  2. Wires in door are fairly easy to repair but a lot of folk just join at the break. I normally splice in a new section of wire a good bit before and after the break as you get more flexability as solder tends to make section of wire rigid plus chances are the section of wire thats broken has been flexed over time and become weak. If the windows are temperamental and door lock doesnt operate it may be just a wiring issue in the drivers pillar/door. I would check wiring and repair first and see if things go back to normal.
  3. Simple really, best wait until there are Cars on Display at Dealers or Shopping Malls that can be sat in at least if not until there are Demonstrators to drive, otherwise you might have buyers / leasers remorse for 3 years.
  4. First you have to patch it using More Incredible Bash. Audi systems require licenses for map updates. More Incredible Bash will write the lifetime map update FEC that’s default on Skoda and VW as an example.
  5. I’ve been having this issue for a few months now, constant updates for the store. I let it update, I get successful installed but it always reappears every single day Anyone else have this?
  6. Nebb started following Constant app updates
  7. Today
  8. While 473 would be nice, I am very happy with 453 as it has removed roads that no longer exist. It is silly being directed down non existent roads. Now I have another issue that I need guidance with. As we know from my previous screen shot, 453 works in my Škoda Columbus very nicely. I have a friend with an Audi MMI Navigation Plus (MHI2Q_ER_AUG22_P5092) with very old maps in it and as viper42 says the FeC for Audi is in 453, and MIB Helper says it uses the same map package as my Columbus, I thought I would update his maps. I put the SD card in slot 1 and the unit spent a minute or two looking and then decided it couldn’t find the data. So, we have a NZ new Audi with (old) NZ maps in it, so the region should be ok. We have a package with the Audi FeC, so that should be ok. We have an SD card with a working, proven, copy of the package, so that should be ok. Can anyone see any reason why the Navigation Plus can’t see the data? Thanks.
  9. LivornoBart joined the community
  10. You welcome 😊
  11. BlueBear7 joined the community
  12. Yesterday
  13. Four 5E0601151 FOD hub centre caps are listed at 42.91 Euros (about £36.87) including shipping to the UK, on "skoda parts com". 5E0601151 FOD hub centre caps (42.91 Euros is about £36.87) https://www.skoda-parts.com/spare-part/5e0601151fod-wheel-hub-centre-cap-with-a-skoda-logo-skoda-19744.html
  14. Carlston started following Wheel Caps
  15. Broken wires in the body to door trunking are common on higher mileage cars.temperature Also a failed lock on the drivers door. The drivers door lock replacement is expensive in labour as the inside metal door panel has to be drilled out to remove the window mechanism in order to replace the lock. I know because my window winder failed and I had the intermittent lock replaced at the same time (temperature sensitive failing microswitch in the lock). I suggest you talk to a good auto electrician for advice. Mine says he regularly replaces locks, particularly on Audi A3s. He frequently fixes broken wires to the driver's door. Same with mirror controls but another cause for intermittent mirrors and window winders is the switch assemblies. Relatively cheap to replace as a diy job.
  16. After a two year gap on “other” brands, I’m back with my 7th Skoda, which will be a 2019 Superb Estate Sportline with a 1.5tsi DSG. Its main duties will be carting one or two MTB about (inside) and taking us, our Labrador and grandchildren in various combinations on days out and holidays. On the test drive for the Superb I realised that I’ve really missed the Kodiaq that I sold. I’m impressed with the DSG in the Superb compared to the one I had in a 2012 Octavia VRS. Seems a lot smoother, but perhaps I “enjoyed” the VRS rather differently. ACC and DSG is a very interesting combo in traffic. Can’t wait to try that out properly. Forum is still a great resource. Thank you. 😎
  17. 1963Malc started following Hello, again
  18. I turned it off on my 2023 280tsi via the Gateway module using VCDS as above.
  19. Deer at Calke Abbey this afternoon 1010338~2.mp4
  20. DogBook replied to BlueDun's topic in Skoda Yeti
    3rd agree, should be attached to the exhaust as they look like dampers to me. Also there is no tray, they go into a cross member between the subframe. Thats without looking at a parts list.
  21. Hmm, with the dpf deleted wouldnt the car smoke a lot and blow big black clouds of exhaust fumes out the back, with that kind of oil consumption. Personally wouldnt want to be driving behind your car...the exhaust fumes would smell really terrible and couldnt see **** for a while🤣. A working dpf really makes a difference, the diesel exhaust stays clean and doesnt smell anything like the old diesels did. Also in my country its illegal to delete dpf, if you get caught, the fines you get from doing that are counted in thousands of euros.
  22. Great stuff. That is pretty damn new and by the sounds of it has an impressive spec list... I'm sure you'll enjoy your ownership.. Nicely done.
  23. I put all the details in lightning adaptations in Leuchte23SL HLC10, Leuchte24SL HRA65 and Leuchte27NSL RC6. First unlocking the car successfull😊 animation worked as it should. Closing the same. Then when I unlocked the car again went back to static. Locking still OK-animation works OK. I'm not sure if there is other module than Lightning Adaptations where animation of tailgate lights is controlled.. I will try, thanks Cairus. This backup has a lot of useful information 👌🙏 Obviously changes made with ignition on, engine off, bonet opened. After coding scanned for errors and cleared few archived ones, reset lights in car menu-factory reset-lights, infotainment reset and car left for 20 minutes with key away from it...
  24. Hello. I need help. I would like to update my car, but i got NO idea how or where to get the software. I am quite a newbie in this lol Number is 5Q0035840A Hardware: H24 Software: 0245 Thank you!
  25. vallhala joined the community
  26. Won't adding front parking sensors also require the PDC module to be changed from a 4 channel one to an 8 channel one?
  27. Hi. I am from Turkey. I want to make an expert install the navigation. I checked update portal to be sure that whether there is map update or not. I entered vin number but it showed that there is no new map data. Is there anybody to explain the problem.
  28. On my early Mk4 (2020) there are options to change colour and brightness of the ambient lighting; I assume similar on the newer FL models so maybe check for the brightness settings.
  29. DanHot joined the community
  30. How do i activate my ambient lighting? I can get the spectrum to show up and I can change the screen background but there are no lights on the door strips or across the dashboard. I have the free month trial of Ambient Lighting Additional Colours and Ambient Lighting Additional Features installed from the My Skoda app and activated, but nothing lights up. Can I get rid of or change the red ring around the 2 circular dashboard dials?
  31. 2024 Skoda Superb 1.5 Tsi Se Dsg Estate
