Finding an Internal drivers door door opener for a Skoda Superb Elegance 2005 in the Uk or beyond!
Just make sure you order the correct one for the drivers door. Have had a few bits and pieces and so far so good. I tend to use a bank account I hardly use for payment just in case. Alasdair
Head Gasket?
Garage has done compression test and block test and said oil cooler luckily
alexsuperb14 joined the community
Skoda approved purchase, but only had one key. Full refund?
I think that was the opportunity to reject the vehicle, or at least get it recorded in the paperwork that they would either forward it on when found or get you another. Once you have accepted one key it is difficult to complain, unless there is something wrong with the car.
Stonekeeper started following Skoda approved purchase, but only had one key. Full refund?
Sagittarius 19" alloy cover loose and fell or theft?
I realise 4wd versions use 45s but do you need to tell your insurance company of the change?
Head Gasket?
Certainly sounds like the head gasket, if you want to be sure you could try a cheap borescope and get the plugs out and see if any of the cylinders are wet, or look like they've been steam cleaned!
chrisund123 started following Head Gasket?
A4 sideskirts on Octavia
Yes, you've missed reading the first post, I only asked if anyone has done it?! 👍
waze through bluetooth
Is your phone on silent? I’ve found that things like satnav announcements won’t come through if phone on silent.
BloodWorm started following waze through bluetooth
AVucic joined the community
No cooling on back seat
MY17 Superb here - as already mentioned above, heating only available for the rear seats. only front seats get heating and cooling.
BlackMagicOcti joined the community
The A4 is longer - it’s only a bit longer than the Octavia in total length, but the wheelbase is a good 10cm longer. All of this aside, am I missing something? Why are we trying to fit OEM A4 sideskirts to a Skoda Octavia? There are options out there that are designed to fit the car. Sure, you can do it, but if you try hard enough, you can also fit 22” 11J Vossen wheels while you’re at it.
That's an excellent call Alasdair. I'd forgotten that so much is available from China. They produced a car that was a concoction of some VW group parts and used a long wheelbase body that was very similar to the Skoda Superb Mk1, hence a good source of parts at competitive prices.
What he said ^ You accepted the terms at the point of sale. I’m not saying you don’t have an argument, but I highly, highly doubt they’re going to take the car back because of a missing key. Have you contacted them? That’s probably what I would do. It’s easier for them to sort a problem when they know they have one to fix.
OccyVRS started following Skoda approved purchase, but only had one key. Full refund?
- Yesterday
Very high bite point on Skoda Fabia 2 2011 estate 1.2 tsi (CBZA) 5 speed manual
and flooring it* Also heard that I won't be able to feel the difference in wear based on the travel distance since it's a hydraulic, does this track?
A problem could arise if the contract was signed accepting one key only as part of the sale.
Warrior193 started following Skoda approved purchase, but only had one key. Full refund?
Superbsport started following Skoda Connect services
Hi all, I'm currently in France and since arriving from the UK my connect services haven't worked. They've always worked before in France. I've tried resetting the infotainment system and I have a connection to the emergency call button (green light is on). However, Skoda connect says no data connection. Anybody else had this issues and any fixes? Car is a 2018 Superb Sportline with 9.2 Columbus system. Thanks in advance for any help.
What to look for when buying
Brill thanks! I'm just wondering if I can manage without the adapters and just screw the fronts to the existing trim as the adapters aren't on autodoc but might be on LLLParts...
I am going to upsize to 45s. ODBeleven can alter the speedo correction after fitment of the 45s so under or over reading is no longer a problem
Hello, I'm looking for advice concerning a used car that's being sold from a dealership, the car has 66000km and has followed every service with one owner. The timing chain is stretched, but they will replace it with an upgraded one before delivery at my request, but I noticed that the clutch bite point was very high during my test drive, is this normal? I own an automatic Fabia from the same generation, so I'm not not familiar with the manual clutches. As of now the clutch engages the gear at about 75-90% disengagement (when I let out the pedal), which feels a lot like a worn out clutch from a previous vehicle I've driven. I did try putting the car in high gear during a slight hill with low speed (40km/h and 4th gear, don't know if this is aggressive enough) without any increased RPM and a normal slow acceleration. I also tried putting the handbrake on and keeping the engine at 2k rpm, then slowly releasing the clutch to see when it stalled, it took a long time, but stalled around 80-90% disengagement. Appreciate any and all advice, the contract for the car needs to be signed tomorrow to keep my reservation 😅
Yes Lee. Heating and only on the outer seats too. They’ve never produced a Superb with cooled rear seats as there’s no gap under the seat base to fit the fans or to allow the disposal of the air. The system draws the air through and thereby away from the seat base rather than blowing it through, which what the wife’s Kona EV does.
