  2. most tuning companies can remap once the ecu is unlocked but at the moment [ bearing in mind that the technology to unlock bosch md1 / mg1 ecu's has only recently been available] At the moment very few companies can or are willing to unlock themselves, but that is likely to change in the future, so most tuners are outsourcing, it's not just because they dont have the equipment or know how to do it, there is a risk when unlocking of bricking the ecu and with some ecu's a resistor has to be removed and re soldered etc and at £2k+ for new ecu's, it's a risk they are not willing to take.
  3. Is this with a manual gearbox? If the problem occurs only when using SS, it could be due to a problem with the clutch pedal sensor (if manual) - or the shift position sensor if DSG. When this fail to restart happens when using SS, does a message like 'start engine manually' display on the cluster?
  4. Your software is the latest version. Your maps is outdated (yours is January '25, as identified by 25.1) The latest map update is from within the last few months. You can manually download and install map versions, search the forum there's plenty of discussion on the matter
  5. Did you find your air con pressure sensor as I am looking for mine at themoment
  6. Wel joined the community
  7. The 2015 Octavia uses a Tyre Pressure Loss Indicator, not a valve sensor, so a false alert on the same corner can happen without an ABS or ESC warning light. After you have set all four tyres to the handbook pressures, store the values. Ignition on, then either CAR, Vehicle status, Tyre Press. Loss Indicator and SET, or press and hold the SET key until the warning light comes on, a beep sounds and the light goes out. If it still flags the rear nearside after a stored set, have the NSR reluctor ring and ABS sensor inspected for cracks, dirt or corrosion, and compare tread wear and tyre size with the offside, because the system is comparing wheel speeds. A lingering malfunction light can be an MOT Major on a 2015 car, so it is worth finding the cause rather than just clearing it.
  8. Today
  9. Didn't you know? All Skodas have a heated rear screen to keep your hands warm when pushing them 🥸
  10. I have only had my superb for 10 days but have never managed to get anything when swiping down from the top of the screen. Is this only available in certain displays or should I be able to to it whatever screen is showing?
  11. BillyParker started following Média display
  12. Have you tried to listen when the vehicle is at operating temperature but engine stopped but with ingition ON. The LPFP should be running, if you have the noise like that and it stops as soon as you go ignition OFF, you'll have your answer ;)
  13. 5 hours in total does seem high especially as they have lifts and should have the proper tools. The fact that the wheel is off centre and pulling slightly isnt right. I reckon something is out of alignment or the steering angle sensor needs recalibrated. Did my old Octavia in around 2 hours but its an old rusty car so nightmare to take apart but didnt affect steering etc. May need a wheel alignment check and if they are ok then steering sensor recalibrated. I would get them to check it over ASAP in case something isnt tight plus depending on whats wrong tyres may start wearing badly. Try full lock left and then right and hold for a few secs each time to see if it helps. Alasdair
  14. Hi, thanks for your message, no I haven't, but the issue only occurs when the start/stop system is operating, and then only following frequent restarting in traffic. Apart from then starting a hot engine is never an issue. I am going to have the battery checked, I use the car infrequently and I don't know how old the battery is (pre-owned vehicle). If the battery is in poor condition I'm hoping a replacement will correct the issue. If not, I'll go with your suggested action. Thanks again.
  15. I would not imagine there is a manufacturer today that still makes a car without a rear heating element in the glass ... even the most basic utility vehicle available here that is not a van has them, even basic vehicles like Lada Nivas and UAZes ... Now if instead you refer to the fact that the front is like "instant defrost" across all the glass and not in "lines" starting from the filaments outwards, yeah, I agree ... There are very few cars with the multi-filament option, I remember old Mercedes have that (mine W126 has it), but it is prone after time to "delaminate" which looks awful and for which there is no solution except replacement, which is not longer costly, is just impossible as there are no more glasses available .... ☹️
  16. Well, at least you got the car corrected and with the right equipment! 😉 Heads' up for knowing ... incidentally I found a stone chip on mine, which means will have to face the replacement procedure ... I already told my insurer about it and he said 'no problem' - I got coverage for this in my insurance, but I will have to face the matter as I want a genuine replacement 😬
  17. Pretty sure there’s a lot more than two companies. I know Darkside do it, although it is an additional £350 charge. Not sure if they unlock it in-house or outsource it - you’d have to ask them.
  18. I actually saw a video on this the other day. I want to say it was TikTok. I’ll have a look - but IIRC the guy was saying that the system was giving false alarms, but that both the ABS sensor and ring were absolutely fine!
  19. What he said. You can get it done by specialists, but the people I know charge basically the same as the dealer anyway. It’s one thing to replicate the physical key blade profile, and another to do the RFID chip.
  20. the rear hatch window normally has heated elements, i.e. demister. i don't know if this was an option in some markets or specs.
  21. Hi Alasdair I'm still waiting to get a full response addressing my query from the garage. Apparently they're looking into it. In the meantime, thank you for your comments. Just to expand on the points you've mentioned. Possible Problems? - On failing the MOT the garage rang to give me the bad news and gave me a quote for replacing both CV boots. I presume at that stage, no attempt would had been made to remove the old CV boots so it wouldn't be known if the job might turn out to be anything other than straight forward. I presume the job did turn out to be pretty straightforward as my invoice shows no difference in the time taken and charged for replacing the CV boot on each side. As per my opening post, the garage didn't mention any difficulties were encountered carrying out the job, either on the day of the repair or since. Number of hours Charged? - The invoice shows 2.50 hours labour charge for each side (Not Both). Travel Time Included? - There wouldn't have been any as the MOT, service and the repairs were all carried out at the same workshop location. Road Test? - I'm not sure. However, since collecting the car it is pulling to the near side and the steering wheel is off centre, neither of which occurred prior to the day. I presume both these things would have been picked up during a road test. I've advised the garage of this in my email queering the invoice price/hours charged. Alignment? - I wasn't informed by the garage of alignment being carried out, and there is no mention of it on the invoice. As mentioned, the car is now pulling to the nearside. Anyway, thank you for your interest Alasdair. I'll update on here when I have more news.
  22. Yesterday
  23. staticshock joined the community
  24. Good effort getting them both from the top! Coolant use has slowed a bit since doing the bypass, but still having to top it up, might just be air purging out. I did run the coolant bleed though so should have got most of it out, but didn’t vacuum fill it or anything
  25. Is yours a hatch? Does the hatch not have a heated rear screen?!
  26. I’ll send you a message with link to the manuals which may help.
  27. Did you find out what was up with yours ? I managed doing the bypass from top of engine but deffo needed a 21 or 22mm connector because the coolant hoses where a bit slack on the 19mm but I fastened them on with jubilee clips really tight so hopefully will hold .
  28. I just finished work and the windscreen was frozen…. 1st time using the heated windscreen… wish the rear screen had the same system
  29. A few recent photos....................
  30. Made an error when I removed old top mount. I didn't notice which way it was located in regards to the tab where the bearing locates
