Past hour
Tyres and punctures
Hi, Self seal means that You do not have to reipair the tyre. Hoewvet, you still should remove the screw. I had such dituation and the screw was jyst simply removed. Then the tyre was pumped to higher pressure for few minutes an that was it. I have driven after that for 6 motnths and paid attention to pressure - there was no drop in the pressure at all. So it works. Regarding repairibg such tyre - yes it can be repaired. However, it is work and time consuming as they have to remove the sealant. As long as it is just small puncture - repair makes no sense as the self seal feature works ok.
ufwojcie started following Tyres and punctures
1.5TSI Axial bearing (2018 car)
https://www.webuyanycar.com/?glbtrd_src_ind=wtxv-GDWlE-GZf8_oNVxXw%2F&utm_source=google&utm_medium=cpc&utm_campaign=Brand%20-%20London&utm_id=16880063734&utm_source_platform=Google%20Ads&utm_term=we%20buy%20any%20car&utm_content=Phrase&gclsrc=aw.ds&gad_source=1&gad_campaignid=16880063734&gbraid=0AAAAAD-VJQY5QLJFybJ9F7WumJmOZ80Bf&gclid=EAIaIQobChMIruakqNmZmAMVKpJQBh3BBh5SEAAYASAAEgKwS_D_BwE
Rear springs...replace?
Hi All, New here so apologies if I have missed something or am posting in the wrong place. I have read the previous posts on this thread as I have a MK2 2015 Superb Estate with a saggy rear...... Ironically I am also moving to France next year so judging by the previous posts I should certainly sort this before moving! To get through the recent MOT my car had the following replaced: Nearside rear suspension arm (left) Offside rear suspension arm (right) Nearside front anti-roll bar drop link (left) Offside front anti-roll bar drop link (right) I have always had issues with the odd speed bump scrape, especially if a tyre or two has lost any pressure, but this summer holiday trip with luggage, dog and towbar mounted bike rack was too much for it. Rear was very low and towbar was regularly making contact with bumps etc. Since those parts being fitted the problem seems to have reduced, which surprised me a little as i assumed I most likely needed new coils, uprated coils, or auxillary coils? I'm keen to solve this problem as I am intending on keeping this car and running it into the ground, I also need to spend a small fortune getting the clutch and DMF replaced which is going to painfully expensive too! Any tips on: Which coils to fit/how i check compatibility. Can this be a DIY job (what tools req'd?), or is it garage only? Any help much appreciated! Ross
RossKetz started following Rear springs...replace?
Start Stop Stall
Alternatively you can code start stop not to activate or install a control module that prevents it from activating too
Chain, tensioner and guide replacement
And ROM. Cheers.
Start Stop Stall
For recoding you can do this easily as a diy job using an app called carscanner and an obd dongle for about £30.
Binx1310 started following Start Stop Stall
Heron91 joined the community
Servicing my serpentine/auxiliary belt, what brands should I get? (CGPA)
Buy from skoda-parts.com is the right way to go never had any problems with the parts or service contitech belts are the OEM prodùcer for Skoda and INA tensioner are OEM If you can freely spin the tensioner òr the idler pulley they need replacing as there should be slightly difficult to spin
campaign
Thank you for the reply mumpsim. That is all as clear as mud. I can't see many average owner making use of that feature
Thank you Alasdair. Will call Kennys Monday for a quote. Graham.
lui19 joined the community
Restarting when warm after stop start activated
I have pretty much the same issue, from another post I have the impression changing the battery should solve it. I've bought a 2017 TSI around 18 months ago but no idea of battery age. I'm now slightly concerned your stop/start issue has returned with the battery reported in good condition. I'll keep looking for answers on the forum, so far I understood it was an issue caused by a failing battery (AI search also suggested this), your experience is making me wonder if there's anything else causing issues.
Start Stop Stall
Hello, I'm new to Briskoda and I'm having the same issue, stop/start doesn't operate at all until I have driven for quite some miles, operates normally then suddenly after stop/start driving the engine stalls when the system tries to restart the engine. The central info screen says restart manually but takes several attempts to get engine to run. Even attempting to rev it doesn't appear to help, it just brings up a comment on the info screen that I'm wasting fuel! From the sound of your postings, I need to replace the battery and have the system recoded. Thanks, your post and the replies are exactly what I have been searching for.
Today
[Octavia vRS 245 - 2019] Constant whistling noise under the rear seat when warm — Fuel pump?
I'll also add that the whisling noise doesn't change whether the tank is full or empty, same when the fuel tank cap is closed or open.
