Past hour
Photography Thread
Today
- Amundsen MIB1 Firmware update finally completed - MSTD_EU_SK_P6230 MU0490
Top mount
Made an error when I removed old top mount. I didn't notice which way it was located in regards to the tab where the bearing locates
Top mount
You bolt a piece of 4x2 wood to the anti roll bar drop link connection and jack it up to compress the spring. If you have spring compressors then I assume you can just compress the spring in situ to the same effect. The secret seems to be the positioning of the expansion tool and how you wiggle the brake disc.
Top mount
Thankfully have use of another vehicle. I undone pinch bolt , compressed spring and man handled the shock out. Whats the 4x2 method? As will be doing the other side.
Top mount
I hope you have alternative transport! This is always my fear when doing a job such as this; not having sufficient parts to get back on the road and no way of getting them! Did you split the hub to take the strut out or use the 4x2 method to compress the spring?
oil pressure problem
Oil got expensive recently thanks to Trump.
thsts tomorws job £51 FOR A OIL AND FILTER OUCH
When you say high mileage, how high?
Constant creaking / rattling from the doors of my Kodiaq Mk2
ŠKODA now want to keep my car for 48rs and reapply the grease then keep it in the workshop overnight to see if the noise returns. I have told them that I can guarantee it won’t return after 24rs as the grease resolves the issue until it wears off. Again I’m keen to know if anyone who has this issue has any paint treatments applied. I’m going to have to let them keep my car for 2 days which is a total waste of time.
Filter will do that for you, it doesn't mean there's no debris anywhere. See how it is after oil and filter change.
Ben23 started following Skoda Karoq
oil looks clean
Top mount
So finally got around to tackling the top mount. Total ball ache. Then noticed what you guys have mentioned. A jagged end to the spring. Was at the very top. Just out of site. I did hit a big pot hole a couple of weeks ago . But was on the near side.
mvasev joined the community
kzolee joined the community
Hi everyone, I'd like to share my experience with the same door creaking issue on my Skoda Kodiaq Mk2, manufactured in July 2025 and purchased new in January 2026. I've been investigating this problem for some time, and my observations are very similar to those reported by @Marcinek and @minimumcharacters. Here is what I've found: The creaking noise disappears when the windows are slightly lowered, even without opening them significantly. Cleaning the upper flocked/felt door seals noticeably reduces the noise, although this does not appear to be a permanent solution. I also experimented with masking tape at the contact area between the upper seal and the bodywork, which helped me investigate the source of the noise. My Skoda dealer adjusted the door strikers, but this did not conclusively eliminate the creaking. Based on these observations, I strongly suspect that the noise is caused by friction between the upper flocked door seals and the painted bodywork, particularly when the body and door frames flex slightly during driving. My impression is that the pressure exerted by the fully closed windows may also play a role, since lowering them immediately changes the noise. I believe this is primarily a seal-to-body contact issue rather than a loose component inside the door. I haven't yet found a confirmed permanent solution. In my opinion, the most promising approach would be to investigate the seal material, the contact surface and the door alignment rather than relying exclusively on lubricants. I would be interested to know whether anyone has achieved a lasting solution through seal replacement, anti-friction tape or a specific adjustment recommended by Skoda. Thanks to everyone who has shared their findings. This thread has been very helpful in understanding the problem.
skoda_kodiaq started following Constant creaking / rattling from the doors of my Kodiaq Mk2
skoda_kodiaq joined the community
Ben23 joined the community
Might be debris in sump pick-up strainer.
changed the oil pressure switch; however, when the car is running, the level on the dipstick shows low but stopped its normal oil and filter change tomorrow
Expert help required
Interesting.. thankyou
Battery light 1.0 mpi 59bhp
Thanks, I’ll try that.
Rear springs...replace?
Thanks @Carlston . I have a Greenline model which I think may be lower than standard models for efficiency, perhaps adding to my problems?
Latest Software update information (Recommended?)
Tyres and punctures
I had a screw in one of these "sealed" tyres and it leaked. Had to replace the tyre.
Polisher started following Tyres and punctures
Skoda Scala 2021 1.0 TSI 95cv – Intermittent clutch problem, gears won't engage
Not sure on the Scala but my old octavia 1.9tdi wasnt too bad a job to do once I got everything off. My newer Octavia on the other hand was tricky as some great car designer?? put the DPF and heat shield in the way of getting to it from engine bay. Managed eventually but awkward with my big hands. I used Sachs ones each time and they have caused me no problems at all since changing them. Alasdair
Heated windscreen, or maybe not?
To conclude this topic, having been assured by the main Skoda dealer, an independent garage in my village, and then by Autohaus Edinburgh that it is not a heated screen, I got on to Autoglass and arranged for a replacement to be fitted. On the appointed day I got to the depot to find a different technician to the ones I had spoken to before, standing by a brand new, gleaming, heated screen in a cradle, ready to be fitted. He first took the two trim panels off from the base of the screen, to reveal the two sets of wires and connectors, one at either end of the screen (it is apparently heated as two separate halves) proving that it was a heated one. Then, having first told me that he couldn't do much diagnosis, as he wasn't an auto electrician, he poked about with the connections, including something behind the cover by the rearview mirror housing and doing what he called a 'continuity test', and found that the glass was now heating up a treat, to the extent that with an ambient temperature of 12o C it became almost too hot to touch! This is a tale, then, of several garages and one pair of Autoglass technicians who didn't bother to check things properly, and another Autoglass man who did (and in a very helpful and friendly way). I still feel slightly sad, though, to have had to drive away leaving that gleaming replacement sitting in it's cradle at the depot! Incidentally, after all that aggravation, I now live in a house with a garage for the car to live in, so I probably don't need a heated screen now anyway!
Constant app updates
Well mine has now been cured! Skoda Customer Services sent instructions to my garage when I had my 6 year service a few weeks ago, and updating the car's software from 0276 to 0334 seems to have let the update work. I suspect the old software level wasn't compatible with the update. As a bonus I now seem to have gained a lot of Radio Logos that weren't available before. There was no charge for the update, although it might have been covered by my extended warranty.
