ogzclp0098 joined the community
Just returned from a 2,000 mile loop to Prague and back. Spent £158 on a full tank of petrol in Germany, £102 for the same amount in the Czech Republic. So, move to Prague! MOT/service on Wednesday. Picked up a small crack in the windscreen - wondering if it's enough to fail me...
OBDeleven/VCDS default values for front left fog light
I was playing around with OBD11 a bit too much, now I get a persistent dash warning for the front left foglight and the code B121F15 in obdeleven. Under Module 09 adaptations, for channel Leuchte12NL LB45 (front left fog light) I set Lichtfunktion B 12 = Abblendlicht links. This caused the front left fog light to always be on with the low beam, the moment I disabled it the error started showing up. I suspect that changing that adaptation also changed Lampendefektbitposition and Fehlerort mittleres Byte DTC-DFCC. Could anyone with a facelift model with the LED fog lights and Matrix headlights be kind enough to share their values Alternatively, I'm also not opposed to just disabling that check if possible.
Pudnig started following OBDeleven/VCDS default values for front left fog light
Round trip Calais to Prague - any tips?
Thanks for the tips. We have completed our trip, without mishap. We stopped for two nights in Koblenz before continuing on to Prague. Both nice towns. Took a boat trip and a ride up to the fort overlooking Koblenz. Ate bratwurst and sauerkraut. Germans do nice soup and potato salad. Regarding fuel: wow. Buy your fuel in the Czech Republic, not France or Germany. I spent £158 on the A3 Rohrbrunn, and £105 for the same amount of fuel in Czechia. Mind, I paid £82 for 47 ltr. in Catford.
A VW Group Global Recall 2026.
That'll be my 2023 SEAT Ateca going in then. Sit down with a courtesy cuppa and a pastry for an hour and catch up on some reading and pay nothing and leave with some peace of mind it's sorted.
Can't see why they'd say left hand drive if it wasn't specific to them.
Autodoc - avoid!!!
Mistakes happen everywhere. What really matters is how they deal with them. If contacting support doesn’t get you anywhere, I’d try sending a formal complaint through their official channels, with your order number and a clear explanation of what went wrong.
Dave1987 started following Autodoc - avoid!!!
Can’t select drive. Only M
But the Dealership has never touched the DSG while servicing, or have they? Did they con you into having it done? Hopefully not the MCU, but I fear it will be and not just the shifter.
Octavia 3 RS FL 2.0 TSI CHHA 169 kW – Loud rattling/ticking noise at idle
Hi everyone, I'd like to ask for some advice regarding an engine noise on my Škoda Octavia III RS Facelift with the 2.0 TSI CHHA engine producing 169 kW. Vehicle details: Model: Škoda Octavia III RS Facelift Engine: 2.0 TSI CHHA, 169 kW Gearbox: 6-speed DSG DQ250 Current mileage: approximately 70,000 km (43,500 miles) Engine: completely stock, no ECU remap or software modifications Description of the issue: There is a noticeable ticking/rattling noise coming from the engine at idle. As soon as I slightly increase the engine RPM, the noise disappears or becomes inaudible. It may return when the engine drops back to idle. The noise is intermittent. Sometimes the engine idles relatively quietly, while at other times the rattling is quite noticeable. I've been noticing this noise since approximately 30,000 km (18,600 miles). It is therefore not something that has only started recently. I've also noticed a similar noise on other Octavia III RS models with the 2.0 TSI 169 kW engine, but it was nowhere near as loud or noticeable as it is on my car. On mine, the rattling is considerably more pronounced. I've already ruled out the wastegate actuator, as this is not the source of the noise. I'm attaching a recording of the engine idling. Would anyone be able to identify what might be causing this noise based on the recording? Has anyone experienced anything similar with the CHHA engine? Any advice or personal experience would be greatly appreciated. Thanks in advance! 20250417_154942.wmv
Cheers... I thought that was just initial info with more to come but maybe that's it??
Rear half of the car without electricity/communication... ?
No it is not.
Is the car an ex-response car? Ambulance, Police, Fire, Paramedic ...
2025 Superb MK 4 L & K 1.5 TSI Hybrid. Space saving spare wheel and fitting kit.
I have for sale an 18" space saving spare wheel and fitting kit for a 2025 Mk. 4 Superb L & K 1.5TSI DSG Hybrid. It was bought new along with the car. Offers around the £100 mark. Collection only. It has never been used. It was bought specifically for the car mentioned and I can offer no guarantee that it will fit other Skoda models. I do know for fact that this will NOT fit an Octavia Sportline.
