the truth about electric cars
Last week I paid £1.80
It is more than that oop north at some BP, Shell, Esso, Texaco etc. PS. I would rather have a litre of go go juice than a cup of Costa. I do like where charging an EV gets you a free hot drink. But then the electricity is very expensive.
£2.12 a litre, where is that?
Skoda Scala 2019 1.6 TDi Bolero udpate - issues with Pixel 10 Pro connection
Hi, I still didn't find any solution. No idea wthat's the problem. It looks like it's global problem, pleae have a look at: https://www.reddit.com/r/GooglePixel/comments/1r3cznd/psa_pixel_10_vwaudiskodaseat_mib3_android_auto_is/
Get it Ready For Winter
Evolution13 started following Get it Ready For Winter
- Columbus Map Update 2026-2027 (MIB2 HIGH)
SD cards and the Amundsen infotainment system.
Picture of actual Software train. Press Long Menü, Service Menü Open, Then Software Update, then picture
Think it's this FeC that is required based on the more incredible bash documentation 023100EE There is a catch that you have to check that the firmware is applicable for the patch. The project tells you if it isnt. Some Audi drivers in the past have updated the firmware so it gets to a point where the patch has been written. A kind soul wrote the patch for my Seat so I didn't have to update the firmware that was 5 years ago. So there will be a table in the github project that shows which firmware release it works with, failing that it tells you when you come to the back up phase. Anyhow you can see why I don't experiment with this once it's working. ... all about your friends car.
OK, forgive the ignorance. What do I need to do/add to an ordinary SD card to make it work as the Satnav data storage? (that's if it can be done .... )
2025 Skoda Superb Navigation Update
Constant app updates
Dozens of reports on the Facebook groups. Skoda supposedly deploying an update to fix it.
Rbz5416 started following Constant app updates
- Constant app updates
Me too. For a couple of months now I've been getting about 2 updates per week. Also had an update to 334 a couple of days ago.
I belive Audi were shipped like Seats so the FeC installed in the unit always tallies with the one in the map file. Their cunning plan was for you to buy mapcare which gives you the ability to update for a 3 years or whatever they sell. VW and Skoda came with unlimited mapcare with a lifelong navigation FeC. There is a combination of buttons you can press on an Audi where you can read off the cars in built FeCs. You look at that list and read it off. That is a hex number. The map file hex as @viper42 quoted / use his method shown but don't save the file after is compared with the units current FeC So the navigation fec on the file has to be less than or equal to the units navigation FeC shown on the unit in Hex terms. The more incredible bash project on github which also goes under the name Mr Bonk or thats what I can it can be installed in the unit and that will write the Audi life long FeC into the unit.... then that <= formula is satisfied and the maps can be updated. All the Audi drivers round here including @BooBoo124 will have used the github project. For RoW there is a catch unless they have fixed it you need to add the RoW life long FeC into the file, the code included in the project is the European one. This came up a few years back on the RoW with someone from your part of the world. The project comes with extensive documentation so you can find the code you need or trace back the conversation. So essentially you photograph the cars current FeC screen. Install the project. Mr Fixit youtube video on that. Make sure the cars battery is charged, or keep it running etc. Make sure you got the RoW life long fec in the file of the project not the European one. Then you run the project. Use to be backup and then update the fecs. If you update with the European fec it wont work. Think the process is install the project in the car which is on the SD card. Then take out the SD card use notepad in text mode to edit the file and add that RoW lifelong fec if its not in it. See notes on their materiel. SD card back in. Use addfec command of the project. Reboot the unit. Go to the audi fec display screen. Photograph it. If it has worked then you will see the updated life long fec shown which should be the audi RoW. Now you are free to update the maps. The project also unlocks assorted screens for off road, performance etc - you can ignore then. Just an added bonus. Was in the middle of typing this when Viper got in with the short answer.... bells and whistles in this. The main thing is to make sure the unit doesn't power down whilst running the github project. It will reboot the unit a few times but loss of power is likely to corrupt the firmware. A charger can be connected or do it with the engine running. It's a one off procedure which you can then forget. Last time I did was 5 years ago. You just leave the project installed but it's there if you need it again. The SD card for the project you fiie away. All clear as mud 👌. Footnote Audi conversation going here: Bit more more time and I may find the Ozzie conversation I had on the Audi RoW fec.
Volume keeps turning up??
Hello, I made a solution for this kind of issue and also made a short movie how to fix touch panel under the black panel which is under the display if you have problems with self clicking or volume goes up or down all the time - this is the solution. Sometimes when on/off button is self clicking all the time - unit keeps rebooting as well.
LivornoBart started following Volume keeps turning up??
Windows, Mirrors and Doors Issues
Wires in door are fairly easy to repair but a lot of folk just join at the break. I normally splice in a new section of wire a good bit before and after the break as you get more flexability as solder tends to make section of wire rigid plus chances are the section of wire thats broken has been flexed over time and become weak. If the windows are temperamental and door lock doesnt operate it may be just a wiring issue in the drivers pillar/door. I would check wiring and repair first and see if things go back to normal.
Alasdair1 started following Windows, Mirrors and Doors Issues
Seats in the Peaq
Simple really, best wait until there are Cars on Display at Dealers or Shopping Malls that can be sat in at least if not until there are Demonstrators to drive, otherwise you might have buyers / leasers remorse for 3 years.
Evolution13 started following Seats in the Peaq
I’ve been having this issue for a few months now, constant updates for the store. I let it update, I get successful installed but it always reappears every single day Anyone else have this?
Nebb started following Constant app updates
- Cruise control. Mine stopped working. Eventually I discovered that I had switched off the skid control, by pressing the button,
While 473 would be nice, I am very happy with 453 as it has removed roads that no longer exist. It is silly being directed down non existent roads. Now I have another issue that I need guidance with. As we know from my previous screen shot, 453 works in my Škoda Columbus very nicely. I have a friend with an Audi MMI Navigation Plus (MHI2Q_ER_AUG22_P5092) with very old maps in it and as viper42 says the FeC for Audi is in 453, and MIB Helper says it uses the same map package as my Columbus, I thought I would update his maps. I put the SD card in slot 1 and the unit spent a minute or two looking and then decided it couldn’t find the data. So, we have a NZ new Audi with (old) NZ maps in it, so the region should be ok. We have a package with the Audi FeC, so that should be ok. We have an SD card with a working, proven, copy of the package, so that should be ok. Can anyone see any reason why the Navigation Plus can’t see the data? Thanks.
LivornoBart joined the community
Fabia Fault Codes (Just purchased car)
Thank you for sharing it
Coasting
You welcome 😊
