  2. ashno3 joined the community
  3. Link to download MST2_EU_SK_ZR_P0369T sent in PM
  4. Today
  5. :ink to download MEN2_EU_SKGPx_P0080L_8755 sent in PM
  6. adrianc27 joined the community
  7. H_Kaludov joined the community
  8. Denied joined the community
  9. Dau has wiped the passenger side of my 2017 1.6tdi estate down another vehicle on the M1 (all safe thank god). I'm thinking just replacing the doors might be cheaper than getting them mended & there seems to be plenty on eBay. Clearly, the rear door is specific to the estate but what about the front? Are the saloon & estate the same? I can swap all the internals inc wing mirror so I'm assuming trim won't matter, just the race blue paint code. Simon
  10. Yesterday
  11. Shkodal joined the community
  12. @pab567 hi pls you can sent me the link to the MEN2_EU_SKGPx_P0080L_8755 download. I have a massive problem with connecting ani android Phones and androidAuto. The USB connector is ok, cable is ok android & androidauto is uptodate. I don't know what else I can do.
  13. ah, seems these HEROs have the vague guide I need! https://www.youtube.com/watch?v=pRWqAoYIfCI
  14. The springs lowered the car 20 mm. The rims r Rotiform LAS-R 19x8.5" ET35. Tyres r 245/40R19.
  15. First check that the microswitch in the door is giving a signal to the system by checking that the door open icon is showing on the display when you open the door. Is the passenger door and rear doors the same?
  16. App doesn't offer this functionality on older mk 4's, mine from 2020/21 isn't supported
  17. Hello everyone. My question is: the interior lights don't come on when I open the doors. What should I check, and how? Could it be that the panel in the overhead trim needs replacing? Thanks to everyone for the help. @Isu1977 Kérjük, vedd figyelembe, hogy a Briskodán az angol az alapértelmezett nyelv. Hozzászólás írásakor kérjük, használj fordítóeszközt.
  18. alanOcty replied to mistac's topic in Škoda Elroq
    Went for Graphite Grey metallic. Staying low key, although was tempted by the velvet red!
  19. Here is my UK 2026 2.0d 150 SE L. Love it so far. A few frustrations with some of the tech, but thats the nanny world we live in now I guess.
  20. Hi there, thank you for accepting me. Its great to find an old school forum for the skoda. Just bought a mk2 Kodiaq Sel 2.0d 150 back in September so its a 2026. Loving it! Sold my 2014 mk7 golf in 2021, went to a focus estate, biggest mistake of my life! Glad im back in the VAG family. Looking forward to getting to know the community. Catch you soon.
  21. Appreciate that! Always handy to know someone with tools like that
  22. Derk2d2 joined the community
  23. Typically you don’t bring 6 year old threads back…. That said are you doing long or town journeys? If short journeys then the first few miles when cold use much more fuel. Otherwise check tyre pressures and try replacing the fuel filter and air filter. The number of diesel’s see thumping out plumes of smoke, because the filters clearly haven’t been maintained. One other thing to check would be that the oil/filter have been changed and you’re not driving around with treacle in the engine.
  24. Skoda dealer will definitely be able to print you off the build sheet from Erwin. I used to have access but my account got revoked as they don’t allow private people access anymore. I did manage to download all the workshop manuals for superb if you need any. Won’t have your engine and gearbox but all the rest will be relevant.
  25. That’s mad. I was speaking to Skoda HQ today. Trying to find out all the build specs for it. Not sure if the buckets are heated. Collect weds morning and can’t wait!
  26. If the situation requires you not to take your electronic key, why would you take a tablet or smart phone with you?
  27. Also. Fun fact. Your reg starting with K makes it likely it was a car of VAG management as it’s first owner.
  28. How low are the springs? What’s your wheel specs for aftermarket. Looks what I’m after!
  29. RogueFabia started following Lowering Springs
  30. Hi I have the same problem here 40 mpg I’m expecting 60 mpg at least
  31. I also see it makes sense, however it still came as a complete surprise. Bit like when I had a BMW 5 series and tried to reverse into a part of our drive, opened the door to lean out and look back and it slammed the brakes on. I’d been doing that trick for decades when it was needed, but not in the beemer! Will try that in Skippy when I get back from Morocco. 👍
  32. I also upgraded from a Fabia although I that was a downgrade from a previous superb. Eibach pro kit is the go to for lowering. Have a search on this forum and there’s a table to choose the correct kit. Not done it to mine yet but it’s on the cards potentially. Lots of things you can do on a relatively small budget. Mostly mine has been fixing up issues plus some styling mods including all LED bulbs. Made my SE L into a sportline lookalike.
  33. caocongtien48 joined the community
  34. UPDATE: 2 weeks on from the crankshaft sensor replacement and , touch wood, no sign of any issues. If things change, I will let you know. Thanks for all the advice and input, its much appreciated. Tony
  35. @pab567 It looks like you’re the guy to help with possible CarPlay upgrades. here are photos of my hardware, software, and firmware packages. Is there an upgrade path for my 2016 Octavia Mk3? VIN <Removed>
