  2. Lovely clouds, sky, Moon (99% full) and reflections this afternoon. Only had my phone to hand sadly🫤
  3. 1941 is not actually the latest software version, although it is considered a stable release so if it isn't causing you issues, I'd just stick with it. 1989 is the latest version, although I myself stuck with 1985 as it was (and still is) working absolutely fine for me. 1985 and 1989 are the only 2 releases after 1941
  4. Ah that might make sense re battery. Think its about a year old but cant remember if I bought a new one or nicked a good one from one of my older cars. Will check voltage tomorrow. The high idle has only been there for the last few cold days -3C and below and only today did it fail a regen hence fans on. Previously it just sat at high idle but no signs of regen or fans. Its supposed to get a bit warmer tomorrow (a balmy 4 degrees!) so will monitor it plus give it a good run when I can. Cold weather is hard on batteries so hopefully thats it and nothing more sinister. Alasdair
  5. zeletu joined the community
  6. Today
  7. Does it if the battery charge is getting low, particularly in cold weather. May be first sign of battery getting tired.
  8. Weird it has done it the last two/three days in a row even after a 30min blast down road. Alasdair
  9. Mines does the same but also get strong exhaust smell. Only in winter the smell but the high rpm is regular due to short runs.
  10. Same here used to do longish runs but now all fairly short. It used to wait till engine upto temp but now seems to do it from cold plus a good blast yesterday seemed to cure it. This morning was the same again?? Seems to be regen every time I start car?? Apart from that car is running perfectly Alasdair
  11. yeah, thats the dpf trying to get a regen done. mine does it pretty regularly since i stopped driving it for work (stupid fleet management taking my mileage off me for a van...) so once a fortnight i bring for a run to let it blow out or force one through my carista if its getring very high
  12. Hi have a 12 plate 1.6tdi cayc and when starting car from cold it idles normally at 750rpm (-3C today) If I drive a few metres then idle jumps to just under 1000 even with engine cold and also once hot. Thought it must be DPF regen but never had it when engine stone cold. Took for a blast down dual carriage way yesterday at 2500rpm for about 30mins at full temp and idle returned to normal. Started car today and idle was 750rpm while defrosting it then as soon as I moved car it jumped to 1000 again and stayed that way. If I turn car off and start again its 750rpm till I move car. Got home from town and the tell tale fans on after engine switch off so reckon its a regen again. What could cause it to try and regen all the time. Is there a sensor I should be looking at. Scanned with cheap reader and no codes plus no warnings on dash. Alasdair
  13. Hello! I have a Octavia MK3 vRS, 2.0 TDI, engine code CUN The engine is overheating, 15k kilometers (~10k miles) since timing belt job (incl. water pump and oil pump belt). *No coolant leaks*. The parts I used are all Continental. What brand of water pump do you recommend? Or should I switch to a mechanical pump instead?
  14. Andu started following Engine Overheating
  15. JohnGallagher joined the community
  16. Hey all, I'm kind of cheating a little bit here because the engine might be in my sisters car but it's the CZJC 1.2 tsi that we're having issues with. 1.2 TSI EA211 January 2016 build Whilst I personally have an overweight Polo (golf) my sisters car has a potentially serious problem. I wondered if any of you guys may have any input on this at all please? My sisters car began running lumpy, threw the eml and then it cut out. The car would not restart. The timing belt has been changed (July) if that makes any difference to these error codes that are now stored : P001100 A Camshaft Position (Bank1): Timing over-advanced or System Performance. P030000 - Random misfire detected P030100 - Cylinder 1 Misfire Detected P030200 - Cylinder 2 Misfire Detected P030300 - Cylinder 3 Misfire Detected P030400 - Cylinder 4 Misfire Detected Having cleared the faults, it then returned with a P008700 Fuel Rail/System Pressure - Too Low error. I wonder whether this might be because it wasn't managing to idle without increasing the revs and so the knock on for that was the reduced fuel pressure? The guys who did the cambelt came out, looked under the timing cover and said there were no teeth missing so that was that. There is however, a chirping noise coming from this area that did not exist before. The idle now I assume when it's switched to closed loop lambda control, is very, very lump with a equally unstable rev counter. What did concern me was that they referred to marks they'd made for the timing..... I thought those days were gone with how tight tolerances are on modern engines! My worry is that the timing has potentially jumped OR the VVT pulley wasn't tightened up properly and it may have slipped - and as such I don't want to try and start it if the timing is physically out. Could this be caused by a failure of the solenoid that controls oil for the vvt or could it be another sensor? I'm guessing cam and crank both have sensors which I'll try and have a look at tomorrow but I'm very limited with what I can actually do. Thanks for any advice you have, she's really saddened at this as she's owned the car for 9+ years and it's never gone wrong before this point! Also, sorry to cheat and ask for my sisters car! Thank you for any advice, Mike
  17. Hello Community, my wife had problems with CarPlay in her VW T-Cross and so I want other update her System. Did anybody have this firmware - maybe anyone can help. Thanks a lor UNIT: Teilenummer: 2GC035869A Hardware: 720 aktuell installiert: MEN2_EU_VWGPx_P0450L MU-Version: 0920 Apple CarPlay: 210.81 Needed Update: Software-Train: MEN2_EU_VWGPX_P7381L MU-Version: 8740 Plattform: MEN2 / Volkswagen / Europa / LG
  18. At least your Skoda came with an Ice Scraper 😂.
  19. Pol3cat joined the community
  20. That’s correct. The fuel/air mixture is controlled by electronic sensors and cables have been replaced by wiring. What could go wrong? There’s not much more than anybody can say but I’m enclosing two pictures concerning the fault on our 2023 Fabia mc. One is a photo of the screen in the yellow AA van before the technician cleared the fault and all record of it from the car’s onboard computer. That makes the car driveable again, seemingly without issue, but the fault recurs and nearly all power is once again lost. The second is a box from the job sheet left with us after the silver service AA van technician updated the software at our house. He said that this would not be a problem in future and it’s over 8 months since the last limp mode crisis. Fingers still crossed. The car is in for a full service and it’s first MOT but not with a Skoda dealership.
  21. Thanks for your reply only had the vrs 6 weeks after 6 bmw like it a lot
  22. packy joined the community
  23. Alright alright all these L&K owners rubbing it in. I have to make do with ice scraper and heated seat!
  24. Agreed - heated front and rear on, seat and steering wheel. Toasty in a minute.
  25. That fault code usually means no 12V supply, often due to missing or blown fuse.
  26. Toyo Proxes SUV in the summer. They seem "ok".
  27. buki32 joined the community
  28. Looks like it was low on oil took it out for a run no alarm bells as yet
  29. Looks like it was low on oil, took it out for a run, no alarm bells as yet
  30. @Gizmo was the OP and is still active on the forum. I believe he has sold his VCP but may be able to provide information on how easy/difficult it is to achieve.
  31. Thank you for the reply Wonder if someone have experience here and able share with me @Everyone
  32. Apologies, looks like a possible faded white one on the left, then the three yellow.