Mattridd started following Fabia Mk2 Greenline replacement front springs
Hello, I have a Fabia Mk2 Greenline estate (1.4 tdi 80hp) & need to replace my front suspension. But I am struggling to find out what springs I need to buy (will replace them while I am in there). My local GSF asked if my car was lowered, no was my obvious answer, but she said it was to a degree, being the Greenline. I have brought some Monroe shocks (16451) & top mount (with bearing), but am having issues with finding a replacement spring. I have been told that the OE part number is 6Q0 411 105 AE. The existing spring has 3 red & 1 green colour markings on it. This is my first time doing any work on my car (did change the drum shoes & cylinders last week) & have never had a need to look for any car parts before. Is anybody able to help me or point me in the right direction of the new springs to buy. Thanks, Matt
The Wife's Roomster (Fintin)
This is a long one, so pop the kettle on and grab the bickys. Fintin is my wife's Roomster, a nippy 2013 1.2 TDI Scout. Now for someone who says they love their car, you'd think they take better care of it. My wife treats Fintin like he's some sort of rally car. The car was grand mechanically and visually up until a Van drove up the backside of it last year. The driver accepted responsibility and said they'd get it fixed but handed it back with problems that were none existent before. Now, yes she could have listened to me and gone through the Insurance, car would've be written off and she'd be driving a different Skoda based car or gone back to the chaps who "fixed" it or even gone to a different mechanic and billed the Van Courier Company Owner but that would intail actually listening to her Husband. So here's were I get to step in, an amateur mechanic at best, I know only what I need to know to get by and save myself a few shillings. She starts by telling me the coolant and oil in the car are low and that Google says it's because of the hot weather......, I'm thinking head gaskets done but there was hope, no milk in the engine or expansion tank, maybe a cracked hose somewhere but no leakage found. I check the dipstick, it's clean, not even a mm of the black stuff, I grab a litre of oil from the local garage and pop it in, 20mins later i do a dipstick test again, it's above the max, now im scratching my head becauseit has a 4.3ltr oil capacity not a 1tr capacity. I do an oil change along with the oil filter and top up the coolant. I'll check it again in a few days. Next, the rear arch trim is hanging off, whatever adhesive that was used (after the crash) to glue it to the car has quit. Most likely the wrong adhesive mixed with the shape of the arch being off after a bad panel beating. I realise in order to fix it, I need to remove the inner wheel arch liner, tyre off, what do I see, she has worn the brake pads down to the bare metal....., I ask her does she hear the brakes squealing at all and she says 'sure i play the radio when im driving'..... new pads and discs ordered (Saturday job). I remove the old adhesive, grind the backside of the trim to fit the shape of the fender/arch, grab a tough outdoor adhesive, a C clamp and bingo bongo (left overnight) it's fixed to the car. Next up, the rear door that was replaced and resprayed the wrong colour, appears to be from a 2007 model along with the rear bumper, paint ordered for respray but not before it's all sanded (don't know when I'll get round to that). Wiper arm and nozzle replaced because she wanted them replaced and had ordered them from Shein, she can now use the rear spray. Rear door rattles, no bump stop on right side, currently searching online for replacement, skoda fabia has similar ones. Next, before the crash, the car had 4 black painted OEM alloys, when the car was returned, 3 alloys are silver and one is black. She wants them all black again, i spray paint the black one silver 😆 job done. Next, I noticed the plasti dip job she asked for on the exterior trim 3yrs ago is peeling, so I remove one side, easy enough, with a bit of white spirit, I go to the other side of the car, it does nothing, im confused and ask her if she did anything, yes, she saw it peeling and spray painted it black.... 3hrs later, high as a kite on paint stripper, job done, 2 days later, I still have paint embedded in my hands. Another job for later is to fill in the deep scratches in the front bumper and respray to a colour matched perfection. Well thats my rant over, im not one for taking pics of before and afters so yas will just have to use your imaginations.
Robertanthonyhpm started following The Wife's Roomster (Fintin)
Anyone Got Part Number Access Based on VIN?
Have done. Thank you muchly.
Great thank you 👍🏻
I'm assuming you think I'm refering to vehicle length ?.....I'm not. Below is what I googled.👍 The wheelbase of a 2018 Skoda Octavia is 2,686 mm (2.686 meters or about 105.7 inches). This measurement is identical for both the hatchback (liftback) and estate (wagon) variants built on the Volkswagen Group's MQB platform. The 2018 Audi A4 has a wheelbase of 111 inches (2,820 mm). This measurement applies uniformly across the standard B9 sedan and Avant (station wagon) configurations.
What he said. Also, instead of doing a bodge, what's wrong with Maxton or Reiger?
OccyVRS started following A4 sideskirts on Octavia
Timing of transition/implementation of the EU driver assist regs for different Skoda models
Ah that’s annoying. This is the kodiaq one from the same brand as I used: https://a.aliexpress.com/_EQe9mI6
