  2. Broken D3S xenon bulb holder!! The last few months I started to notice the beam of the right side headlight was looking a bit off, not as bright and a faint vertical line right in the middle where there wasn't much illumination. Initial thoughts were a failing bulb, which I only replaced approx. 2 yrs ago with LED ones, or the bulb was out of its holder/socket. Turns out it was the bulb holder that was broken!! It normally holds the D3S firmly in the socket with a twist to lock it in. Mine was sitting loose, hence the bulb was not in its correct position, resulting in poor light output. Somehow the bottom hinge had broken. Was not fixable, hence a replacement holder was ordered. Part No. 9FH 161 097-016 All fixed now. The right side beam is now as it should be, again. p.s. mine being a pre-facelift with SLA headlights (version B), it uses a different mechanism to hold the bulb. Version A headlights use the spring clip method. Broken one on left. Replacement on right. How it sits on the D3S bulbs....
  3. Hello everyone! Can anyone help me find long coding for ECU 03 Brake Electronics Skoda Fabia 2011. Please see attached details Image removed due to vin visible. Please crop and attach the error code only
  4. Hi all, fairly new to skoda ownership after years of vw. Recently bought a 2015 vrs tdi estate and occasionally I'm getting juddering when braking. Feels like a warped disc but doesn't do it every time I brake. Sometimes does it a low speed and sometimes from higher speed but no real pattern. It's a 2 owner car with fsh. Has had discs and pads replaced fairly recently before i bought it. All calipers are free, I've cleaned everything all pads slide freely etc and there are no ABS fault codes logged. Any ideas gratefully received.
  5. The Kamiq owner's manual only lists the 16" winter wheel size for use with snow chains (with links and locks that are no larger than 13mm), ie. 195/60R16 6Jx16 ET35...not the factory fitted 205/60R16 6Jx16 ET38/ET40 wheel size. The alloy rims on 215/45R18 7Jx18 wheels have very little protection from kerbing damage (because the sidewalls don't bulge out much), so are probably best avoided if deep snow is hiding where the kerbs are. Winter wheel size (Kamiq) 195/60R16 6Jx16 ET35 Factory wheel sizes (Kamiq) 205/60R16 6Jx16 ET38/ET40 205/55R17 6.5Jx17 ET40 215/45R18 7Jx18 ET39 Actual inflated width of tyre (measured on the outside of the sidewalls, at the widest point) 195/60R16 6Jx16 ET35 201mm 205/60R16 6Jx16 ET38/ET40 208mm 205/55R17 6.5Jx17 214mm 215/45R18 7Jx18 213mm
  6. Today
  7. Hello there. Recently had the check engine light up on my 2004 TDI Skoda Fabia. Friend of mine had a code reader and found two faults apparently. First one is 17911 Load Signal From Alternator Term. DF: Implausible Signal Second is 17571 Fuel temp sensor short to +ve / open error. Previously there also have been recent problems where I had to replace the battery for being drained and front lights several times for burning out. From what I've read both faults can be led back to faulty wiring or connector issues but the other problems make me believe the issue could be also with the alternator. Any way to check the cause without replacing parts?
  8. Hi Everyone. I know this is an old thread - but I’m having a problem getting the aerial mast out. It turns only so far, then turns on the thread without coming free. When you say ‘yank’ it, how much of a yank are we talking about? Only want to replace the mast as the rubber has perished, and feel a yank might mess up the aerial base. Thanks.
  9. Hello there. A new owner of an older car, here to learn a bit more about my car.
  10. Jed_Blace joined the community
  11. Alasdair1 replied to royread's topic in Skoda Karoq
    Been using Fram,Febi/blueprint or Mann which ever is cheapest for years and no probs. I use standard oil not longlife so it gets changed more regularly including filters. Just avoid any cheap ones that you have never heard of. Alasdair
  12. Depends if you can fit two prams or pram and buggy plus luggage. Daughter has volvo v40 which is only slightly shorter than the karoq and just gets the pram in boot. I would have a look at both load space in rear. As previously mentioned have a look at Octavia estate. Its got a big load space and slightly shorter than kodiak. Alasdair
  13. Just used the method above to restore the convenience window on my 2020 after they stopped working.
  14. There were only two TMC providers in the UK. Both have pulled out now. The VAG / Here Maps traffic offering is only available through connected services.
  15. @Tznofl I can vouch for Kieran (East Yorkshire Retrofits) who ran the full update package on my 2020 Octavia 4 as it's performed flawlessly since. Will save you a lot of time, hassle and money versus going to a dealership
  16. Hello, I’m posting on this forum to see if anyone can help me. I have a 2015 Skoda Fabia; I’ve never updated the radio, and recently it’s been giving me a lot of trouble with Android Auto error 8. I was wondering if there might be an update available for my radio. Many thanks in advance. DPN - 5Q0035840A Hardware - H25 Software - 0245 Media Codec: 2101.0.0.10
  17. 9083ja joined the community
  18. Probably as you said not put back on securely which would explain the whistle noise. Glad you got it fixed. Alasdair
  19. If you disconnected battery the steering and esc will come on until you turn full left and full right plus a short drive. Looks like you may have to remove bearing and clean or replace. Alasdair
  20. Does anyone know if it's possible to switch mib2 /mib2.5 high to use Here TMC in UK. If I good remember ford sync 3 used Here through TMC and never noticed issues.
  21. So if i'm lucky i can find one online and if not, a creation of a new plug is required ok ok thx for the help
  22. Just an update, I've checked the alternator pulley and other pullies around that area, all seem tight, belt looks tight, OK from what I can see. As they're not easy to inspect, due to their location. Unless you were to go from underneath. So Ill keep an eye on it, if it becomes worse, be easier to diagnose. If I do get to the bottom of it, I'll post on here, again.
  23. Beige88 joined the community
  24. Yesterday
  25. There’s an update to take the system from 16xx to 18xx via 17xx (2 updates in one) Then a separate update to take it to 1985 It’s likely your car has a boatload of software updates outstanding which should all be completed at the same time to ensure a compatible baseline. Visit a specialist - we can help
  26. No, Firmware 17Xx-->18xx-->19xx-->Last Firmware Also you have To Check the OCU Firmware
  27. Ah! Just looking on YouTube, and what I thought were plastic flaps, are probably actually bits of the magnetic ring on the bearing! https://www.youtube.com/watch?v=QeILfoNK9q0 (That's a Karoq, but I think it looks very similar to our Kodiaq)!
  28. Very helpfull, thank you!
  29. I know it is the hight of summer with heat wave 100...., but I would like to check if anyone has used snow chains on a Kamiq. My daughter's Kamiq SEL runs on 18" alloys. She has got all-season tyres fitted to the 18" wheels and might need to fit snow chains. The Skoda manual recommends snow chains only on the 16" option. I have seen on the www that you could use thinner 9mm chains rather than 12mm for low clearance on 18" wheels. Is there anyone who has done this successfully?
  30. So... ...that went well...🙄 Replaced the ABS sensor this morning, and now I've got FOUR warning lights! ABS, ESC, steering and TPMS... OBDeleven is still saying right hand front ABS sensor. When I took the old one out, I could see a few fine scratches on the tip, and peering down the hole it came out of, I could see quite a lot of flaky rust, so I scraped that off with a small screwdriver, whilst slowly turning the hub. I also noticed what seemed like a number of small, black plastic "flaps" on the vertical face just outboard of it. No idea what that face is?
