BradleyRushforth joined the community
Karoq Instrument Panel & Servicing Generally
Brake pad wear and therefore lifespan is very much a function of driving style and journey types. I personally find that garages always under estimate how long they will last; partially because they have to err on the side of safety - although this is open to looking like generating extra revenue. I usually change front pads at 72,000 miles, never had rear pads changed even after 162,000 miles in a previous car.
thamestrader started following Karoq Instrument Panel & Servicing Generally
rje99 joined the community
Slugish up slight incline
I was having random misfire without any warning on the cluster even vcds didn’t show anything, after replacing ignition lead (for the updated one with the heat shield around each ignition lead) and the spark plugs the misfire was still present after replacing the ignition coil the misfire went away, from the outside it wasn’t presenting anything wrong so if is still the original try to replace it
Jack25 started following Slugish up slight incline
Glowplug prices - having a laugh
I just noticed pim (link above) are also doing 10% off with code HEAT10. £86 is pretty good from a reputable supplier.
ECP prices for parts, I've found that at least for some parts, you should check the Halfords price, I don't have anything other than the free "motoring" membership, and many times I've found Halfords to be much cheaper than ECP - which is where Halfords use to supply their ordered car parts. Maybe not in this case though, but always worth checking before placing an order. Edit:- not many places tend to match or beat PIM for genuine OEM parts - plus very fast despatch/delivery.
Final Drive Service?
I've just remembered that the "safety data ref" on the labelling of both these products are different, so must be a significant "chemical makeup" between them.
vRS Owners, cars with a VAQ front diff, a question on the servicing and what you are being told at Skoda Main Dealerships?
It definitely isn’t every 2 years in NZ. I want to say 45,000km but don’t quote me. I have the prepaid servicing for 5 years. It’s included in that but not in the 3 year one from memory
Just replaced cylinder 4 with a £13 Bosch 0250403009 direct from Amazon. It was a Bosch 0250403007 that came out. Looks like Beru (another OEM) go for around £100 on ebay for the pressure sensing one. Bosch seem to be around £135. I find ECP expensive these days, even with an essential code/deal. https://www.ebay.co.uk/itm/336472172965 Bosch seem to be around £135, but I see a full mixed set for £140: https://www.ebay.co.uk/itm/286741811628 I soaked it in wd40 for a few days then got the engine to temp at removal. I might just have been lucky, but once it cracked, it was finger tight.
8755 Software Update - Skoda Fabia 2019 Carplay Issue
FYI: If you're updating a MEN2 unit and the firmware SD card is being rejected with an "SD/card reader error", try starting the update from the extended setup/service menu instead of using the normal "Update software" option under Setup. On my 2019 Skoda Fabia with MEN2_EU_SKGPx_P7381L / MU 8740 / HW 690, the SD card worked perfectly for playing MP3 files, but the normal software update menu kept reporting an SD/card reader error. The solution was to press and hold the SETUP button for about 5 seconds to enter the extended setup menu and start the firmware update from there. The exact same SD card and firmware files were then detected correctly, and the update to MEN2_EU_SKGPx_P0080L / MU 8755 completed successfully. The update also appears to have fixed my CarPlay audio crackling/distortion, which previously started after about 30–40 seconds of playback. Hopefully this saves someone else from repeatedly reformatting SD cards or assuming their card reader is faulty.
Silencing the loud spoken traffic congestion warnings
I believe traffication is subscription service, free for first year. If I recall correctly I think it cost £4.50 per year and you pay for it through the ŠKODA app. Look under PROFILE -> PAID SERVICES
- Codes 00883 and 00668 Octavia 2007
Jonnytange joined the community
Skoda Superb iV - Factory paint thickness specifications / tolerances?
- Adblu reducdant sensor
Search for adblue delete. Not sure where in the country you are but this was the first hit on google. Not a recommendation. Skoda AdBlue Delete | NOx Delete | SCR Delete | LeicesterSkoda Adblue Removal Specialist in Leicester. We offer custom Adblue / NOx / SCR Delete Services for Skoda Octavia, Fabia, Yeti, Rapid and others. P20EE, P20E8 When I bought mine it had already been done.- Radio change incompatibility
00883 is I think is an ignition switch problem. it could be the switch behind the barrel that has failed. Read that there is part of the switch that senses when key is in ignition that is prone to failing. It could also be loose bad connection at switch. Check the fuses near battery for corrosion/loosness as well. AlasdairAlasdair1 started following Codes 00883 and 00668 Octavia 2007- Adblu reducdant sensor
Thanks for the tip but how do I go about doing that?- Final Drive Service?
I guess I'll let the experts work it out when I take it to them thanks for all the advice.- Hi all: Is anyone able to do a VAG Service history report for me please (Skoda Superb 3)?
PM'ed to you. Thanks. AG Falco- Adblu reducdant sensor
Code it out and worry no moreBinx1310 started following Adblu reducdant sensor- Rapid 1.2 TSI Broken valve / hose
- PCV valve/assembly
That's what should happen with a healthy system. (Apart from the lumpy idle).- 8755 Software Update - Skoda Fabia 2019 Carplay Issue
Hi @Tdawber I have a 2019 Skoda Fabia with MEN2_EU_SKGPx_P7381L / software 8740 and the CarPlay audio crackling issue. Could you please start a private conversation with me so I can provide my Gmail address for the 8755 files? Thank you.Wimmel101 started following 8755 Software Update - Skoda Fabia 2019 Carplay Issue- PCV valve/assembly
It might be the PCV, hard to say on modern engines.Aldfort started following PCV valve/assemblyWimmel101 joined the community- Elroq: Who else has ordered?
eneskisacik joined the community- What does this symbol mean
- Karoq Instrument Panel & Servicing Generally
E13. Thanks, according to last year's Skoda Dealer check list, the air filter was replaced at 6 years - but clearly the new garage must have thought it needed doing again. Maybe it gets dusty at the edge of the East End of London. The spark plugs have been renewed once, 3 years ago I recall and due again next year (when car will be 8yrs old). My garage man wonders if this will be necessary - in his experience - in view of my limited 7,000miles per year, with at least half being long distance, but he said it's up to me, so if you and others think they should be changed, I'll insist. R193. thanks - yes Maxidot, I remember now. Will have a go at changing via the scroll bar. - Adblu reducdant sensor
