be honest, I’m not comfortable advertising on Autotrader as I would feel bad about the occasional ECU error unless the person buying was comfortable resetting the error code every now and then!
glenmc started following VRS estate - opinions on selling/disposing
Octavia VRS Mk4 - real life MPG
I've had 3 MK4 Petrol VRS' (hatch, 2020, 2023, 2025), and the average for all of them has been between 40-42mpg. Can easily be 50mpg on a long motorway run, and if I get 30mpg on a Sainsbury's run then I've done well. It's pretty efficient if you are happy to drive sensibly!
Check the battery voltage while engine is being cranked - likely that voltage is dropping too low during engine crank.
Warrior193 started following Radio cutting out new starter motor
Driver4567 joined the community
What car? Which engine type?
Hello, Had a crank no start. Bosch starter motor reconditioned fitted. Car starts each and every time for a month since fitting. Wife noticed radio (Kenwood aftermarket) loses power on cranking and resets or stays shut down. Radio fitted 1 year ago and only shut down when battery was knackered. Turning off fan, lights had no effect. Radio loses power when starting every time, warm or cold engine. Looks like a voltage drop. Dash lights unaffected. I already cleaned all earth points in engine bay. I checked the negative battery cable to suspension turret earth. Put extra cable on it in case breakage (jump lead). Radio still loses power momentarily forcing reset. Presets not lost. Battery is healthy and reading over 12.6v AI Google says to fit a capacitor plus loom behind radio to drop the voltage drop. Anything else I can do? The battery is bigger than needed. 540Cca and it got at least 100 cca so I'm thinking is there a weak ground. Radio needs ignition on to power up - switched live. Could red and yellow wires be wrong way around, but then radio would be on all time = flat battery on constant live. Also seen a little brown wire slightly frayed on neg battery terminal. It is used for control systems on car and provides clean voltage unlike earth points. Could that be to blame? Any ideas appreciated.
bmbmdmb started following Radio cutting out new starter motor
Timing stuck at 38
mate I'd love to but it's all I have. I've asked on forums and FB groups but not getting much back. I know AI is doing exactly what you're saying, but it's avenues to explore and rule out and that's better than nothing.
Timing stuck at 38
Id ditch the AI mate. It just makes stuff up that sounds like what you want to hear
is RHD hatchback looks like you talking about basic LED there is T73a/72 controling fog light (NSL) I swaped basic LED to full LED and there is T73a/25 LIN controling fog and reverse light how you can see on diagram T73a/72 is not connected
Upgrade oil cooler
That would be great Thanks Very much appreciated
Can anyone please advise me where I can get the 3 bolts that hold the throttle body actuator to the EGR valve as I do t know how but I have dropped them and cannot find them - urgently needed as getting a wee bit desperate Thanks in advance
Stevediggo started following Throttle body actuator
jora_zd91 joined the community
Wiper blades for 2022 Karoq
I've used Aerotwin for as long as I can remember on a variety of cars. I put a set on my '25 Karoq last week, as the originals had started dragging. They were more of a wrestle than previous vehicles, especially the nearside which needed tapping onto the arm. Never had that before but may be down to the stretch to reach that one when in the service position.
Rbz5416 started following Wiper blades for 2022 Karoq
2020 Technology Courtesy Light
Hello @milloo24 , Congratulations on your work with the retrofit! I have couple question regarding the actual behavior with both rear fog lamps steady on: Can you share a backup of adaptation on BCM unit? Is your car RHD? I'm working on finding out how to enable both on my car, which is a LHD vehicle. Based on the investigation I did so far it seems that this is a wiring harness tweak. Can you confirm you have connected both: T6y/5 and T6x/5 (NSL signal) to BCM: T73a/72? Thank you
You shouldn’t have to raise the bonnet, if you put the wipers into the service position you will get access to change them. Please see attached image
I can confirm those are the correct ones. I've fitted those to both a 2021 and 2024 Karoq. They can be a tight fit though...
@Bap33 just a note of caution, revving up a TDI until 15k RPM might bring other foreseeable troubles .... 😁😜 Doubt will arrive at 20-30s 🤪
My Car
Fabia Mk3 SE L 1.2 TSI 110 6 speed manual RED
