help.. octavia
so update. new turbo fitted, car was showing p0544 egt sensor ,then showed p02458 regen not completed, now showing p02463 dpf . so the egt bank 1 sensor faulty which is causing fault codes p02458 and p02463. my question is dpf obviously has been shut down by ecu to protect turbo etc, once the new egt sensor is fitted will that enable the dpf regen again or will it need flushed out.
MIB 3 SW update
Hard to say, because when I click to SW update/version in long Menu hold, there is a warning it will update.. but I don’t want to confirm because if I don’t have anything in there it can maybe search for some update and get itself in to some sequence. Maybe it is somewhere in advanced ID in VCDS but I am not able to do it now
Wue joined the community
Broke down in my 1.5 TSI - oil in spark plugs
The mechanic is currently stumped as to why there’s excessive suction. You’d hope he’s checked the breather pipe but you never know. I’ll take it off and have a check myself.
SATNAV maps update?
Hi chaps, I have had no problems whatsoever with the software and maps update over the past year, the maps are a bit (about 5 years I should think) out of date though, so every now and then I find myself driving on a new piece of road whilst the SATNAV thinks I’m in a farmer’s field. I think the unit and software I have were the end of the line for my 2013 Superb, but it is worth asking the question: is there any way if further updating the maps without changing the entire unit (which I really don’t want to do… I like the motorcar the way it is)? Alan
interior cleaning - shoes dirt marks
Yeah I'd leave that to someone who knows what they're doing if it comes to repairing physical damage as opposed to ingrained dirt. Heat on interior materials (especially plastics) is something suggested on a lot of forums but its a short-term effect and in the longer term it'll look worse. Check out auto-recon ronnie on instagram - american bloke who's a wizard when it comes to repairing interior materials but he's been doing it since the dawn of time.
Replace all four tyres?
I'm swapping rears to fronts in perfectly workable condition. If I didn't, I'd end up with old cracked tyres at the rear after going through several sets of fronts, even on an AWD when the rears should be chiming-in on occasion. Always been the way except in a rwd 3-series. Whilst I don't disagree that traction at the front isn't essential, I don't think its the "essentialness" of grip in question; we're splitting hairs over when to swap tyres rather than re-educating ourselves away from running tyres bald. So personally, I'd still prefer to lose the front-end than the back. I'd also prefer that to happen if my wife is driving too because the first thing she'd do is lift off and I wouldn't blame her for that.
samturbs joined the community
Why?! For you that's every 2 years.
Finding an Internal drivers door door opener for a Skoda Superb Elegance 2005 in the Uk or beyond!
Hi all, I'm new here but did get some valuable info a few years ago about water ingress so thought I'd give you all another go. I've managed to snap the metal lever which opens the drivers door (well it is 20 years old so shouldn't really be surprised). Anyway, I've tried ebay, Amazon and whole variety of online breakers without success. If anybody can suggest another possible angle on this It'd be most appreciated.
Oracle11 joined the community
I think a leak in air intake manifold would reduce suction in crank case but it could be a blocked breather pipe think goes from engine to PCV? I think there is a one way valve inline. Alasdair
Glow plug warning - No OBD code
Yep probably the most awkward place to put it. Its one of those you can see it but cant get to it. Alasdair
SlabRunner joined the community
the truth about electric cars
^^^ Here we go again then Fire Danger. We will ignore the lack of reported issues where Hydrogen is already produced and used for Transportation on land and at sea. So lets do nothing then. Stay as we were. Waiting for the new technology. In less than 6 posts we are back at being doomed! PS. Have you notices @Graham Butcher how much wasted electricity generation there is now in the UK as not enough storage or transmission capacity and even though Wind & Solar in Scotland can produce many times more electricity than the National Grid wants or can handle? The BEV,s used as a means of Storage for excess production is getting no place fast. Have you noticed the cost of liquid and gas fuels due to matters around the world? Hydrogen Hubs for Low Carbon Transport are still being planned around Scotland.
Well that's a possibility but that too has serious complications in its use, storage and can be extremely dangerous when things go wrong, plus it also consumes massive amounts of energy currently to produce it.
Here we go again after many false starts. Easily generated electricity used to produce hydrogen and off we go with zero tail pipe emissions.
Intermittent AC problem
Some closure for anyone who read this thread and wonder what the problem was. I took the car to a mechanic and it turns out the LIN wire had been damaged somehow and ultimately broke off (see pic). No other cable was damaged and neither was the harness sleeve, so I guess the wire was damaged from the factory (but not enough to completely loose the connection) and then after a couple of years of vibrations and temperature cycles it came off. So most likely bad QC at Skoda unfortunately. Not sure how I could measure activity on the LIN bus leading up to this, maybe the wire got a connection when I was holding it up and didnt tear off completely until the mechanic opened up the harness. Anyhow, the AC is back up and running and my wallet is a tad thinner.