MikeTheThinker started following Rear half of the car without electricity/communication... ?
Troter joined the community
Have you seen that formally confirmed yet... I've seen it mentioned in reports but nothing definitive and I'd find it strange if that were the case given LHD and RHD are produced on the same line and likely use the same bolts
Skoda App maps not sending routes to car
Unaware of this thread, in May 2025 I started a thread in the Karoq sub-forum. I have now resurrected that thread as I am again having issues with Send Route and so is another forum member.
Felicia's have blower motor relays?
Hi guys, When adjusting my blower motor speed I only have 2 out of the 3 blower speeds, when I turn the dial what I get is at: - 0, the blowers off 1, what seems to be speed 2 2, speed 2 3, speed 3 So it’s not drastic but I would like to have speed 1 just blowing lightly. Do I need to replace a resistor (is there one?) if so where is it and which one if not is it a motor or switch issue? Regards Rob
Rsedmonds started following Felicia's have blower motor relays?
Changing the key fob transponder. 2026 Octavia Sportline.
Does any one know if it is possible to replace the transponder in a 2025 key fob. I have 2 Skoda Superb key fobs from a 2025 model. Is it possible to fit a new transponder to these to enable all functions of a key fob for s Skoda Octavia Sportline 2026 model?
YMe started following Changing the key fob transponder. 2026 Octavia Sportline.
It’s a DQ200 7 speed dry clutch. Not under warranty. Always dealer serviced, last done on October 1. It’s only done 21000 miles.
Pickup towbar - where to find - see pictures!
Hi So, I have a customer with two pickups. One has towbar and he wants to mount towbar on the other as well. How ever - he does NOT want to remove the rear muffler. The towbar I can find does not look like the one thats mounted on his other pickup. It looks like this: Right side attachment to van: Left side attachment to van:
Orchid70 started following Pickup towbar - where to find - see pictures!
Tips to remove consol bush bolt on front swing arm. Very stiff been at it for hours.
Cheers Pete will give it another go tomorrow once hand and back have recovered I hope. Seem to be getting a little bit more on each attempt or it could be my imagination. Found a console bracket from energised customs for around £40 but not sure of quality. Might try and crack console bolts to chassis to see. If they are easy I will get the grinder out and cut the old bolt bush . The bolt thats come out 1/4 way looks shiny and isnt seized in buh so I can only assume its alloy oxide as you pointed out. Will clean up the oil slick under car due to the amount of penetrating mixtures and and give my map gas torch a go with my trusty big CO2 extinguisher at hand. Alloy and steel should never be used together on cars!! Managed to get a bit of hose into open threaded hole. raised it up and filled with oil/white spirit to soak in overnight. Alasdair
Radio clock Problem 0:00
- Can’t select drive. Only M
Shows as a 2018 1.5 TSI ACT in profile. So DQ200. & Karoq,s never got the DQ250 6 speed, they got DQ381 7 speed wets.Evolution13 started following Can’t select drive. Only M- Rear half of the car without electricity/communication... ?
( 2013 ) Skoda Octavia 2.0 TDI SCOUT with 6-speed manual transmission. My friend's car suddenly had a major electrical fault. Suddenly—and without any prior issues—there is no power to the entire rear section of the car, along with a few other likely related faults. No tail lights. No brake lights. No turn signals. No reverse lights. No license plate light. The tailgate lock solenoid remains in the closed position. The engine doesn't stop when the key is turned to the OFF position, instead it keeps running perfectly. If the key is removed from the OFF position, the entire dashboard starts flashing frantically yet the engine keeps running—though now very, very poorly and unevenly.. I’ve attached a VCDS fault code scan I performed. ...Can anyone draw any conclusions from it ? 🤔 Has anyone experienced a similar electrical fault on an Octavia-II ? 🤔 - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - EDIT 🤔 For some reason unknown to me, I cannot upload the VCDS fault code reading 🤔- A VW Group Global Recall 2026.
^^^One less recall or service campaign that might concern those with VW Group vehicles with the steering wheel on the correct side. Just those with the wheel on the wrong side to see if their vehicle is part of the Global Recall.- Can’t select drive. Only M
Ive just replied to your post on the Facebook Group. Now I see it a dry clutch DQ20, so my comment about DQ250 is no applicable, if you have TSR and ACC is this a 2024 or later car - in which case take it to the dealer, its still under warranty, still has roadside assistance. - Can’t select drive. Only M
