  2. This 1-year-old topic may be of interest https://www.briskoda.net/forums/topic/536354-wipers-very-noisy/#comment-5981475
  3. Today
  4. the first few posts on this thread lists nearly all of them
  5. Hello, I’d like to bring up an old thread of mine again. Does anyone have any ideas regarding my issue? It seems that the authorized service center doesn't even know what to do or suggest—according to them, everything is fine. The sound in the link occurs almost every morning, or during the day after the car has been sitting for a while. Lately, it has also been happening after long drives. The sound appears when the car is rolling in 'D' (Drive) gear, or when starting to move in 'D' without pressing the accelerator pedal. As soon as the car comes to a stop, the sound disappears. They replaced the belt tensioner this week, but it didn't help. Also, besides this sound, there is some jerking when accelerating. Thanks for your thoughts. https://youtube.com/shorts/4iBDhxFsDdc?feature=shared
  6. Crikey are the OE front wiper blades this noisy on all Fabia’s?
  7. Lee01 replied to Lee01's topic in Motoring News
    Skoda 3D printable accessories https://www.skoda-storyboard.com/en/skoda-world/printly-clever-custom-accessories-you-can-3d-print-yourselves/ 'The world beneath the upholstery' https://www.skoda-storyboard.com/en/skoda-world/the-world-beneath-the-upholstery/
  8. Should I perform an update for the software, or should I continue using it as is?
  9. Is there an explanatory video?
  10. Firmware 0480 Only Install when the unit is patched, you need modify Meta File and Audio Channel Change Side, After Update left is right
  11. There’s a full list of bulbs to be replaced to LED I started writing down each bulb and location - but was taking ages And wondered if there was a list or do I need to keep going 😂
  12. Is there any visible damage to the loom in the vicinity of the wiring core failure - or is it not accessible?
  13. I totally agree with you, but it was the only thing I could think of. I think this was the root cause to all the electrical gremlins I had before, So I probably unnecessarily changed the alternator as well. I´m just glas that it works now.
  14. mateiapostoiu joined the community
  15. Matus22 joined the community
  16. It could be that the brake pedal hasn't returned fully. Try and lift it with your toe. Also check reservoir isnt full to the brim. Only other thing I can think of is ABS unit. It may require vcds or similar to bleed if air got in while changing calipers. As its all four wheels I reckon its trapped hydraulic pressure somewhere between master and ABS. Alasdair
  17. Hi Only the boot (half) of my 2013 Superb opens.Is it possible to open the full hatch manually to examine the wiring in the hinged area. What does the Torx Bolt pictured do?
  18. jjtone started following Dual Tailgate
  19. I have just fitted new front dics calipers and pads to my 2015 skoda roomster 1.2 tsi with 35000 miles the items were replaced as brakes had seized on 1 wheel following a successful mot/nct test a d 1 front disc had been fried so to speak after fitting new brakes and bleeding system all 4 wheels are locked any ideas
  20. Yes Sir, Mr. Thread Revival.
  21. So when I collected my car Smelt of dog constantly Detailer says they have painted over the dog hair with black spray paint While he will do his best to get a lot of it off Is there part numbers for new side pieces, maybe bottom carpets and back of the seats? This is what I’m faced with So might just replace Part numbers and pieces be perfect for all rear pieces Estate
  22. Daturon joined the community
  23. Thank you for the detailed study.
  24. To be fair, it's always been a requirement for drivers to check their vehicle. The Highway Code states: Checks you should carry out Every time you drive you should check: the windscreen, windows and mirrors are clean all lights work the brakes work It's our laziness that encourages reliance on the car's electronics, but are they always right. There are now street legal LED retro fit bulbs that can still be seen as failed by some ECU's (older I suspect) that can be fooled by a resistor pack (Osram do all of this). NOTE: Unsurprisingly, the UK is behind the majority of European countries in granting LED retro fit bulbs type approval 🙄 All 'coding out' bulb failure means is doing checks as per the Highway Code 🙂
  25. There must have been significant damage or poor crimping there before these events happened, almost certainly at build time, or wiring harness build time. No way an inrush surge from connecting a battery should be able to burn out wiring.
  26. tylerf16 joined the community
  27. Thanks a lot mate qick question will this file work with VCP? I tried couple of .frf files allready and all the time the VCP run into an error due to missing .odx file. Thanks for answer
  28. I get that I just like shorter clean plates Maybe have the front bumper smoothed in the future
  29. Waze and Google maps were set up on the digital dash. Certainly not a must have, but a nice little gimmick.
  30. Martski joined the community
  31. Yeah mine seems to have about 20 holes through it. I put plate holders on as I don’t like seeing screw heads in plates!
  32. Yeah noticed the rears Front bumper looks a **** show 🫣😂