Blue sky thinking out of the box, maybe while taking psychoactive drugs. Lets hurry up and develop these nuclear powered vehicles & until then ban all cars for personal use. No point rushing into things.
Random locking / Unlocking
Good shout. It has just had a service and MOT as it happens so maybe connected to that…
VAG garage recommendations in South Manchester
Strongly suggest a proper load test on the battery - your GFs Polo fault could well be just a failing battery.
Warrior193 started following VAG garage recommendations in South Manchester
Where do the rear panoramic sunroof drains end?
- Random locking / Unlocking
I've known mine to lock/unlock as I'm washing it if I have the key on me, take the key away though and it stops. The only other time I've experienced this was after my MOT last year, when for a day afterwards my car would unlock itself and the alarm would trigger. Went away on its own though after a day and I put it down to maybe they'd disconnected the battery or something during its MOT and not reconnected it correctly? Not sure. But worth checking on the health of your 12v battery I'd say.scotthugh3s started following Random locking / Unlocking- the truth about electric cars
The point I think the video is making is, are we just replacing one problem with another before we have thoughlly tested things out. Are we just adding another form of pollution while still continuing the former? We will still require oil and plastics, so drilling will still be done. Should we have invested more in looking at ways to scrub the harmful emissions from burning fossil fuels while simulatously looking at other technologies at exploring their potentials? So we don't just lurch from discovering that petrol has major issues, then the same again with diesel, and we already are aware that Lithium has some major undesirable effects etc. The post is not a downer on EVs and praising fossil fuels, it's taking an alternative look at devlopments and questioning everything. Just maybe we should all be thinking this way, because that is how progress is made, it is not made by just following like sheep what a few people are telling us. We need to think outside of the box.- Glow plug warning - No OBD code
Thanks Alasdair - I'll check it out. Not looking forward to getting the EGR Cooler out, though - looks like a nightmare job on the YouTube vids I've seen.- Solved-> Overheating problem Skoda Superb (year 2018)
The oil temps still sound a bit on the high side, but not much, probably ~5 deg C higher than I would expect. Oil cooler on these engines is disappointingly small. However, I decided not to fit external oil cooler because if it is impacted, engine loses oil, and some of the roads I drive on are shockingly poor. It is worth also double checking that the coolant mixture is not too rich in antifreeze. I avoid G13 as it really needs a silicate bag to lubricate water pump, and that's another bag of problems when the silicates burst out and block heater matrix. G12++ is my choice, currently use one made by Fuchs, numbers below are for G12++ It's water that's removing majority of the heat and 40% antifreeze is more than enough down to -27degC and up to over +140degC, if more range needed, 50% diluted G12++ works in -37degC / 145degC range. Preventing coolant boiling out is why ECU limits power above 135degC. in general, so long as coolant is relatively fresh, the more water in it, the better it carries the heat out, right down to about 35% G12++ content, after which point corrosion and lubrication might become an issue. So 40%-50% is best range IMHO. The difference in coolant heat capacity between 40% and 60% is about 7%, and if a car is filled with pure G12++ (some people mistakenly think undiluted coolant is best), the difference between 40% and 100% G12++ accounts for about 25% reduction in coolant heat capacity.Dave77 started following Vapos retractable towbar retrofit- Vapos retractable towbar retrofit
I've just spotted this on eBay, has anyone fitted one of these Vapos retractable towbars? https://www.ebay.co.uk/itm/257584097212 A video showing it in use https://www.youtube.com/watch?v=2qE2QlGz11g- TMC traffic events no longer being received...firmware update required?
One solution or grin and bear it. Generally I checked the route if its long distance before setting off. TMC was handy in that it gave you similar information as the boards they use to have up in motorway service stations. In urban areas when you hit a jam you just follow the people ahead who are all taking the same google maps merry go round then filter back on when required. Works for me. Connected Vag cars all come with traffic data built in assembled by Here Maps. Keep your contract going for that and map updates. What I'll be doing when I get a new car, till then check for traffic before starting off and at worst tag onto the Google Maps car conga at a diversion. Alternatively on these connected cars or mib2s / 3s use Android Auto or Car Play. Android Automotive being deployed in the latest Vag cars use Here Maps, have the traffic reports if you take the contract out or plug in your phone if that takes your fancy. That covers all bases except external satnavs that always fell down off the window for me. I like them built in with no messing, trailing wires or over heating phones.- Replace all four tyres?
Yes, but with the way I drive, that would mean rotating every 1,000 miles. I’m not paid enough to do that! - Random locking / Unlocking
