  2. I have had the fluid changed twice. Just not this time. Agreed I will look for a specialist. The dealer will probably just change the MCU or gearbox or both!
  3. Any new firmware for my Swing? IMG_0349.HEIC
  4. hihitavec joined the community
  5. Today
  6. Morning all wise people. Dilemma time. Been running a 2015 L&K 2.0 estate superb for coming on 2 years. Got as a stop gap but love the car and has been brilliant so kept it. It’s now done 280k miles but is virtually perfect …apart from DMF starting to go. Do we think it would be pointless to change the DMF and clutch only for something else to go in another 10k miles. Local garage who is use for other cars has quoted about £1200. Alternatively I’ve seen a kit with clutch for around £400 with a discount. Is it insane to try and do this on the drive? Other alternative if can get the kit cheaply is anyone likely to fit a f and clutch kit I’ve purchased ? Thanks for any advise in advance!
  7. dxbajf started following Advice please on DMF
  8. Did you try it in S? No way would I go to a Skoda Dealer with a DSG issue. An Automatic Gearbox Specialist is what is needed. And one that does DSG,s. & Brake fluid does need changed sometime in 8 years especially with low miles. I hope it had been done at some point.
  9. Turns out I have an aftermarket rocker cover on my car so I will end up replacing the whole cover to see if that helps. The PCV I took out was different to the OEM one and the rubber didnt feel great, it was quite stiff but was intact to hard to say if that is part of the issue or not.
  10. @Toothache it's still working fine 🤞🏻 probably done 6k miles on it, varied mileage, as far as calibration, I just cleared the faults with OBD11. It's since been serviced/MOT'd at my trusted garage - no issues. The hardest part is access especially if you have fists of ham and thumbs of butter like me.
  11. Can I ask - I'm on 0276 and I have the daily "update" message that apparently needs a FW update to be carried out. Reading this thread, it seems that if I update it manually, some other things will break and I can't fix them? Is that correct, or is there a full fix now? Thanks.
  12. Long Story short, it was just the app N7 Player.
  13. Thank you for the feedback. I would also like to add that MEN2_EU_VWGPx_P0180L on a VW Polo 2021 is also not working.
  14. just to confirm not working on MEN2_EU_VWGPx_P9200L Tiguan 2019 Regards
  15. It wasn't before I uprated it. Back to the drawing board, as I still feel something isn't working correctly
  16. The box has never been serviced. I don’t think I’ve ever been asked. I refused the brake fluid and aircon clean this time. I’m really puzzled. I’d like to find out what the problem is before I send it to the dealer.
  17. The recommended plugs are Champion CH700 but are there other preferences used by owners please?
  18. FlyByMe started following Suitable glow plugs
  19. Funny enough, ours has been behaving itself for the last year or so, but it's just started playing up again this last week!
  20. It's 1.9D, right? Those use different heating from Favorit, so I'm not familiar with it. But you should be able to locate the resistor pack in the engine bay, following wires from the motor. There are two bimetal contacts that appear to short the resistors if they overheat. It's possible that the one for 1st speed got stuck.
  21. Hi lee, no maps on screen, mph as numbers and a rev counter plus additional vehicle information you can select.
  22. Hi Derek. Thanks for the videos and information really helpful. I test drove the car yesterday it has the Digital cockpit which displays speed as number's and a rev counter above in a line or circular around mph number which works well, i pick the car up monday. Regards robsie
  23. This 2022 Fabia-related video may also be of interest as it shows a variety of different Virtual Cockpit displays.
  24. OK, no worries. Thanks for responding 👍
  25. Unfortunately I don't have it, 0359 is the most current firmware I have
  26. It’s better but still not great, changing the PCV today to see if that helps.
  27. Hi Pab567, Google has brought me here to you. Are you able to help me getting the software upgrade MST2_EU_SK_PQ_P0369T for my 2017 Yeti radio please?
  28. Any update on the oil consumption Sharpy?
  29. Anyone solved this yet? The noise is very irritating and the passenger door is doing it now as well.
  30. A perfect outcome. Well done. Well worth the prep and planning involved.
