Warrior193
Joined
Last visited
Currently
Viewing Topic: Škoda Approved Used – should outstanding scheduled maintenance have been completed before sale?
Can Parking assists cause transmission system (manual) malfunction?
Reverse gear on a M6 gearbox is left from neutral, through the gate stop, then forward (same direction as 1st gear position) therefore is possible that OP is pressing down on stick and actually selecting reverse instead of first. Or the reverse gate stop is faulty and is allowing stick to be pushed straight across into reverse gate without first having to press down on stick. Suggest selecting all gears in turn to check that reverse gate stop functions correctly.
Head unit upgraded but no audio.
Hello, I believe these infotainment units have component protection - which means they cannot be used in a different vehicle without them being unlocked, was this done?
Boot light problem
Flyback diode was the term I couldn't recall when I first responded to your message. Perhaps it's there to limit ripple.
Key in Water for 24 hours
Suggest giving it another wash out in pure alcohol after removing battery, then gently dry.
Boot light problem
Are you sure it's a diode? That arrangement may be to slightly reduce the voltage to the lamp using the forward voltage - these are more often seen on a coil connection to prevent inductive surge on de-energising. Are you able to test for continuity in either direction?
Octavia Mk3 VRS TDI Oil leak problem
Is this oil leakage from the camshaft cover gasket - or the cylinder head gasket?
Power Mirror Retrofit
It would be fairly reasonable to think that it would be cheaper to have a level of commonality in components like wiring looms, so it is possible that wiring is already in place - although I have seen references for having to run cabling for retro-fitted reversing cameras, so may not always be the case.
odd rear middle seat backrest shape
That looks like space for the LH hinge of the ski hatch.
Combi Boot Release
Is your Superb KESSY, or does it use a standard 3-button remote fob? If 3-button fob, does the handle release the tailgate when that button is pressed?
Combi Boot Release
On the assumption that the Superb tailgate operation is similar to the Octavia, yes the handle should release it when vehicle is unlocked.
14" steel wheel = seat Ibiza or a golf
If the Ibiza or Golf are similar years to the Octavia, pretty sure to be same.
Did I Locked My Keys In The Car!?
If this is for the manual key-fob type, the car should not automatically lock after approx. 40 seconds if any of the doors (or tailgate) have been opened - not sure about KESSY.
Normal startup noise 2016 EA888 2.0 Video included
That sounds pretty 'rattly' to me for a TSI. What is the mileage, Is there any record of timing chain and tensioner replacement?
Good morning Ewan, probably will but it depends on the bolt PCD and the centre bore size - there are two sizes.
Air con not engaging
I see that there is a reference to rating of 12 volts - is there an electrical connector on the compressor? If there is, it will be supply for clutch or solenoid valve feed - check that this is being fed when A/C engaged.
Help, Kamiq oil temperature 140C !
Unless the oil level sensor is a dual one, which I think may be unlikely, that may not resolve the issue. I'd have thought a temperature sensor would be positioned lower down than a level sensor.
Does your AC system have a clutch on the drive pulley?
Fabia III 1.4 TDI (CUSB) cranks but won't start
One question on the parts list (+ cambelt) - isn't the HPFP driven directly off the camshaft?
Headlight ballast needs replacing
Behind the dial on the dash as far as I know - it's the body of the switch. I believe I have seen reference to removal for checking being fairly easy, not done it myself though.
Your new fault sounds as if you have a faulty switch module.
Fabia 3 Electric windows
Not available on SWMBOs Mk3 SE-L Fabia either, ignition needs to be on.
EPC indicating turbo underboost
I believe that EFB and AGM charging regimes are pretty similar - My Ring smart charger has two settings only - regular lead-acid and EFB/AGM.
Oil Sensor - please visit workshop warning light.
Have you used that method successfully?
Quietest Karoq?
Provided they do the job well, I wouldn't worry about how the tread pattern looks. Go for function over looks.
I'd suggest getting the oil temperature sensor tested ASAP - if that reading is correct, be aware that synthetic oil can start breaking down above 135 C.
