1.6 TDi Greenline glow plug replacement
When I changed a glow plug, I sprayed it when hot and cold with WD40 specialist penetrant for about 3 weeks leading up to being brave enough to try taking it out. https://www.eurocarparts.com/p/wd-40-specialist-penetrant-400ml-542771790?utm_source=google&utm_medium=cpc&utm_campaign=610675635&utm_content=70461851759&utm_term=&type=shopping&gad_source=1&gad_campaignid=610675635&gbraid=0AAAAAD1aCJiCH00Nb1y-9oNagakWazLWg&gclid=CjwKCAjwifjVBhBKEiwAYx4K9Gr4esDsqkYF07vtj-SUlNoa99sUK64kWpMgQefPCrCN5MJdWU_ttRoCb-IQAvD_BwE It came out ok but took quite a bit of force (And bravery) to crack it initially. But they can be very hit and miss!
Binx1310 started following 1.6 TDi Greenline glow plug replacement
Amazed Skoda has become so BAD..
Thanks Rbz5416, excuse my ignorance but how do you do that?
Which suspension parts can contribute to brake judder?
I bought them from Eurocarparts (UK) but you can search the Brembo website based on your exact car - mine is 190 TDI FWD Estate. I got the Prime model. https://www.bremboparts.com/europe/en/catalogue/skoda-superb-iii-estate-3v5-2-0-tdi/000115168-1
Do you have any references which exactly model/type disks you used for replacement?
Octavia VRS rear end issues
Glad you got it sorted out. How do you find the ride with new parts and bilstein eibach combo? Is it the bilstein b12 kit with b8 shocks and eibach pro springs? Im also thinking of replacing/upgrading my shocks and springs but still havent decided. Also with the fuel prices skyrocketing it doesnt make me feel good throwing much money in the old but reliable diesel Vrs.
Jo88Mak started following Octavia VRS rear end issues
I was the same. Changing back discs and pads didn’t cure it but fronts did. All brembo parts used. Remember to clean and lubricant the slider pins. This should be the proper ate grease for the fronts. Not copper slip.
Hi yes I had the issue, I changed all 4 disks and pads with brembos now it’s all ok
KamiqFrancais joined the community
Thanks for replies guys All sorted. Ended up being the lower toe control arm on driver side. The inner bolt had worked its way loose. Supposedly all checked when alignment was done. But all good now
Have really similar case, does any one have managed to solve this issue? Was just pads/discs replacement (both front/back) ? Or anything else underlying? @Sko101 @Binx1310 @MrRich
sis11 started following Which suspension parts can contribute to brake judder?
sis11 joined the community
Superb MK4 IV charging
Hi all. Apparently Seat/Cupra and VW have released a software update that installs a charge scheduling function to the latest generation PHEVs. Skoda UK have referred me to a dealer to check whether Skoda can do this. Has anyone got any news?
4x4 Suspension Upgrade
Anyone any thoughts!?
the truth about electric cars
Brake pedal soft but brakes fine. Doesn't pump up, no fluid leak - air in system or master cylinder problem?
I think the only time the seals could get damaged is if there is dirt corosion in master. Normal braking pedal only goes so far down. When bleeding it can travel to floor and seals can get damaged if theres rust/dirt in an area they dont normally use. Saying that I have never bothered using a pedal block as I didnt know to until now and so far in 40years never damaged seals in a brake master. Alasdair
Car juddering during acceleration
I have a 2012 skoda superb 2.0l tdi DSG. The issue is when accelerating I get a judder around 1600rpm. It is nearly like I am hitting the rev limiter, the revs will bounce and struggle to rise and you can feel a judder through the whole car. You notice most in 3rd or 4th but it does happen in all gears. It goes away after driving for a while, not just enough to get engine warm but 20-30 minutes. And strangely after problem goes away like that the next day the problem still won't be there but will come back after a few short journeys. I plugged in a obd and no faults showing. I did try record live data and use chat gpt a bit but I'm not convinced by it, at one point it referred to car as a BMW. Some things that came from live data Fuel pressure specified and actual seemed to track well EGR similar Air mass seemed to have a difference in specified vs actual, and charge air pressure also had a difference. I took it to a mechanic who thinks it's a gearbox issue, and advised taking it to a gearbox specialist, he kind of said the turbo could be showing issues because the engine management is seeing issues with gearbox and so pulls back on the turbo. I'm not so sure because of charge readings but looking for any advice from people on here. Any better ways to confirm issue?
gillo100 started following Car juddering during acceleration
barn find felicia pickup.
hmm some progress perhaps, not finalised, it needs the bits and bobs greasing, but i THINK those springs are all in the right places more or less.
