Skoda Scala 1.0 TSI 2023 - Stiff Gear Change
If fluid was low and disenaging clutch and re engaging helps with gear changes it might be a leaking master/slave cylinder or the seals on either are going and allowing fluid to pass them when engaging clutch so clutch isnt engaging fully. Monitor fluid level and check at base of Gearbox/engine join for signs of fluid. The master on my octavia failed but the fluid ended up on undertray. It could also be the gear linkages need lubricated as you said and also might be worth resetting cables. As its had a fluid change and no improvement I assume theres no air in clutch system. Alasdair
Alasdair1 started following Skoda Scala 1.0 TSI 2023 - Stiff Gear Change
Park Assist when stationary
Hi All, Something I find most frustrating is pulling up to any junction or stationery traffic the park assist screen insists on appearing and remains until I pull away. Annoying when you've got the nav running and somewhere new and need to see where you're going (I know you can see the high level in the dash but the wider view for me is preferred!). I've scoured all the options turning things on/off to see what changes but cannot find an appropriate option. Does anyone else have this and/or know how to resolve? Previous models/vehicles I'd only expect to see when engaging reverse. I've never used the optional parking assist (I didn't spec the car) but surely you can just hit the parking button to engage when required... Hoping someone can confirm this. Model is 2025 vrs Thanks
mork23 started following Park Assist when stationary
DGW started following DPF cracked?
- Yesterday
Fabrizio956 joined the community
Amundsen MIB2 Firmware Update
Carlinkit's adapters are very good. I am using it (mini ultra 3). It is almost as good as using it with cable. Most importanlty no delay while listening songs. Sometimes while playing songs it can glitch for 1 milisecond and after that it continues normally. Glitch happends rarely. If I was in your shoes I would first try with some better cable, like Samsung's original, if that doesn't help then I would continue with other methods. Good luck.
I had read that they were problematic but considering I'm only looking for android auto have gone for the latest Motorola one from Amazon. I like that it has a physical power button and fast switching between phones. Good suggestion.
Thanks @pab567 for such a quick response. Have a few follow up questions on procedure via pm thanks again.
DPF cracked?
My son has a 2013 Octavia 3 purchased from a dealer about 11 months ago. The dealer has proved deeply untrustworthy and has lied about many things. That’s another story. In spite of this the car has mostly performed ok. However, with MoT looming he’s mentioned again that the check engine light is on. Code is PO401, insufficient EGR flow. Car drives fine so I’m suspecting that the EGR filter in the LP circuit is blocked. This in turn likely means that the the DPF is cracked - a theory supported by the sooty tailpipe 🙁 We could clean or replace the filter pipe, which will probably keep the light off briefly (until it clogs again), but this is probably pointless as even if the MoT tester doesn’t spot the sooty tailpipe, the machine will spot excessive particulates? Anyone else travelled this way? I’m thinking aftermarket DPF replacement and a through washout of the filter pipe is the budget option. Looks like genuine parts exceed the value of the car even before fitting! Thanks Nick
VitesseEFI started following DPF cracked?
Wheel spacers?
I definitely type stuff filling in blanks in my head; then go back and re-read it and wonder how on earth I’ve let that go out the door.
Photography Thread
MargaretandRob joined the community
Incorrectly Identified NSL Speed Limits
I sometimes get this when on the A303 heading east coming to the Sparkford turnoff, it ' sees ' the 40MPH sign sometimes , especially if I'm in the overtaking lane ! I just carry on and reset the ACC and it recovers about a mile further on.
@red-ireland friend of mine had similar problem. Then he tried with higher quality cable and there was no more issues. Did you try using any carplay bluetooth adapter ? CarPlay requires a high-quality cable that supports both power and data transfer (at least USB 2.0 speeds of 480 Mbps). "Charge-only" cables will not work.
