  2. My 2023 Karoq Sportline is 3 years old tomorrow, Sept 15th, so the Skoda Warranty expires at midnight today. Having done my due diligence comparing the Extended Warranty offer from Skoda and having it serviced at the independent garage who have serviced our cars for the last 20 years with the Skoda 2 yr All-In-One Service plan, I opted for the All-In-One plan, as the warranty covers the expensive items like Matrix LED headlights, Infotainment screen, Virtual Dashboard,, Mechatronic unit and Clutch Packs. Anyone who is thinking of going with the All-In-One plan you can now arrange it up to 30 days before the vehicle becomes 3 years old, this has only just changed as it was previously only available AFTER the car was 3 years old. Skoda Warranty Offer is a separate insurance policy with a 3rd party provider the cover is slightly less inclusive, the All-In-One plan continues the original Skoda Warranty same cover as when the car was new. Costs: 2 yr All-in-One plan £959.76 or 24 monthly direct debit payments of £39.99. Covers 2 services Oil and Filter, Oil Filter, Pollen Filter and Spark Plugs), 2 MOts, 2 Years Roadside Assistance - 2 yrs Skoda Warranty included. The Skoda Warranty with the 3rd party Insurance company is £624, 2 MOTS is £108, so thats £732, very difficult to see how any independent could do the two services for £227.
  3. Hi folks! I was checking the values of the timing which are reachable by VCDS and found that my Camshaft adaptation intake bank 1: phase position is arround 1.05 and 1.10 which as I know is acceptabel. Also chacked the Camshaft adaptation intake bank 1: specified value which was 10.00deg and the actual value was changing around +-0.20deg. My question is if the vehicle is a NON VVT then why is it showing any values on these two signals? The car is a 2013 mk3 vRS TDI with CUPA engine. Thanks for the replis in advance!
  4. Quick update - took my car to an indy for MOT and some other bits ... they said one of the lambda sensors was shot so they replaced it.
  5. Bucket99 joined the community
  6. BlueDun replied to BlueDun's topic in Skoda Yeti
    Update:- all holding good and drying out slowly. It's surprising how much moisture the felt-type mats hold. Also, a big problem is the very dense foam moulding that fits from the end of the felt mat, under the pedals and part way up the bulkhead. Does anyone know where such a moulding can be purchased, as I think its going to be virtually impossible to dry it?
  7. Du weißt das du eine Ocu High 3 brauchst? Du bekommst eine Funktion Freischaltung nicht legal über odis. CP entfernen geht. Desweiteren arbeitet MIB3 und Ocu 3 mit Car Ethernet mit dem virtual Cockpit und dem Soundsystem wenn vorhanden. Beides muss Ethernet tauglich sein. You realize you need an OCU High 3? You cannot legally unlock the function via ODIS. Removing Component Protection is possible. Furthermore, the MIB3 and OCU 3 use Automotive Ethernet to communicate with the Virtual Cockpit and the sound system (if present). Both must be Ethernet-compatible.
  8. Yea I get this most days and it's been doing it for months on end now, Karoq 1.5 sel 20 model year.
  9. vulcan started following Constant app updates
  10. Wife's car 23,000 miles bought 2 years ago from main dealer failed MOT on Check Engine Light Showing. This is the saga 🇨🇬 Check Engine light shows 2 days prior to MOT date, duly fails 25Aug26.☹️ Connect ODB reader & it shows one DTC. (P0441 “Incorrect Purge Flow”) Check fuel tank cap & seal (All OK) Clear DTC Code returns within 1 mile whilst driving. Code P0441 detected Recheck fuel cap seal & start research in manual, forums & online. First port of call seems N80 solenoid valve. Code cleared, Code returns within 1 mile of driving. Cleaned pipes on inlet manifold & checked electrical connectors to N80 solenoid & GV 344 Pressure sensor. Small crack found on insulation of Pin1 wire on GX 344 sensor (manifold pressure), so checked conductor continuity – OK, but reinsulated wire with liquid tape. Used hot air gun to soften hard plastic pipes, removed & checked N80 Evap system solenoid valve – OK on & off the car – both solenoid & pipes are completely clean – no sign of debris/dust/charcoal. Code cleared, Code returns within 1 mile of driving. Conclude GX 344 sensor faulty – not available separately so: Bought new genuine VW/AG N80/GX344 plus pipe assembly (all in one with quick connectors) & fitted. (£117) Code cleared Test drive of 15-20 miles All OK😀 Check Engine light shows following morning 1 mile after restart.😡🤔 Connect ODB reader & it shows one DTC. (P0441 again) Remove rear wheel & wheelarch liner, investigate activated charcoal canister & blow through all pipes. Remove canister & weigh – 1.700 Kg Check for weight of new one which is 1.330 Kg Conclude canister is contaminated, so order new VW/AG one. (£167) 01Sep2026 LLL Parts take 5 days to dispatch an apparently "in-stock" item then DPD/Evri delays so part gets to me late Sep 11th (outside of my 10 working days free MOT retest)😠 Fit new canister (after checking weight!) Sat 12th & arrange retest for today 14th Sept (I've dealt with this garage for MOT's for over 35 years so they squeezed me in) PASS MOT The actual mechanical work is very straightforward, I could change sensors/pipes & canister in an hour now I know exactly what to do, but I have a nagging thought that only the canister needed replacing & my gx344 & N80 were fine - I know the N80 is certainly OK. It took hours of reading about these over complex modern petrol engines to find why & how to do the job, but the job was simple even at my advanced years (76☹️) Anyway, wifey is now happy so I suppose it was £384 well spent - cheaper than a new cooker anyway😇
  11. How did you fit your rear dash cam? If anyone can give pics or pointers for how to run the wire from front dash cam to the rear I'd be really grateful. Did you have to remove the headliner? Thank you!
