Past hour
PSDR joined the community
- Fabia 2024 SE comfort mpi fault
Fifth gear popping out (gearstick)
Might be worth checking gearbox oil level/condition as well as its a 2005 car. Could be low Alasdair
Karoq Sportline 2024 2.0TSI - What lights do I have?
According to AI, not all Karoq model trims are fitted with AFS as standard - do HBs operate when switched manually on the stalk? Check on 2024 Skoda options list what yours has as standard. You could also try an online VIN decoder to see what you actually have.
Might be worth resetting gear lever cables and check that the selector on Gbox is not seizing especially the plastic triangle shaped bit. Alasdair
Alasdair1 started following Fifth gear popping out (gearstick)
Wheel spin on moderate throttle
Just to reinforce StevesTruck's message. Many years ago, or so it seems, I had a new Audi A4 Avant which would spin its wheels at every opportunity. Only after a few thousand miles when I checked the tyres & found that the wear on the tyres was uneven did I get it sorted - it was the steering geometry at fault. Once corrected it was a far more sure footed car.
Cheshirecat started following Wheel spin on moderate throttle
skoda superb mib3 multimedia black bar problem
Here is the solution to this problem: https://www.drive2.ru/l/747128872385908278
dagetto started following skoda superb mib3 multimedia black bar problem
Thanks for the reply. Ive been back twice now!! Getting usual dealer fobbing off, 'theres nothing wrong with them'. I cant find any way to adjust the beam though, (like in the old days with a thumb wheel on the dash!)
Today
Welcome to the forum. Take it back to the supplier and insist they inspect the headlights for correct function. Quite possible your lights do not comply with MOT requirements if as described.
Warrior193 started following Karoq Sportline 2024 2.0TSI - What lights do I have?
AdBlue
It's not a Skoda, but my van runs adblue. Bought it with 130k on at the start of 2024, not it's on about 170k. I dropped the injector out and cleaned it with warm water when I bought it, even though there was pretty minimal residue in there. At the start of this year, I hadn't used the van for about 3 months and it faulted on the final O2 sensor on the system and started the countdown of doom. After a bit of reading, and nearly falling for it, I found that fake sensors are a thing, so I paid Merc £400-500 for a new one and it's been fine since. Rightly or not, I don't use anti-crystal, the van uses about 1litre of adblue per 1000 miles. I fill it up at the lorry pump at a garage that sees a lot of HGV's coming through, so my hope is their stock doesn't get chance to get old. To be fair, adblue systems aren't complex, it's not too dissimilar to an old Single-point fuel injection system when you think about it. When the engine conditions are right, it injects, and monitors the O2 sensors before and after the cat to see if it's worked. Yeah, I'd rather not have it, but it's not the witchcraft everyone makes it out to be.
Hi all, I recently picked up a (used approved) 2024 Karoq Sportline 2.0 TSI. I was under the impression that all Karoq Sportlines have AFS (Adaptive Frontlight System) that changes light range dependent on speed etc. Thing is, the lights are terrible. Like dangerously bad. They are constantly around 4 meters in front of the car and dont shift. Not fun at 70mph on a dark motorway. I've been in touch with Skoda UK who have said my car doesnt have AFS!? In that case what lights do I have and how do I adjust them? Hoping someone can help Thanks 🤞👍
Cakewalk started following Karoq Sportline 2024 2.0TSI - What lights do I have?
Park Distance Control: please clean rear sensors - 2022 Octavia 1.4TSI iV
There's still a free check you can do without live data. Ignition on, handbrake on, reverse selected, then put your ear right up to each rear sensor. A working one makes a faint fast ticking. If one is silent while the others tick, that's your suspect. Holding a phone on voice record against each one helps if it's hard to hear. All of them showing nothing with the exclamation mark doesn't mean all of them have failed. On these VAG systems one bad sensor is enough for the whole rear set to be switched off. If none of them tick at all, I'd look at the bumper loom and the plug where it joins the main harness before buying sensors. For the measured values later on, a VAG specific tool like VCDS or OBDeleven will read the parking aid module. A generic OBD scanner usually only gets the engine side.
- Cairus's Leon FR
AdBlue
I've taken my 2016 Greenline from 152,000 miles to 191,000 miles since I bought it in March 2025. In that time it's been 100% reliable in terms of never breaking down and never going into limp mode. Including when a glow plug failed on a trip to Prague in September 2026. The car drove fine and I replaced the glow plug when I got back to England. I've topped it up with 10 litres of Adblue plus a bottle of Wynns anti-crystal every 6,000 miles or so. I've had no Adblue issues. No DPF issues. No EGR issues. I paid £0 road tax for 2025. And £20 for 2026. It does 60+ mpg on a long run, driving at the speed limits when safe to do so. Insurance is below £400 per year for me. OK, it's a slow grand-dad's car to drive. But 99.99% of the time, the lack of engine power is not an issue on the roads of the UK and Europe. Any time I lose by a lack of rapid acceleration is made up by having to stop for fuel every 700 to 800 miles.
tyres
which is month and year of production ot that tyres? best is to buy al 4 new if you change tyres, i dont like to drive different tyres front and back. but sure you can put new back, and next year it this time rotate and put new ones on front. those tyres are for electric cars btw.