Sold my 2016 Octavia 1.8TSI L&K hatch
I'd like to echo Pete's comment. Hope you're going to stay for the chat 👍
Battery light 1.0 mpi 59bhp
No ACC
Chalmers garage inverness havent used them for years but heard there still pretty good. You could also try ROM garage walker road just along from them for another quote. My old mechanic garage owner Robert brown when he retired put his customers there as he reckond they were good. Did my MOT a few weeks ago and very helpful old school garage. Another to try is Kennys autos on seafield road. They are vw/skoda specialists and have a good rep. Alasdair
Alasdair1 started following Chain, tensioner and guide replacement
Octavia Mk1 1U5 2004 - N/S/F wing required - ideally Diamond Silver Metallic (Code 9102)
Thanks. That's very useful. Cheers.
Anyone had success requesting a key code to get spare key cut?
misunderstood; that no longer exists
JFH joined the community
KedarCZ joined the community
Phone symbols on infotainment screen.
What follows is the result of a AI Overview based on a GOOGLE image-search using the image in this topic's original enquiry. The Volkswagen T-Roc Forum and Skoda Kamiq Forum references come from these links https://www.trocforums.co.uk/threads/number-indicator-at-top-of-infotainment-screen.3387/?utm_source=google&utm_medium=organic https://www.kamiqforums.co.uk/viewtopic.php?t=149 (As my religion prohibits me from using a smartphone in a car, I've no idea if the above information is correct.)
- Skoda fabia starting issue
5Q0 612 041 BM Brake booster vacuum hose with a non-return (check) valve and pressure sensor
Our Karoq 1.5l petrol 2018 60000 miles went for a service this week. The report said "Vacuum hose off inlet manifold has damage to connector and will not clip into place. Advise this is replaced". Car seemed to drive as per normal with this 'failed' part after service The part has now been replaced - separate visit - part details off the bag are "5Q0 612 041 BM Brake booster vacuum hose with a non-return (check and pressure sensor". So I am wondering how often this part fails and requires replacement? Perhaps this connection tab suffered from plastic ageing? Does this part require disconnection as part of a normal service which included the spark plugs so the plastic top engine cover has to come off, etc.? Photos below/attached: old part on the drive which shows is wiggly shape - yellow arrow indicating failed connector offside of engine bay with hose identified in red nearside of engine bay with hose identified in red. Yellow arrow indicates failed connector failed connector, shown with red line - the 'push' tab seems to have broken and is missing non failed connector with green showing the bit of the tab that has come off
That's the bit i'm after - the 4 digit code for the key blade - if it's stored somewhere I must be able to request it right?
Good luck Dave, hope you'll not disappear completely from here. 🙂
After 27 years of Audi/Skoda ownership I've deserted to Toyota and a new RAV4 GR Sport.
Latest info looks like this one "1.0l petrol engine with start/stop system , DKLD,DKRC,(7L6) From November 2019" Only difference is in cars with adaptive cruise control where the green/yellow wire goes somewhere else: * For models with no adaptive cruise control (ACC) *2 For models with adaptive cruise control (ACC) Not totally clear to me whether that extra connection is instead of the one to the BCM or as well as; the former I think. J533 defined as - J533 Data bus diagnostic interface. Does your car have ACC?
Put octavia mk1 breaking into ebay and came up with a few. Not sure on 9102 colour but theres a 1.8 vrs on there with what looks like good passenger wing in silver https://www.ebay.co.uk/itm/116190808688?_skw=skoda+octavia+mk1+breaking&itmmeta=01M7ZE485CMYGCK3NGT778AVY9&hash=item1b0d830a70:g:~yMAAOSwLppmTc24&itmprp=enc%3AAQALAAABACHNgUiiE%2FjQhlDTaMiAde%2FME5jbBWz7MU%2BzjpBQSDwKFqcEKz7KvJMpF4w9SKFTcEy4enazCzUrEgrcOScYP9nyuI9O2hv3O57u%2FF5%2BswkaCzE2DbYLDfxt5c9LZ6GZUU%2Bciz2Ax88hX430uJ9u24F6zSAFq8bkuqsFP9vi7GspmWU7w7xiRQnuiEf0SJv%2BrEzSdv7QQgxZqm%2BTZ0RFSzLOHq6ntsIXDR9GDVPfa3fUqKLcGHRdBtY8ZK0OLrdyI1R%2FdYz1mszXTqQnKh6d5Y6s0zq7qXTisizMqAuCSwBPku%2FKVP4Vk8I5g33mzkeqGhCgcTmQ3TEh4j5hSJJBiv4%3D%7Ctkp%3ABk9SR4SDke6_aA A few others but nothing in silver. Alasdair
