Past hour
Octavia 3 Haynes workshop manual
Nice. Im keen I wonder how detailed it is. Keen to hear the feedback. I got a Haynes and a Gregory's in the past. Gregory's was way superior. Just better graphics and explanations. More detail.
Photography Thread
Servicing intervals?
I agree with 26DIPP. For the sake of a few pounds I will have the oil and oil filter changed at 9,000 miles to preserve the life of the engine and turbo, as I have done with all my cars that I tend to keep for 9 years or so. However I also have a look and smell the oil on the dipstick as well at about 6,000 miles to see how dark and smelly it is! As for filters, the air filter gets looked at every year and replaced before it gets really dirty, likewise the cabin filters. Basically I don’t trust manufacturers schedules any more. Also I don’t trust cheap chain car servicers who use inferior generic oil filters not fit for purpose. My local reliable independent has got used to me supplying him the desired oil, correct filters, sump washer for him to fit during the past 30 years He is happy as he says he wastes a lot of time arguing with Eurobits factors and FSG plc that they have sent him the incorrect poor quality part and service item on the van. Unlike others I believe the 0-20w Castrol Edge LL IV spec meeting Volkswagen requirements is better for these Turbocharged cars in UK. I will revise that opinion as Global warming takes hold and my turbocharger catches fire!
Kamikazedriver started following Servicing intervals?
Remap options for 2023 Mk4 vRS TDI
The bosch md1 [ tdi ] ecu's in vag cars from around 2020 are locked from the factory and it has taken until now for someone to crack them. ECU needs to be removed and sent away for unlocking, then a remap can be done in the normal way. There's only 2 places doing the unlocking at the moment but that's likely to change in the future. DC Remapping UKNew ECUs We Can Unlock | DC Remapping UKThe locked, encrypted ECUs (Bosch MG1 / MD1) we now bench-unlock in-house - across BMW, Porsche, VAG, Land Rover, Ford and more, with the models each covers.
henrypolack84 started following Skoda Octavia Mk3 (2013 - 2020)
Yes! Best post ever! Just ordered mine!
henrypolack84 joined the community
Heater Matrix Flush??
To be honest the biggest faff with heater matrix is draining the coolant and then if you flushed it, disconnecting pipes, might as well bite the bullet and replace, not sure flushing would be that effective (I replaced mine). Lots of blocked matrix threads going on!
- Heater not working
01skodaOCT joined the community
Today
AG_Precision joined the community
- Bixenon Headlights auto-adjustment problem
@AroCz - which channel r u reading the values from? I'm assuming this is on module 55 - Headlight, given urs is MY16 This is the Basic Settings values of mine (with DCC). However this with all 4 wheels hanging, for the DCC Recalibration procedure. I'll c if I can get the readings with the car sitting normally.
Kamikazedriver joined the community
3.6 fsi
Hello, I’ve noticed this “swooshing” sound on my 3.6 fsi after releasing gas pedal, I know this sound is expected on NA engine but not that noticeable. Haven’t done anything to the engine in few months so everything should be tight without any leaks, should I look for some loose vacuum connection of valve cover gasket leak, maybe pcv? thank you for any advise IMG_2178.mov
Can you change front shocks without removing hubs etc? 12 plate 1.6tdi
So much easier to remove the driveshaft out of the hub, even on the drivers side it's a struggle. Undo the 3 X nuts bottom of ball joint, drive shaft hub bolt, split the hub at the back at it should drop down. No need to remove tie rod end
Octavia 2l tdi cupa egr cooler bypass what is needed and how to do it ?
So, did this myself today. Likewise, dpf and egr are mapped out. Car has been using coolant since about 100k miles. Now on 180k and worse than ever after changing everything but the head gasket. This is the last chance before I get rid of it. Link below to the connector I used. You need under the car to get at the bottom coolant hose on the egr cooler and the top hose from the top of the engine. Once both are disconnected the connector piece is just about long enough to bring the two hoses together. You will probably make a mess even with hose clamps to try stop the flow. If you don’t have the vw hose clamp pliers for removing the hose clamps you might struggle https://vehicleclips.co.uk/products/20mm-car-heater-breather-hose-connector-straight-nylon-pa66
Incredibly stubborn hub bolt
Yep use a 3/4 breaker bar, its too much for a 1/2 especially when you need to re torque the new one (200nm + 180°)
- MK2 Octavia VRs wheel sizes
- Persistent P0441 error on Octavia vRS MK2 2011
Karel91 joined the community
octavia18l joined the community
A few questions regarding the Kodiaq – brake light, Start-Stop and Travel Assist
Thank you, let me know what you are gonna find out for number 1 🫣😉
Headlamp Help Please
MIB2 retrofit on an MY2015 L&K
Will send you PM
Yes please
I'm sorry I missed your message. Do you still need my help?
Reversing sensors gone haywire. How to check them.
Absolutely, an ideal idea for Christmas - I think that that was when I first bought my VCDS back in Christmas 2000 or 2001!
alinco2006 joined the community
PhilFlyer joined the community
Retrofit autodimming mirror
Hi, This one is pretty similar to what I used. https://www.ebay.co.uk/itm/135709654756?_skw=skoda+autodimming+mirror&itmmeta=01M7DMZXN61REXT0AH6R7YJYKB&hash=item1f98ecfee4:g:znYAAeSwKc9oAQnn&itmprp=enc%3AAQALAAAA0CHNgUiiE%2FjQhlDTaMiAde%2F%2BScYTeFLpcKeZnqF5dZO0ylDeF3GRHZdHMdn8SqTeEO8hd%2BpRQ2%2FH1t72tPfLx%2Fc0ducyTE70z2w2PmhTBauWmldtyuJIWog9BCRgw9SFeWoqJaW0y8TqVIj178qJZFCbKUKhtTCl7%2BCytucDeiL7lAoycn95mPDUQ04E8yrtRvxpId4AfLjUhtYEvLse7mNfqd7qUgLlZSCmfAo3UYcjMDewVgh9qtxG4rszDdixwwk5HfwmyOITsqKO895nr4U%3D%7Ctkp%3ABk9SR-Lb_7S7aA It does have the wiring connection included. The Fabia mirror / windscreen is a different design from the Superb. The FII uses a small foot / mount which is also integral to the windscreen whereas the SII and other cars use a larger bracket - 3AA845543B. The larger bracket fits around the small FII one and I hid it with the screen adhesive. You will get it from a dealer.
26DIPP started following Retrofit autodimming mirror
Radio code
Had to replace our radio head unit but it didn't come with the 4 digit pin code. Cost $50 Aus but got it done through this UK site https://www.onlineradiocodes.co.uk/ Just need the Serial code from the side of the head unit. Was surprised it worked but all good and working fine. Andy
AndyLake23 started following Radio code
3) Yes, Change dataset from unit A5
