Kodiaq Seven seater and space saver spare wheel ?
There are two "foam and jack kits" (which includes everything except for the actual spare saver spare wheel, for the Kodiaq MK2. One of the "foam and jack kits" is for the Kodiaq MK2 5-seater and the other is for the Kodiaq MK2 7-seater. Both kits are only for a 145/85R18 4Jx18 ET28 space saver spare wheel. Foam and jack kit (Kodiaq MK2 5-seater) 57H093860C https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola-18/p/57H093860C Foam and jack kit (Kodiaq MK2 7-seater) 57H093860D https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola-18/p/57H093860D
Carlston started following Kodiaq Seven seater and space saver spare wheel ?
Brake pads installed wrong in the past?
They are sided in that the one with crescent cut out go behind the disc and the one without goes in front of the disc.
Are the brake pads sided or are they all the same? Thanks. AG Falco
AGFalco started following Brake pads installed wrong in the past?
Can’t complain about this mpg.
My 2024 1.5TSi SEL DSG Karoq averages 50+ when cruising on a not busy motorway at an indicated 70-75. My Leon FR 1.4TSi FR DSG would show 53-54. I suspect that's the affect of the Karoq's larger frontal area. Normal driving around the Cotswolds drops the Karoq to anywhere between 42 to 45. The Leon would be 45 - 50. The extra weight of the Karoq is against it when accelerating or climbing hills. It is noticeable that the Karoq is often 1 gear lower when climbing particular hills than the Leon would have been at the same speed. The 2 engines seem to have identical power & torque figures & curves although the 1.4 was smoother & quieter. Perhaps 50k miles against 10k may explain some of that.
VRS Mk1 crankcase ventilation system
Adding a Oil Catch Can is a great idea, it helps reduce oily air coating valves, piping, turbo impeller vanes and the intercooler. When I fitted mine in 2010 there were not many to choose from I opted for a Saikou Michi one from the USA. See my engine pic' its located bottom right, I made up a small bracket to mount it. 19mm diameter lined silicone hoses are the size recommended for the 1.8 turbo. Another useful mod is to replace the stainless charge pipe that dives down behind the engine on the drivers side. It has a push on connection & o ring retained with a c clip. My one kept leaking and coming off so I replaced the stainless pipe with 06A 145 731D , (there is one on e-bay). The lower end just pushes into a new silicone hose (Creation Motorsport). Dean quoted Bowders 1 post, he was a trail blazer for VRS mods for us all and posted many good "how to " posts and is a good source of reliable info. Good Luck Peter
Changing the front badge and rear lettering on 2020 Fabia colours edition
Thanks Everyone!! Great help, ordered everything and its all here..cheers again
- What does this symbol mean
MintyPanda started following What does this symbol mean
Exterior bulb warning light after car wash (2011 Octavia) - Wing mirror LED?
From memory I read there may be two w3w tail light bulbs in each cluster on rear think its the MK2/1z. Not entirely sure but worth a check. Perhaps one has blown. Alasdair
Griff_The_Biff joined the community
Thanks both, they were pretty corroded, once over with some contact cleaner, no change. (But they not looking great anyway so might change alongside the indicator and see what happens.
Chassis cover protecting fuel tank
Doubt it but heres a link to lll parts diagram. Cant work out if it just clips in place or requires bolts. The part number you gave is no 75 on diagram. https://www.lllparts.co.uk/product/5wa201429/trim-for-fuel-tank-5wa201429 Alasdair
Alasdair1 started following Chassis cover protecting fuel tank
Fabia 2 windows stop after 10 minutes.
Yes, the metal casing. Remove electronics first, by defeating the 6 plastic clips with toothpicks or similar. Then undo 4x torx screws, carefully pull out metal housing with rotor and brushpack all together. Pull brushes outward off commutator and spin the brushpack 180° relative to metal housing. Reassembly in reverse order. 6Y1 label will now face the opposite way, and the permanent magnets within the metal housing will be oppositely oriented. Better not to pull the rotor out of the metal casing as the bearing at the closed end can be tricky to realign the shaft into.