Suspension upgrade installed
Ride is great. No issues anymore with shocks and springs. B6 damptronics with Eibach pro kit. Racingline links and H&R bars front and rear. I have three sets of Lower front arms on the go at the minute. I’ve been trying different front bushes to stop them eventually making a slight noise when they dry out during the summer. I’ve tried pre fitted, I’ve worked my way through suoerpro, and powerflex. I’m starting with polish now. I have the blue fitted but it’s starting to emit the odd creak again. So I’ll pull them out and try going up to the orange. I’ve also tried all the others refitted with a range of grease from polybush specific to marine grease to no avail. Just the front now though. The front lower with the tts solid bush is quiet. Obviously for reference, it’s always rebuilt with new bolts and tightened on the ground along with setting the adjustable links again everytime. Otherwise the thing drives really well and still makes me chuckle evertime I use it. The rear bar and links were a great help as well to handling and cornering. Yellowstuff rear and blue stuff on the front with their floating discs. Needs tyres on the front, but I’ve PS5’s coming again hopefully next day or two.
- Moving over
iPhone 12, pixel 8a, oppo find x9 ultra. All of these phones came with USBC and the car is usba so not able to use original cable but most of my other cables are ugreen.
@red-ireland regarding your problem which phone do you have and are you using original cable for connecting to android auto/carplay?
Download link for MST2_EU_SK_ZR_P0480T sent in PM
I have a 2018 skoda octavia and Wondering if there is any update for my unit? @pab567 I have a problem where smartphone disconnect frequently from car play or android auto. Might just be a problem with usb port. Anyone have a doc or video on how to check for loose connection or replace the USB unit? I replaced the original battery less than 2 years ago and the latest one is not dead. I checked for parasitic draw but not found any. Wondering if mib intermittently causes the problem. Thanks Red
red-ireland started following Amundsen MIB2 Firmware Update
Sorry @UndertheRadar didn’t mean to exclude you from that question! Cheers for confirming. Think I need to review your project thread! Cheers @MarioVrs Eibach is a def! Alu subframes all round…?
- 01276 ABS Pump
Same thing happened to me intermittently and annoyingly on minor roads in North Yorkshire. I just pressed on regardless
vade04 started following Incorrectly Identified NSL Speed Limits
I fitted mine dry as well as per their instruction. Felt weird doing it, but no issues since.
rudolfo10 joined the community
- Owners manual
01276 ABS Pump
Yeah so it hummed for a few seconds but on my output tests using obdeleven, it hummed for a long time. I got the connector off, it was much easier than expected, no signs of corrosion. The cable was fine, I learnt that trick a bit late. I got a used pump from a breaker for 70e (including shipping). Got it changed at a garage, the job was very easy as you said, I could have done it on me own. Guy charged me 140 for the job including coding (not sure if that was even required, feel like he fleeced me there). All's well now, hopefully I don't see that error anymore!
- Owners manual
Tim started following Owners manual
Hi everyone. My son bought a 2023 Skoda Scala 1.0 TST Monte Carlo back in April. It's a beautifiul car. Early in the summer (on one of the days it was 35C) he said that it wouldn't go into gear after having it parked all day, although after a bit of trying it was fine. This didn't happen again until last month when the same issue occured. Over the last few weeks he says it's been happening more often, although it is still only intermittent. As there was no record of the car having it's brake fluid changed at 3 years he had this done at our local garage yesterday, along with the clutch fluid as we know it's shared. The garage said the fluid was low, and now that's all done. He was hopeful that that was the problem sorted but it happened again this afternoon. This time I was able to get into the car and feel it for myself. The gear change felt stiff and required more of a push than usual to get it into gear. Lifting and then reengaging the clutch resolves the issue. A quick search on the web suggests lubricating the linkages in the engine bay with lithium grease - that looks easily doable and worth a go, but I'd appreciate any other thoughts or suggestions. Car has 23,000 miles, full service history - and is no longer under warranty from the garage we bought it from (of course!) Thanks in advance for any advice.
dunder101 started following Skoda Scala 1.0 TSI 2023 - Stiff Gear Change
Skoda Superb Alloy Wheels 18 inch from 2013 Superb Elegance Mk2. Set of four. Plus steel spare.
Hello, I am interested. Please send me your number, and I will get in touch.
