Key
OP had lost a key - so no key available to swap out parts.
Coil pack(s) Fabia 1.2htp, possible failure?
Hello, I'd suggest pulling the plugs and check their condition and gap first. Use a proper coil pack extractor so as to not damage them when removing.
SAD : Failed to resolve "Error: workshop! Only leave vehicle in Position P "
I seem to recall that @skodud ended up rejecting the vehicle.
Why doesn't my non-digital speedometer show 30 mph
All speedometers in UK have a statutory requirement to overread - you will be perfectly OK to use the 50 KPH mark on the dial.
Wiring Cruise Control
Try Google Translate. I just ran some Polish instructions for a new lawnmower and it worked surprisingly well for me.
My 2023 MINI Cooper S Level 3 Electric leased from Motability which will be with me for 3 years & now a 2021 MG5 as a dog wagon.
BEV still not really there when compared to ICE - max. 4 fuel stops, totalling around 20 mins and only 1, or possibly 2 cards needed for entire trip.
Long list of fault codes detected
Resting voltage (after all vehicle modules have gone to sleep) should be minimum 12.2 to 12.5 volts unloaded, but you really need to test with a proper battery tester and with the battery at full charge - or with a multimeter while the engine is being cranked-over, where the terminal voltage should not drop lower than a minimum of 10 to 11 volts. You should note that normal battery State of Charge (SOC) will usually be only approx. 75% due to the way the smart alternator operates to allow recuperative battery charging.
Also strongly suggest that you get the battery tested.
When to replace battery?
With mostly short trips, the smart alternator control unit limiting battery SOC to around 75% max. can become an issue - you don't normally get sufficient energy recuperation to maintain a decent SOC. To prevent excessive hard sulphation and ensure a reasonable battery lifespan, an occasional recharge or longer run should be considered.
Engine dies when horn used
Post deleted as already answered.
- Stalling, and no codes...at a loss
Rear vents - no air flow
Assuming that you have had the Kamiq from new, this pipe was never fitted?
Should I put them "in the bin"?
What is the tread depth over 75% of tyre? Is the scrubbing on the inside edge? if depth getting close to 3mm, I'd say replace for confidence.
Does the horn sound normal (or at all) when operated?
multiple warnings lights
When you consider that micro processors control practically every single item in a modern vehicle, it's not surprising that spurious faults can get displayed when supply voltages start to drift.
Loose bolts on camshaft pulley cover, rattling engine
If engine is now thought to be not running as well as previously, it is very possible that the belt has 'jumped' a notch on the pulley - the lost bolt could well have fallen between the belt and pulley when it was displaced. It also sounds as if the tensioner has failed. These issues need to be checked immediately before any further damage occurs.
Scorched discs?
Possibly some binding on the front brake pads/calliper's? Have you checked front hubs for excess heat after a drive?
Tell me about your fabia 1.0 litre as my sister is interested in buying one.
OP was asking about 1.0 TSI.
@Ootohere - As from my profile, my TSI Octavia.
My Skoda Fabia 2010 VRS is getting sluggish in the hills.
I'm wondering if your terminology is correct - you say the vehicle 'becomes sluggish when going uphill because the DSG shifts down too quickly" - Do you really mean that the DSG does not shift-down quickly enough?
+1 for the 110, not as silky smooth as the 1.4 but a very willing engine. The 6-speed box on the manual version is a bonus.
Road bump thuds and brake noise
Had only one been left in? It beggars belief that this block has been in place for 4 years!
Amundsen MIB2 Firmware Update
@pab567 A question about wife's 2018 Fabia (MY17) it has what I assume is Bolero MIB2 (device 5Q0035842C, HW. H41; SW. 0468.) - is navigation from iPhone only displayed on MIB if connected via USB - or is it possible to connect wirelessly?