OK, that's good to know, thanks. I suppose it is difficult to know how the air bubbles will behave. I always assumed they just moved linearly as you bled it but I suppose it is more complicated than that. Thanks. I would take you up on that offer though I think I'd be cutting it a bit fine now (I know I should check for replies more frequently) as the MOT is 8AM tomorrow. I've also only just checked the VCDS owners map, and there are people a lot closer to me that I should maybe ask. Thank you for the offer. Fingers crossed it passes the MOT. Even if it does I still need to sort this out so I will probably need to organise trying this with someone. If the master cylinder does need to be changed, do you think it is possible to do that without having to do the computerised bleed all over again? You're right. Without understanding the ABS unit inside out it is impossible to know what is going on exactly. I have tried pushing hard with the engine off but not in a while. I'm fairly certain it was quite hard though so maybe it is air. But I don't know if there is some kind of threshold of pressure that is needed to make the seals blow by. I suppose if I can get someone to do a bleed without me having to buy a VCDS license, I might as well try that and then move on to the master cylinder if that doesn't help. Is it a sure thing that bleeding it without the block ruins the seals?
gillo100 joined the community
So more articles on fuel and China banning exports and then Car Dealer magazine on the rush to buy ev,s but dealers not wanting trade in ice,s. Maybe so. Lots and lots of Chinese manufactured and owned EV,s in the UK ready and at sea on there way here. Win win, every cloud a silver lining for China thanks to the POTUS.
Driver's Door Electrics
Yep. I'd agree, my 2014 had some issues with the locking, found several broken wires and wires with insulation cracked. DIY repair if you are comfortable messing about with wires/soldering etc. I suspect the passenger door and boot lid going the same way unfortunately...age, repeated bending/stretching and material quality all an issue here.
TasMan started following Driver's Door Electrics
Subarugd8 joined the community
Mine is a 25 & has no over-revving, except when using engine braking to keep the ACC on the limit when going down hill. If the demonstrator does it as well then maybe whoever uses it at the dealership has a leaden right foot. As I said previously, try a reset of the DSG.
Octavia radio swap
Looking to swap out the mk3 radio for the 3.5 radio in the misses car she’s got 2014 Octavia, what steps do I need to take to swap them over is it a straight swap both the screen and box in the glove box or is there coding to be done.
Chrismk started following Octavia radio swap
Might be worth getting someone to follow you on a straight flat road and see if the car is dipping on one corner at rear when accelerating. If it is then maybe swap shocks around and see if it moves to the other side. Before swapping might be worth loosening and retightening bolts in case one side has been tightened when off the ground. Made that mistake on my mk2 as I was tired and the car was a few cm higher on one side. From memory its the shock bolts and wheel end of swing arm.
Alasdair1 started following Octavia VRS rear end issues
Broken wires in driver's door bellows. Super common.
My 2011 Superb Elegance has developed a weird fault with some electrical features, but just on the driver's door: Central locking works on all doors - except the driver's door Left (passenger side) door mirror can be adjusted from door control, but not the driver's door. The driver's door mirror does not heat up or fold in. I've checked the fuses but they are all OK, but I can't understand how one fuse could be responsible without affecting the other linked electricals. Does anyone have any ideas regarding this? Thanks in advance.
JohnnyRich started following Driver's Door Electrics
The bloody drama continues apace but I'm too weak to get the springs in any of the right places, hahaha. Will deffo get these brakes back on in the end. This is improving stuff, it is. I read back through this thread and it's picked me up a bit, this truck has been on a long journey but it's all moving in the right direction.