Do you mean swapping this 180 degrees? Sorry app playing up. Would be nice to get up and down the coorect way. The wiring diagram I have doesn't show what's happening at the motor. I have swith and control unit but can't work out what controls motor run direction. Given up today as its too hot! 😂
Update applications Kamiq
I'm usually driving at the time, so your saying I have to be parked up to update
Hi, Beezy, Pete. Got this motor and the windows do now work. However the drivers one is still incorrect for up and down. The wrong way round. So do you mean swith the motor body around by removing the 4 screws and turning the metal casing a
You cannot normal update while driving. Park the car where there is good signal. Ensure you are not in max privacy mode. With the ignition on activate the update process via infotainment. Wait for a message telling you it's finished before starting the engine. Normally turning off the ignition and locking the car halts the process.
Scala SE L 2024 Infotainment unit updates
We have a 5 year old Golf, it still gets OTA updates. You must have a registered MY VW account with VW for this to happen. It's the same with Skoda and I also get occasional OTA updates. You must also not be set to max privacy. In both cases if you wish to get the extra information about traffic and map updates you must not only be registered you must pay a subscription after the "free" period expires. Most OTA updates require that the car is not moving. It must be stationary with the handbrake on (in P if auto). The alternative, as mentioned above, is to have the dealer do it. Since the OTA updates never take more than 30 mins a dealer connecting it to VW computer should not take 2 hours!
I am shortly hoping to pull the trigger on a new Kodiaq SEL seven seater TDI AWD. This will be my first Kodiaq after three Superb's, all of which lived up to their name perfectly. The Skoda website configurator allows me to select an optional space saver spare wheel, which is what I need, as every year I get one or two punctures, usually in the middle of nowhere. However, the brochure says that a space saver is not possible in a seven seater. Assuming the brochure is correct and the configurator is wrong, has anyone managed to fit an 18 inch space saver tidily in the rear of a seven seater with the seats up or down? With the seats up, is there enough space and secure tie downs in the boot for a space saver? I am not concerned about appearance. I will be adding a few options, so it will be a factory order with projected delivery in November.
Long coding for ECU 03 Brake Electronics Skoda Fabia 2011.
Will a Skoda Main Dealer be able to provide me with long coding for my ECU 03 Brake Electronics Skoda Fabia 2011.
Melco started following Long coding for ECU 03 Brake Electronics Skoda Fabia 2011.
+1 for intermittent number plate bulb. Check the contacts.
Strings joined the community
Inexplicable tyre deflation - no puncture, valve OK
My experience of the major tyre fitting places is that they don't want to do a repair. Instead they want to fit a new trye even though the faulty one is repairable. I always go to my local independent tyre fitting place which is more or less within walking distance. Never had a problem with them.
"Convenience" window opening with remote stopped working.
This might be an old thread but it still works a treat. Many thanks for helping me sort out a frustrating problem✋
JacobSladder started following "Convenience" window opening with remote stopped working.
My 2017 2.0 diesel Kodiaq 4X4 with manual gearbox has a transmission noise.
Sorry for delay on returning to the thread. Car now booked in for repair. Problem diagnosed as being from a module at the back axle.
This particular trip is done regularly over the last 10 years. Outbound is south on the M1 and east on M25, prevailing wind is from the west and outbound is generally better mpg. I leave the aircon (climate control) set to auto and just vary the actual temp setting currently 20c , when the weather cools down it will be lowered to 17/18. @Gerrycan I’d agree the 1.0 or 1.5 would have probably exceeded 60 mpg under similar conditions. I was predominantly in the left most lane, fewer vehicles, the three lanes to the right weren’t moving much faster and had many more vehicles on. What I did notice was when an artic container lorry pulled in after overtaking the instantaneous mpg jumped from 50 ish to 70 to 80 on the flat.
Always difficult to comment on one-off journeys, especially when quoting the display figures (unless confirmed to be accurate against measured refuels) but yes, a 52mpg return from a 2.0tsi would be pleasing. I'd estimate that a 1.0 or 1.5tsi version driven in a similar manner/environment as you describe would probably get around 60mpg as the 2.0tsi is a nice performance engine but not particularly economical. With regard to fuel, the general published consensus is that if your car is capable of adjusting to better quality fuel then you can expect about 1% improvement for each increase in RON rating and a little more if the better-quality fuel has lower levels of ethanol than the mandatory 10% in UK 95 RON fuel. Ethanol has 10% lower energy density that 'pure' petrol.
- Skoda caraq select 2l diesel towing
