- 2016 Mk3 Octavia vRS 2.0: windows fog up badly after 20+ minutes of driving, no leaks found
2012 to 2019 Superb Refresh
I use the VWG diesel additive, never had an issue with the EGR valve touch wood. I have seen lots that have failed, trying to keep on top of the sludge is the key and turning the ejector nozzle next to the V157 valve must have helped mine, think I posted a how to way back when....
Is this the perfect spec Superb?
Wrong colour and wrong seats to be my perfect one ๐ฎ
RogueWagon started following Is this the perfect spec Superb?
Well, I checked both possibilities, but unfortunately, the results were negative. The trunk (spare wheel compartment) was dry, just as you would have hoped. I also checked the drainage holes in the passenger doors. They were reasonably clean. Not spotless, but all the drainage holes were completely clear. The left rear passenger door (behind the driver's door) was by far the dirtiest of them all. However, there was nothing extreme, which is a shame because I was hoping to find something more obvious. Too bad, but thanks all for your help! Cheers!!
st_ntrelias joined the community
tr3m5 joined the community
- Abs module long coding
Glove box light missing
This Fabia MK2 discussion may be of interest...
Carcathan joined the community
mick25 started following Dongle for code reading & coding
Check oil level warning - level seems fine
According to LLLparts 03C 907 660 M was replaced by 03C907660T. The Hella part number I think should be 6PR 013 680-011 according to autodoc etc If its the correct hella number it maybe a wiring,connection issue. Check for worn or broken wiring. Alasdair
Alasdair1 started following Check oil level warning - level seems fine
Have you read the thread I linked?
Where exactly is the oil level on the dip stick (if fitted) when checked correctly?
I see that you have a TPMS warning up as well.
1.2 2014 Rapid steering light
Before trying to access the reservoir, inspect the gaiters on the tie-rods. Fluid leak might result in one of those filling with PAS fluid and leaking past the clip. If no sign there, then access to the pipework may be best via wheel and arch liner removal rather than from above reservoir. If Rapid is like Fabia, the only thing you'll see from above is the reservoir cap poking up through a hole in the chassis leg. Good for topping up, but not fault finding.
Good morning all. I have recently had the Steering amber warning come up on the dash. I also noticed in a place that I had parked a small drop of fluid on the ground. I assumed it was from another vehicle.I now suspect it is from the steering system .The reservoir is under the battery housing. If I disconnect and remove the battery will I lose all info already in the system. Also,if I am luck enough to find it is a hose leak has anyone changed one of these and if so any advice please. Many thanks in advance, Graham
gswainyboy started following 1.2 2014 Rapid steering light
Cairus started following Abs module long coding
briannac1994 joined the community
Chime after locking and unlocking car
Does the cluster go blank when key is removed and car is locked. When I was working on my sons fabia I left key in ignition and battery went flat over two days. As said it may be a faulty ignition switch and car thinks key is still in it so not shutting down. Alasdair
ล koda Approved Used โ should outstanding scheduled maintenance have been completed before sale?
Your expectation isn't unreasonable, and the Approved Used wording backs you up a bit. On the Skoda Approved Used benefits pages that retailers publish (Marshall Skoda's, for example), the line is "all service work has been completed if due within 6 months, including your vehicle's cambelt", along with the 100+ point inspection and a copy of the report at collection. I'd find the same page on your selling dealer's own website, screenshot it, and ask them for the actual inspection report rather than the A4 prep sheet. That report is what says what they checked. Then it comes down to dates. Ask Worthing to print the maintenance list showing when each of the three items fell due. If any were already overdue, or due within six months of the date you bought it, put that to the selling dealer in writing with the printout and their own Approved Used wording attached. That's a much stronger position than "I think it should have been done". On the fluid question: Skoda's schedule for the Octavia is brake fluid first at 3 years, then every 2 years, whatever the mileage. A 2019 car should show it at 3 years and again at 5, and the next one falls this year, so check the history for both. As yours is a DSG there's no clutch pedal, so there's no separate clutch fluid to worry about. Start/Stop: Approved Used comes with a 30 day / 1,000 mile exchange if a demonstrable fault can't be fixed by the selling retailer. Report it to them in writing now while you're still inside that window, even if it turns out to be nothing more than battery charge. Then it's on record either way, and the 12 month warranty is there behind it.
Sleep pack can be - headrests and you change a section of the door trim for the one with the roller blind cartridge in (and install clips to hook it onto). I looked for that as kids get a fair amount of sun in the rear despite the windows being partially tinted. Went for Snapshades instead - frame with mesh covering but shaped to the rear door opening and magnets hold them in place. Work perfectly and if the kids donโt want them they can take them off and chuck โem on the rear parcel shelf. Come from Oz and weโre here within the week.
Hi. Thanks for the reply Iโve tried the fuse 35 and itโs still happening. Does this video help any better? This is the noise I was on about. Cheers TomIMG_5227.mov
- Are drum brakes rear axles different to disk brakes?
I would have expected the glove box light to be switch operated, on when open off when closed, my 2025 Fabia has no glove box light. Cost cutting.
robsie started following Glove box light missing
Most upset, my V3 L&K written off after a cretin drove into me.
I just did the same as you, I guess. Just downloaded the sheets from the app. And yes, I think maybe the only thing they didn't put on the car was the panoramic roof....!
What a great spec. How did you get the digital certificate? The one I get in the app just shows the service history etc. (2019 model)
Firmware Request MST2_EU_SK_ZR_P0480T
I am searching for MST2_EU_SK_ZR_P0480T too. Can anybody give it to me? Thanks in advance.
lazymick started following Firmware Request MST2_EU_SK_ZR_P0480T
Almost like ours. We have 2018/2.0tdi/4mo/L&K with options. Its missing only TV and Sleep pack. Sleep pack could be retrofitted. Should I? I think TV was not an option in Finland back in the days.
