Glowplug prices - having a laugh
Just replaced cylinder 4 with a £13 Bosch 0250403009 direct from Amazon. It was a Bosch 0250403007 that came out. Looks like Beru (another OEM) go for around £100 on ebay for the pressure sensing one. Bosch seem to be around £135. I find ECP expensive these days, even with an essential code/deal. https://www.ebay.co.uk/itm/336472172965 Bosch seem to be around £135, but I see a full mixed set for £140: https://www.ebay.co.uk/itm/286741811628 I soaked it in wd40 for a few days then got the engine to temp at removal. I might just have been lucky, but once it cracked, it was finger tight.
8755 Software Update - Skoda Fabia 2019 Carplay Issue
FYI: If you're updating a MEN2 unit and the firmware SD card is being rejected with an "SD/card reader error", try starting the update from the extended setup/service menu instead of using the normal "Update software" option under Setup. On my 2019 Skoda Fabia with MEN2_EU_SKGPx_P7381L / MU 8740 / HW 690, the SD card worked perfectly for playing MP3 files, but the normal software update menu kept reporting an SD/card reader error. The solution was to press and hold the SETUP button for about 5 seconds to enter the extended setup menu and start the firmware update from there. The exact same SD card and firmware files were then detected correctly, and the update to MEN2_EU_SKGPx_P0080L / MU 8755 completed successfully. The update also appears to have fixed my CarPlay audio crackling/distortion, which previously started after about 30–40 seconds of playback. Hopefully this saves someone else from repeatedly reformatting SD cards or assuming their card reader is faulty.
Silencing the loud spoken traffic congestion warnings
I believe traffication is subscription service, free for first year. If I recall correctly I think it cost £4.50 per year and you pay for it through the ŠKODA app. Look under PROFILE -> PAID SERVICES
- Codes 00883 and 00668 Octavia 2007
Jonnytange joined the community
Skoda Superb iV - Factory paint thickness specifications / tolerances?
- Adblu reducdant sensor
Search for adblue delete. Not sure where in the country you are but this was the first hit on google. Not a recommendation. Skoda AdBlue Delete | NOx Delete | SCR Delete | LeicesterSkoda Adblue Removal Specialist in Leicester. We offer custom Adblue / NOx / SCR Delete Services for Skoda Octavia, Fabia, Yeti, Rapid and others. P20EE, P20E8 When I bought mine it had already been done.- Radio change incompatibility
00883 is I think is an ignition switch problem. it could be the switch behind the barrel that has failed. Read that there is part of the switch that senses when key is in ignition that is prone to failing. It could also be loose bad connection at switch. Check the fuses near battery for corrosion/loosness as well. AlasdairAlasdair1 started following Codes 00883 and 00668 Octavia 2007- Adblu reducdant sensor
Thanks for the tip but how do I go about doing that?- Final Drive Service?
I guess I'll let the experts work it out when I take it to them thanks for all the advice.- Hi all: Is anyone able to do a VAG Service history report for me please (Skoda Superb 3)?
PM'ed to you. Thanks. AG Falco- Adblu reducdant sensor
Code it out and worry no moreBinx1310 started following Adblu reducdant sensor- Rapid 1.2 TSI Broken valve / hose
- PCV valve/assembly
That's what should happen with a healthy system. (Apart from the lumpy idle).- 8755 Software Update - Skoda Fabia 2019 Carplay Issue
Hi @Tdawber I have a 2019 Skoda Fabia with MEN2_EU_SKGPx_P7381L / software 8740 and the CarPlay audio crackling issue. Could you please start a private conversation with me so I can provide my Gmail address for the 8755 files? Thank you.Wimmel101 started following 8755 Software Update - Skoda Fabia 2019 Carplay Issue- PCV valve/assembly
It might be the PCV, hard to say on modern engines.Aldfort started following PCV valve/assemblyWimmel101 joined the community- Elroq: Who else has ordered?
eneskisacik joined the community- What does this symbol mean
- Karoq Instrument Panel & Servicing Generally
E13. Thanks, according to last year's Skoda Dealer check list, the air filter was replaced at 6 years - but clearly the new garage must have thought it needed doing again. Maybe it gets dusty at the edge of the East End of London. The spark plugs have been renewed once, 3 years ago I recall and due again next year (when car will be 8yrs old). My garage man wonders if this will be necessary - in his experience - in view of my limited 7,000miles per year, with at least half being long distance, but he said it's up to me, so if you and others think they should be changed, I'll insist. R193. thanks - yes Maxidot, I remember now. Will have a go at changing via the scroll bar.JD52 started following SmartBox no longer recognised.- Final Drive Service?
I've checked the Skoda parts listing that I use/trust and, for a 2020MY Octavia, if the car is 5E - L - 000 001 > then VAQ fluid is specified as being G 060 175 A2 If the car is NX - L - 000 001 > then VAQ fluid is specified as being G 065 175 A2. I'm not a Skoda Octavia owner is the model designation doesn't mean much to me - but it will do to you.- SmartBox no longer recognised.
After some 18 months of use, my wireless Android Auto link has died. It wuld connect automatically to the my phone in my pocket. See attached vid for what happens now. https://bigjohnd.org.uk/Octavia1/Video/SmartBox.mp4 My phone connects to the SmartBox but the car doesn't connect to the Smartbox. The car will not read my phone when it is conected directly to the USB port either. Smatlink/Android Auto/CarPlay all seem fine on my OBDII I am suspecting the Amundsen or USB port itself. Any suggestions where to look next- Final Drive Service?
The two Haldex fluids that I have ended up with, are VW Group G 060 175 A2 and VW Group G 65 175 A2. I was buying fluid online for a 2019 SEAT Leon Cupra VAQ, SEAT listed G 60 175 A2 - but my seller sent out G 65 175 A2, now I think that he assumed that the "G 65" version superceeded the earlier "G 60" version as it turned out that VW quote the "G 65" version for similar aged VW Golf when it has a VAQ. In the end I got a refund and bought the "correct for that car" version. Checking on many sites I found nothing to confirm that, but, I discovered that the Febi offering does claim to meet with both these VW Group Haldex fluids - so how important that is I can't say, for my money, I'd prefer to buy the version that is listed for "that" model of car.- Photography Thread
Funnily enough, I wondered about using an extreme ND filter to see the eclipse, but luckily remembered it didn't have any UV protection, so it would still have been potentially dangerous. I was surprised to see a chap on the BBC website saying he damaged his eyes in the last eclipse, looking at the sun through a welder's mask. I would have thought this would have been sufficient, but I've since read they aren't usually filtered enough. Something to do with a rating of 12 or above being needed (I assume this is pretty dark?)- Final Drive Service?
Cheers, I'll give the Phirm a call then and that's 5 minutes from me pretty much. Not sure about the fluid you listed after I that 'm afraid.- Silencing the loud spoken traffic congestion warnings
I'd have thought this would be similar to sat nav directions or phone calls, in that the volume can be adjusted during announcement (or call) by using the volume dial on the steering wheel. After a year of ownership (used car purchase), i've not had any traffication announcements, maybe they were turned off by previous owner. - Adblu reducdant sensor
