Past hour
Servicing my serpentine/auxiliary belt, what brands should I get? (CGPA)
The last FEAD belt that I replaced was on my wife's 2015 VW Polo 1.2TSI and it was a Contitech (Continental) that I bought. The belt for her previous car, a 2002 VW Polo 1.4 16V, that I bought was a genuine VW Group part - and it was a Dayco "made in France", and it, when opened out and laid down on a flat surface it had a "bow" in it, ie it only touched the flat surface at 2 points - I examined it and discovered that it had been cut at an angle to the weave - or at least the smooth side material had been, I still fitted it and it lasted okay. I did expect better from VW Group, but there again, I've had failed front wheel bearing due to water ingress - and that bearing was "made in France"!
yeah will do, we tried to get the belt off earlier today and the bit kept slipping off, gonna have to take it to a garage, which is rather annoying as i already bought the belt but im guessing they will want to use their own parts for insurance/warrenty purposes i guess i have a spare belt now 🤷♂️ or i could also return it as well as its still in its packaging
Autodoc - avoid!!!
Oh well, my mate's Autodoc parcel arrived, meant to be 2 rear callipers, but it seems he has been sent 3 Ridex callipers AND a Ridex radio! Hopefully he attempts to refurbish the 2 original rear callipers and just uses these Ridex cheapies to keep things moving!
- 1.5TSI Axial bearing (2018 car)
No, just a straight change of old for new. It turned over a bit to start and then the eml light came on. Just turned it off and restarted and eml light went out. My mate reckons it was due to low fuel pressure with changing the filter. Been fine since. :)
5Q0 612 041 BM Brake booster vacuum hose with a non-return (check) valve and pressure sensor
Plastic became brittle and snaps. Nothing unusual.
Common issues and what to look for
Rear shocks, electric tailgate struts, rear discs, 2016 diesels had a bad batch of water pumps, others are ok I think. Some DQ381 7 speed dsg's have failed mechatronic units. Other than that full service history and overall condition.
Replace complete tensioner, not just roller, 2 months ago I put on my 1.5 tsi INA tensioner and belt. Car had 100000 kms. Belt seems to be high quality. Shiny surface which suppose to be dayco or gates. Always choose belts with shiny surface, not matt, it is newer technology. More durable. Original was also shiny one.
Canton Subwoofer to Aftermarket Sub and Amp
Just in case someone is interested: I have been running a JL Audio 10TW3-D4 (2x4 ohm) sub for a year hooked to the Canton sub channels. Works perfectly, no problems whatsoever and enough bass for me. I have cranked the stereo to the max and no issues. The enclosure is a car-model-specific from basser.pl. Installing 10TW3 to the enclosure requires some modification to the speaker hole, the original has to be enlarged a bit. Additionally, the mounting flange needs to filled up with plywood. I also took the trouble or lining the inside of the enclosure with 50/50 mixture of sand and poly resin. This made the walls rock-hard.
cabbie_fin started following Canton Subwoofer to Aftermarket Sub and Amp
Today
DCC Slider adjustment option mod
Where are these modules located or how can I check if my car has the right ones? It's a 67 plate Sportline if it makes any difference. Thanks
Phone symbols on infotainment screen.
Excellent, well done @DerekU , I'll check that out in the morning when it's a bit warmer! You'd think something so basic would be mentioned in the infotainment part of the manual really!! FP
- Ceratec diesel additive to Octavia mk3 2.0 tdi
It’s a 10 year old car which I bought and I would want to do all the possible preventative maintenance tasks which will keep the engine running for long. I do understand that the synthetic oil VW provide already provides protection to the engine, but I have seen cases where there will be metal shreds in the engine oil in an aged car. So, Ceratec basically provides a coating which will prolong the engines life. I have seen videos and reviews on YouTube where this product has received positive feedback.
Bert joined the community
- Skoda fabia starting issue
Flat Battery in Key Fob - Warning
Please ignore. I'm a doofus. Had forgotten to peel sticker off new battery. Key works fine.
Gearbox Emergency Mode
VW group / Skoda refer to them as Semi Automatics just because that is what what DSG,s and S-Tronics are we them dry or wet clutch.
Tailgate being funny?
