Stopping chain noise
Where was that recommendation, and for which cars/engines?
^^^ That is good, but VW specifically recommended the 5w 40. 40 for the HIGHER STABILITY. so really the 0w 30 FS III is neither hear nor there.
Nope, even back in 2024 (last saved list I could find) it could also be 0W40, 0W30 and 5W30, here's just the first few oils listed as 502/505 approved.
Crank but no start 2.0TDi
So the latest update on this, turns out cylinder 1 is over fueling which is causing the ticking, all other injectors have been inspected and appear to be in good shape, looks like I will eventually have to do the other 2 injectors
Power steering (Rapid)
No reservoir is a good clue. Here's a pic of the hydraulic installation; the pipe connections to the steering unit should be obvious, too.
I need Bolero Update :-)
sent in PM
£30 charge for Courtesy car!!!!
They are doing the courtesy or pulling your trousers down and .................
Tyre recommendations
Had the same on my old Octavia. It had budget tyres all round when I bought it with triangle on front and imperial on rear. They had good tread but handling in wet was atrocious as well as particulary noisy. Went with GT radial FE2 and on way home it felt so much more positive and excellent in wet. Why folks skimp on tyres is beyond me. Its the only thing holding you on the road. Alasdair
That is not a courtesy car, that is a hire car. ☹️ Thanks. AG Falco
AGFalco started following £30 charge for Courtesy car!!!!
Radio cutting out new starter motor
Reckon radio should be completely off with ignition off and key removed. Try swapping yellow and red wires to see if it makes a difference. It could also be a bad ignition switch thats cutting power to radio when cranking. Alasdair
DMAC23 started following Heater Matrix Flush??
Hi all please help! SKODA OCTAVIA 1.5 TSI 2018 Interior heater blowing cold driver side and on off hot passenger side, has anyone done a heater Matrix Flush/Full coolant Flush and does it actually work?? Because New Matrix + Labour is approx £600 😵 Is a Flush worth a try?? I can't seem to see any silica bag in my Tank, maybe its there and maybe its split open not sure. What yall saying? Kind Regards
Motor shop says battery is good using tester 78% health.
What have you done to your Kodiaq today?
Hi, I've just switched from summer to winter wheels, with its original rims. Also ticked off the side mirrors automatic folding upon closure. I rather avoid the mirror motors making too much efforts in freezing conditions. Ready for winter!
Yes. You could retrofit torch. But I’ve seen posts where people have put led strip light along back of seats and included a plug so it can be disconnected when folding the seats. You can splice into existing wiring without too much drama.
Retrofit OEM LED Headlights for LHD
@gold , AFAIK @Cairus lives in Austria. It may be a long way from home to bring him your car... 😉
Jack Point
@Legend88 I’m just underneath the car now. It’s quite hard to see, but I’ve had a feel and a look with the endoscope, and I suspect those aftermarket covers do exist for a reason - there’s not a lot of clearance at all! The difficulty will be getting the clips in place, with the pad installed. The cover probably would physically go over it, but you have to push it in to slide the tabs into place, and you can’t do that with the pad installed.
I just fitted a set of FALKEN ZE320 195/55R16 91V XL tires, inflated to 33 psi. I only drove a short distance to get home, but there’s a massive difference in terms of quietness and smoothness. Naturally, I always notice a similar change when replacing old, dried-out tires with brand-new ones, but this time the difference was truly significant—it’s like the transition from walking on a wooden floor to stepping onto a carpet. Only time will tell how they perform in other respects.
Following on from this I stripped the battery tray to gain access to the steering reservoir. Please see pic. NO RESERVOIR !!! I had asked numerous times online where the reservoir was for my year and model Rapid.The code shows 1N1 which indicates a hydraulic system is fitted but 1N3 is for Electronic Power steering. Although the EPS warning has flashed up once the Oil/fluid leak I have been trying to trace is presumably something else. Please give me your thoughts on this.Thanks, Graham 2014 RAPID SPACEBACK 1.2 VIN - <Removed> Please don't post VIN's publicly. This is to help prevent cloning and data theft. Briskoda Admin
face lift steering wheel squib part number.
I am revisiting looking at retrofitting heated steering wheel on my 2019 vrs, I know there are a few thread already on the subject, I have commented on them already. I was wondering if anyone has a 2019 Octavia with a heated steering wheel, it cannot be earlier as there was a change in hardware just before this. If you do, it would be a great help if you could tell me what the part numbers for your squib and columb are. It is proving quite a challenge to find a suitable replacement for mine, seeing as apparently you cannot just replace the squib, you must do both squib and stalks as well. I am happy to be proven wrong on this if anyone has already done this retrofit on a car of my year. My car has: Key barrel not Kessy Cruise control, no adaptive. Multi function buttons with DSG. Finding correct wiring diagrams to figure out how adapt my 16 pin to 14 pin is also challenging, but I guessed if I could get a part number, or numbers of known compatable squib and stalks with heated wheel support, it would be of help.
Got car back from oil change and as always after the service engine is as sweet as a nut. You would think that 0W would hit the tensioner quicker but 5W has more body. The consensus is that the tensioner is tired and at maximum adjustment so a replacement chain, tensioner and sprockets.
Well Marshall in Barnstaple now charge £5 to give the car a quick jet wash and hoover. Used to be free for as long as I can remember. Penny pinching bar stewards. Soon there will be precicely zero reasons to use the main stealer apart from getting software updates for bugs in their computer code during the first few years, warranty claims, etc (which I assume an indipendent mechanic cannot gain access to / carry out).
Thanks for the information. The facelift bumper and headlights are already fitted. The car starts, drives and runs perfectly fine. The headlights also power on and stay illuminated, but the indicators and other lighting functions aren't working correctly. Do you know whether the original BCM and LCM can be reprogrammed, or whether they need replacing? Would you be able to recommend a solution or supply the necessary parts? Alternatively, if this is something you can do yourself, I'm happy to bring the car to you and have you arrange the wiring, modules and programming to get everything working properly. Thanks, Adam
Hi Briskoda!
Hi all. New to the forum and stopping in to say hi. My names Josh, I’m based in London driving an ageing but loved Fabia Monte Carlo 2012. It’s my 2nd one with the previous having the slightly more powerful engine in (until it died hahah) All the best, Josh
JJP2000 joined the community
RogueWagon - 2018 MK3 Sportline Estate
My 2p: Plates: Get motorsport plateholders? They usually come with a million different positions; not sure if you can get ones for shorter plates though; unless you mean without the welsh badge, in which I'm sure you can. I had some nice ABT ones on an old Audi I had and might consider getting some of those again. If you're looking at wheels, look for a reduced offset instead of spacers - saves cost of getting longer bolts and faffing. I'd also not bother so much with 245 tyres although appreciate you're looking at 8.5" wide. They were a thing on the standard 19s due to lower price for a greater footprint, but tbh I never found any real impact and prices have changed now so that 235s aren't any more expensive. Early call: I'll be surprised if you stop there...
Gandalf's Evolution
Yeah if mine turns out half as good I will be happy Given me tons of inspiration and help for sure