Cairus's Leon FR
thats very cool
Octavia VRS 2.0TDI DPF Issues HELP
DPF is full of ash, it needs proper chemical cleaning outside vehicle, EGR system needs replacing or detailed cleaning, when i had EA189, 2012, intake manifold was 30% blocked with some kind of soot, greasy and hard. yours is also similar probably. you need to invest, but you already aware of that when buyed sport version of TDI with 300k
Reverse doesn't always engage on the first try
If it was linkage, you'd have issues with other gears as well - either 5th due to side-to-side play, or 4th and second due to forward-backward movement. The reverse is unsynchronized on these gearboxes, with reverse gear sliding in between other gears. With some wear on those gears, it's quite easy to hit side of the gears. Once you leave the clutch, gears spin for a bit and you can get a better position on the next try. I always tried to hit the right moment after pressing the clutch, when the gears stil spun a little, to make the engaging easier. But if you do it too soon, the gears will grind.
Coolant overflows
A partly blocked radiator would usually show as the temperature climbing and staying high under sustained load, like a long hill or a motorway run, rather than jumping to 105 and dropping back to 92 within seconds. It also shouldn't push coolant out of the tank unless the coolant is actually boiling, so I'd put it lower down the list. The pump is more interesting on that engine. The 2.0 TDI EA288 has a switchable main coolant pump. A shroud slides over the impeller when the engine is cold so it warms up faster, and the ECU pulls it back once it's warm. MAHLE put out a technical note about the shroud sticking closed, which stops the coolant circulating even when the engine is up to temperature and makes it overheat. The same note says that when the pump is changed, the actuator from the old pump has to go onto the new one and be reconnected to the ECU. As you've already replaced the pump, I'd check which type went in and that the actuator is fitted, plugged in and actually switching. If the flow drops off under load, the head can boil in spots and push coolant out of the tank, while the sensor only shows a short spike. I'd look at the main pump and its control before the electric pumps. If the EGR cooler and the leakdown both come back clean, that's where I'd go next.
Evilserge joined the community
When it does happen, it tends to be either when already in gear and just driving steady (ie random) or, on the occasion it did it several times, on acceleration. If that helps diagnose!
- Reverse doesn't always engage on the first try
D.FYLAKTOS started following Reverse doesn't always engage on the first try
Hey from the North East of England!
Fairly new Skoda owner (it was my wife's, but I foolishly traded my car in so she could have an electric car, received her Karoq because I tend to do about 1000 miles a week, she does a total of about 300 including the back and forths to various 'socials'. Never had a Skoda, more of a van / mondeo hit it with a big enough hammer and it'll keep going kinda driver, with enough spanner wielding to fix most things until the computers in the cars became more than just "is that the right key?" and "How much oxygen you got there mate?" - Weirdly I'm a software developer by trade (proper software, ground up - not a script writer) and robotics is a fun hobby - so you'd think I'd be over the moon about the computerisation of cars. So, seeing as you can't even change a battery without cranking out a copy of VCDS and prodding the brains of the unit I thought I'd better come and get some coercive support from someone! That happens to be you. I hope I can assist as much as I need to be assisted - we'll see I guess! For now I'm going to sit here, watch the sea broiling out of my window and wonder how I can get my good old 2007 Mondeo back from the dealership pmsl Doofs
Doofah started following Hey from the North East of England!
Your issue is most likely to be excessive wear in the gear cluster, although this can sometimes be due to faulty engine mounts on some older vehicles. Does this this tend to happen more when you accelerate - or when you lift-off the throttle ?
Is the oil service really needed ?
Presumably your vehicle is on fixed, annual servicing schedule. £250 is expensive for just an oil service! If you now have used up all of the services paid for under the plan and now require a further oil service, you are free to have it done anywhere you like - just make sure that the correct specification oil is going to be used.
tyres
car has Hankook ventus all round, but the back are now around 3mm front 5mm Big decison do i go like for like with a new pair on the back or switch to four Hankook flexclimate Any one have experience of the range drop going to all season tyres and are they worth it for someone whose main use is between March and sept Less than 5,000 miles a year total
- Coolant level warning mystery