Hi all, I tried to search the forum but couldn’t find anything that would help. Last month when I was about to leave for work, I noticed that rear licence plate lights were on (the car was locked). I unlocked the car and they turned brighter once the car was unlocked. I locked the car and they dimmed but remained on. I unlocked the car again and tried to open the boot, but nothing happened (it’s a manual tailgate), it was like it was still locked. I used the emergency release from the inside and it worked. After I arrived to work, I was able to open it, but the lights remained on. This went on for few more days and then it suddenly went back to normal - lights off when the car was locked and boot opened just fine, when unlocked. I should mention that this happened after driving in very heavy rain. Anyway, it was then ok till now. It started happening again and the last rain was on Wednesday. I managed to open the boot in the afternoon and I heard water splashing inside of the tailgate and then noticed water coming out from behind the plastic trim as I opened it fully. Google suggested to remove 3 rubber plugs at the bottom of the tailgate to let the water out, which I did. My guess is that water gets in somehow and messes with the cable harness causing the lights to remain on 24/7 and tailgate release not to work at all times. I checked everywhere and everything seems fine, so no idea where the water gets in. Has anyone else had similar issue? Thank you
Heron91 started following Tailgate being funny?
Tyres and punctures
Hi, Self seal means that You do not have to reipair the tyre. Hoewvet, you still should remove the screw. I had such dituation and the screw was jyst simply removed. Then the tyre was pumped to higher pressure for few minutes an that was it. I have driven after that for 6 motnths and paid attention to pressure - there was no drop in the pressure at all. So it works. Regarding repairibg such tyre - yes it can be repaired. However, it is work and time consuming as they have to remove the sealant. As long as it is just small puncture - repair makes no sense as the self seal feature works ok.
ufwojcie started following Tyres and punctures
https://www.webuyanycar.com/?glbtrd_src_ind=wtxv-GDWlE-GZf8_oNVxXw%2F&utm_source=google&utm_medium=cpc&utm_campaign=Brand%20-%20London&utm_id=16880063734&utm_source_platform=Google%20Ads&utm_term=we%20buy%20any%20car&utm_content=Phrase&gclsrc=aw.ds&gad_source=1&gad_campaignid=16880063734&gbraid=0AAAAAD-VJQY5QLJFybJ9F7WumJmOZ80Bf&gclid=EAIaIQobChMIruakqNmZmAMVKpJQBh3BBh5SEAAYASAAEgKwS_D_BwE
Rear springs...replace?
Hi All, New here so apologies if I have missed something or am posting in the wrong place. I have read the previous posts on this thread as I have a MK2 2015 Superb Estate with a saggy rear...... Ironically I am also moving to France next year so judging by the previous posts I should certainly sort this before moving! To get through the recent MOT my car had the following replaced: Nearside rear suspension arm (left) Offside rear suspension arm (right) Nearside front anti-roll bar drop link (left) Offside front anti-roll bar drop link (right) I have always had issues with the odd speed bump scrape, especially if a tyre or two has lost any pressure, but this summer holiday trip with luggage, dog and towbar mounted bike rack was too much for it. Rear was very low and towbar was regularly making contact with bumps etc. Since those parts being fitted the problem seems to have reduced, which surprised me a little as i assumed I most likely needed new coils, uprated coils, or auxillary coils? I'm keen to solve this problem as I am intending on keeping this car and running it into the ground, I also need to spend a small fortune getting the clutch and DMF replaced which is going to painfully expensive too! Any tips on: Which coils to fit/how i check compatibility. Can this be a DIY job (what tools req'd?), or is it garage only? Any help much appreciated! Ross
RossKetz started following Rear springs...replace?
Start Stop Stall
Alternatively you can code start stop not to activate or install a control module that prevents it from activating too
Chain, tensioner and guide replacement
And ROM. Cheers.
Start Stop Stall
For recoding you can do this easily as a diy job using an app called carscanner and an obd dongle for about £30.
Binx1310 started following Start Stop Stall
Heron91 joined the community
Buy from skoda-parts.com is the right way to go never had any problems with the parts or service contitech belts are the OEM prodùcer for Skoda and INA tensioner are OEM If you can freely spin the tensioner òr the idler pulley they need replacing as there should be slightly difficult to spin