  12. Today
  13. Hi all, I am looking into upgrading / retrofitting the infotainment system on my Skoda Superb Mk3 (3V) to a full MIB3 Columbus setup. Could someone please share the best OEM part numbers for the MIB3 Columbus main unit (glovebox unit / brain) that supports navigation and Virtual Cockpit mapping? Also, if there are specific hardware revisions (e.g., Harman unit indices) or common retrofit pitfalls with ODIS / Component Protection / OCF coding that I should be aware of, I'd appreciate your advice! Thanks in advance!
  14. Well a quick update on the vrs. Went into r-tech for a couple of weeks. And has had a k03 hybrid turbo, wagner intercooler, and k04 injectors. Plus some other supporting mods. And some general maintenance bits. Very happy with the results. As can be seen in the photo she now has 3 boost levels.
  15. I use it when I'm in the West Somerset area, you have some very nice drivers roads which go from nice, open straight to twisty and cambered, so I select the Sport setting on my Octavia RS, I know that I'm going to have to relearn my driving technique as the Elroq is RWD.
  16. cryp2oking joined the community
  17. I've had similar problems on the few occasions that I have tried the park assist. It does seem to work better when there are already parked cars for it to orientate itself against; empty car parks seem less successful. But that may just be my imagination. However ... at a local mini roundabout that I pass each day, the park assist always engages as I pull up to the roundabout and starts to look for parking spaces 🤨
  18. Skoda roadside assistant told me that the codes are cleared when he couldn't find any after being put into limp home mode. I called recovery when driving home slowly but as it was 10pm at night I asked for them to come the next day. When the guy turned up he could see there had been an issue but couldn't tell what it was as there were no fault codes showing.
  19. David - if you do retire this thread, I hope you start a new on to record your experiences. For me, I've thoroughly enjoyed reading what you and other have written. Despite the challeges this has all been a friendly and positive set of interactions.
  20. The car is a manual, would understand that if it was auto. Thanks
  21. It looks like the F11-79-008-01-HA rear spring (and E10-79-012-04-22 kit) isn't for a Superb MK3...but a Superb MK2 and other VAG cars that were based on the Golf MK5/MK6... The eibach de website has an online catalogue that should list suitable kits. https://www.eibach.de/en/iam
  22. I've just checked the battery voltage and with a cold battery it's sitting at 12.33 volts. When the car is running on idle it's 14.30 volts. Should I be concerned about the cold battery voltage?
  23. thesaltysquire joined the community
  24. I had it in a few cars, played around with it when I got the car first and didn't bother with it after that just left it on the default setting.
  25. Yeh, Chassis control. It was recommended to me
  26. Hello In need of some help please. I recently swapped out the RNS 315 nav unit in my Fabia II Combi and replaced it with a RCD 360 from China. With the maps on the 315 now getting a bit stale (VW stopped supplying updates about 4 years ago), the new unit instead offers a factory-fit-like option with Carplay and Android Auto. However, the new unit is coded, by default, to support a reversing camera. I have no plans to fit one, and it's an annoying error (no camera found) to have to clear from the 360's display the first time I try to reverse each trip. The AliExpress seller of the head unit has sent me a series of screenshots to help navigate through the VCDS steps needed to code out the reversing camera function (Warning, they are in Chinese, but they've marked everything up so hoping it's going to be more a case of following the boxes rather than having to translate stuff). However, I don't have VCDS myself. hoping someone who does in my broad radius (I'm in NW London, but happy to travel as needed to get this done) will be able to help me out. Happy to come to you and pay you for your time, though this should be a quick process, hopefully. Thanks Chris
  27. Can someone please shine some light on this ? Time came for the Eibach springs to get fitted last week only to find out that the rear springs don't fit at all. They are hitting rear droplinks without any weight put on them. Yes i know the springs are for estate and my car is saloon but they don't fit. Unless my mechanic doesn't know how to fit them I'm really lost. Pictures attached below
  28. Nice - I think you mean DCC on drivers pack, as ACC is standard
  29. I have recently ordered a 85 Sportline in velvet red (no extras) - expected Dec ish
  30. Right, right. Another lad replied on my YouTube channel about it, said my car is missing the missing the exhaust manifold heat shield / 'hot air collector': https://www.skoda-dily.cz/nahradni-dil/115050680-predehrivac-vzduchu-evropska-unie-1031.html . Huzzah! Another part to buy. 😑
  31. I have a 2025 Skoda Diesel L&K and notice no matter how many times I try and engage Parking Asist to find a suitable parking space it fails to recognise any even when I am driving slowly in a supermarket carpark after pressing the 'P' icon on the infotaintment screen and indicating. What more do I need to do?
