gyfggg started following Getting rear dash cam cable down to rear wiper
Oil filters
Been using Fram,Febi/blueprint or Mann which ever is cheapest for years and no probs. I use standard oil not longlife so it gets changed more regularly including filters. Just avoid any cheap ones that you have never heard of. Alasdair
Advice on Karoq vs Kodiaq
Depends if you can fit two prams or pram and buggy plus luggage. Daughter has volvo v40 which is only slightly shorter than the karoq and just gets the pram in boot. I would have a look at both load space in rear. As previously mentioned have a look at Octavia estate. Its got a big load space and slightly shorter than kodiak. Alasdair
Convenience windows no longer working
Just used the method above to restore the convenience window on my 2020 after they stopped working.
TMC traffic events no longer being received...firmware update required?
There were only two TMC providers in the UK. Both have pulled out now. The VAG / Here Maps traffic offering is only available through connected services.
Update To Infotainment Version 1985 - Download Link and Guide
@Tznofl I can vouch for Kieran (East Yorkshire Retrofits) who ran the full update package on my 2020 Octavia 4 as it's performed flawlessly since. Will save you a lot of time, hassle and money versus going to a dealership
Amundsen MIB2 Firmware Update
Hello, I’m posting on this forum to see if anyone can help me. I have a 2015 Skoda Fabia; I’ve never updated the radio, and recently it’s been giving me a lot of trouble with Android Auto error 8. I was wondering if there might be an update available for my radio. Many thanks in advance. DPN - 5Q0035840A Hardware - H25 Software - 0245 Media Codec: 2101.0.0.10
9083ja started following Amundsen MIB2 Firmware Update
9083ja joined the community
Broke down in my 1.5 TSI - oil in spark plugs
Probably as you said not put back on securely which would explain the whistle noise. Glad you got it fixed. Alasdair
Tyre Pressure Monitoring fault
If you disconnected battery the steering and esc will come on until you turn full left and full right plus a short drive. Looks like you may have to remove bearing and clean or replace. Alasdair
Does anyone know if it's possible to switch mib2 /mib2.5 high to use Here TMC in UK. If I good remember ford sync 3 used Here through TMC and never noticed issues.
Mrk26 started following TMC traffic events no longer being received...firmware update required?
- Radio harnesses
Very intermittent screeching noise.
Just an update, I've checked the alternator pulley and other pullies around that area, all seem tight, belt looks tight, OK from what I can see. As they're not easy to inspect, due to their location. Unless you were to go from underneath. So Ill keep an eye on it, if it becomes worse, be easier to diagnose. If I do get to the bottom of it, I'll post on here, again.
Beige88 joined the community
- Yesterday
There’s an update to take the system from 16xx to 18xx via 17xx (2 updates in one) Then a separate update to take it to 1985 It’s likely your car has a boatload of software updates outstanding which should all be completed at the same time to ensure a compatible baseline. Visit a specialist - we can help
No, Firmware 17Xx-->18xx-->19xx-->Last Firmware Also you have To Check the OCU Firmware
Ah! Just looking on YouTube, and what I thought were plastic flaps, are probably actually bits of the magnetic ring on the bearing! https://www.youtube.com/watch?v=QeILfoNK9q0 (That's a Karoq, but I think it looks very similar to our Kodiaq)!
More LED DRL Woes!
Very helpfull, thank you!
Milet started following More LED DRL Woes!
Snow chains with 18" wheels
I know it is the hight of summer with heat wave 100...., but I would like to check if anyone has used snow chains on a Kamiq. My daughter's Kamiq SEL runs on 18" alloys. She has got all-season tyres fitted to the 18" wheels and might need to fit snow chains. The Skoda manual recommends snow chains only on the 16" option. I have seen on the www that you could use thinner 9mm chains rather than 12mm for low clearance on 18" wheels. Is there anyone who has done this successfully?
26DIPP started following Snow chains with 18" wheels
So... ...that went well...🙄 Replaced the ABS sensor this morning, and now I've got FOUR warning lights! ABS, ESC, steering and TPMS... OBDeleven is still saying right hand front ABS sensor. When I took the old one out, I could see a few fine scratches on the tip, and peering down the hole it came out of, I could see quite a lot of flaky rust, so I scraped that off with a small screwdriver, whilst slowly turning the hub. I also noticed what seemed like a number of small, black plastic "flaps" on the vertical face just outboard of it. No idea what that face is?
What to look for when buying
Daughter had hers for 5 years prior to having grand daughter. Only issues were sticking rear brakes and rust just starting around the fuel filler. Hers was the 75 bhp version which was surprisingly nippy and great on the motorway.
camiqsid joined the community
I'm old enough to remember when the most difficult part of keeping a car running was doing the tappets.
Not sure but off the top of my head I'd say that's too big of a jump, I couldn't be sure though. Just be aware that if you try it and it doesn't work out you could brick your system. I've heard of people going from 18xx to 1985, I did so myself, but only based on sound advice. There are a few experty types browse these forums, hopefully one will see your post and be able to advise you better than what I can The other thing to be aware of is that updating your infotainment system won't necessarily get rid of any bugs you may be experiencing, these cars have a lot of modules and each of them need updating from time to time. Could be worth getting in touch with @East_Yorkshire_Retrofits who offers a comprehensive software update package, depending on where you're based
Can I update from 1668 to 1985?
Tznofl started following Update To Infotainment Version 1985 - Download Link and Guide
Tznofl joined the community
sam27 joined the community
Octavia 2 has developed a boot leak
5407-5410.jpg When I first considered this gutter area edged with the boot lid seal it was packed with bone dry clutter from the sky. I wondered where water was supposed to be accommodated. With this in mind I intend to keep it scrupulously clear of debris in the future. The rear light clusters have been removed and inspected and reinstalled. There was no evidence of water damage.
8hmit9ggj joined the community
CR170 Hard to start after replaced fuel tank.
From your description, I'd suggest very likely something wrong with the replacement fuel pump.
Skoda Superb 2017 2L Petrol 4x4 Laurin Klement FOR SALE
Make & Model: Skoda Superb Mk3 2L petrol 4x4 DSG 280ps Laurin Klement Mileage: 88300 Price: £13 995 negotiable Location: St Albans, Herdforshire Condition: Used Very good in and out. Slight dent on passenger rear arch Wheels could use a bit of love, but otherwise look good. Service history: Last dealer service at 79k miles, which included a DSG service. Previous service allegedly at 69k miles, which, according to the previous owner, also included a Haldex service. New types & recently replaced front dampers. Next service due very soon. Collection: Yes Pictures:
Im sure you wont regret it,enjoy!
