Past hour
Can anyone diagnose what might be causing this noise?
Fantastic! Thx so much for the steer. I'll get onto sorting this now.
P0078
Had a quick google and it came up with this on AI. Most Likely Causes on a Škoda vRS (EA888 TSI / TDI) Faulty or clogged VVT solenoid (camshaft adjuster magnet/spool valve). Oil sludge, carbon buildup, or internal coil failure prevents the solenoid from opening and closing properly. [1, 2, 3] Damaged wiring or loose connector. Broken wires, frayed insulation, or oil intrusion inside the electrical plug on the cylinder head disrupt the signal to the ECU. [1, 2] Low or dirty engine oil. VVT actuators rely entirely on clean, pressurized engine oil to function; low oil levels or overdue oil changes commonly trigger timing solenoid faults. [1, 2, 3] Vacuum/PCV leak (secondary contributor). On TSI vRS engines, a torn PCV diaphragm or split breather hose often causes severe idle bouncing (900–2000 RPM) alongside timing faults. [1, 2] Step-by-Step Troubleshooting Check your engine oil level and condition. Top up if low, and note if the oil is dark or overdue for a change. Inspect the solenoid connector. Locate the exhaust camshaft adjuster solenoid on the cylinder head (typically on the timing-chain side of the engine). Unplug it to check for oil contamination, corrosion, or bent pins. Test the solenoid resistance. Use a multimeter across the solenoid pins; a healthy VVT solenoid typically reads between 5 and 15 ohms (an open circuit or zero reading confirms a failed unit). Clean or replace the solenoid. If resistance is normal, removing and cleaning the valve with brake/carb cleaner can free up a sticky spool, though replacing the solenoid or magnet is usually straightforward and inexpensive. Check for air leaks. If replacing/cleaning the solenoid clears P0078 but the idle still jumps, inspect the PCV valve and intake hoses for vacuum leaks. [1, 2, 3, 4, 5, 6, 7, 8]
Amundsen MIB2 Firmware Update
the admin team has already asked that all posts are made in english. Consider this an instruction to follow the forum rules you agreed to when you joined and use english or your account may end up being restricted. there are several translation tools available on the internet, for free, including google translate which works very well even with car related technical language.
- Yeti 5L: byte 18 changed, need BCM light config (VCP) - halogen
langers2k started following Yeti 5L: byte 18 changed, need BCM light config (VCP) - halogen
I had a new battery fitted to my 21 plate Octavia in May by the Skoda dealer. In the space of a month the car had gone from complaining the 12V battery was low to completely dying on me. A neighbour got the car started with a jump pack, and then tried charging it and reconditioning it with his CTEK but I think the battery was too far gone. If the car was left for more than 2 days without a run the battery would be dead. I didn't ever think the original battery was in good condition. I didn't have any tools to check it. But Start/Stop would only ever activate after a long drive. I don't think the early life of the car helped the battery health. My Octavia was manufactured in July 2020, but not registered until May 2021. So it probably sat in a car park for 10 months. I purchased it in January 2022. But I did always wonder why Start/Stop rarely activated. Once the new battery was fitted that all changed. Start/Stop now activates all the time when stationary in traffic even after just a few minutes of driving. Overall getting nearly six years from the original battery was probably quite good.
Vertu unfair charges
This is the advice of the Motor Ombudsman The Motor OmbudsmanThe garage will not give me a courtesy car. Do they have...There is no legal or Code obligation on any accredited business to give you a courtesy car. Click here to find what to do if a garage will not give you courtesy car
Today
L&K Front Fog light Bulb access?
Yep. I'm going to give that a go. LED fogs waiting to go in 🤞
MVegvari started following Skoda Octavia Mk3 (2013 - 2020)
MVegvari joined the community
@Colin170CR - if u get a flat trim removal tool, u can insert it between the bumper and the foglight grille at the points shown in the pic below to pry it out. Back view.... Front view....
Hello, Could you please help me to get the latest firmware of this Octavia 2015 infotainment? Thx, Attila
ahurak started following Amundsen MIB2 Firmware Update
barn find felicia pickup.
Yeh, everyone I've spoken to agrees with you. I'll get that ordered today. I still have the front brakes to work on to keep me busy.
Sat Nav Lead
Thank you but I only use the satnav in this car very occasionally
Is DCC important?
This is a classic, which has been the staple in all "mother factory" assemblies ... it has advantages and disadvantages, but in general the pattern is the same. Whether is Alfa Romeo to FIAT, Moto Guzzi to Piaggio, Skoda to VW, the "poor cousin" always gets to suffer 🙄
Fabia Mk2 1.9 TDI Slow cranking and flashing Glow plug Light
Could be corrosion at terminals as said or its on its way out. I would clean and check condition feed and earth straps first. If that doesnt improve it I would replace starter. Got a febi one a few years back for my folks 1.9tdi and it was around £80 from parts in motion. Alasdair
Sat Nav Lead
Buy a hardwire kit. https://www.briskoda.net/forums/topic/448233-dashcam-switched-power/
Rbz5416 started following Sat Nav Lead
Sat Nav Lead
Any clever people on hear who had a neat solution to attach the Satnav lead to the dash, I’m using a sticky substance at the moment but would prefer a neater option like a small clip ?
The legal side might help when you go back. Your contract is with the dealer that sold you the car, not Skoda UK, so Skoda customer care saying it's down to Vertu is technically right. That's also where your rights sit. Under the Consumer Rights Act, when a dealer repairs a fault on goods they sold you, they have to do it within a reasonable time, without significant inconvenience to you, and at their cost (the Act says "any necessary costs", including labour and materials). It doesn't mention courtesy cars by name, so I wouldn't say for certain the £20 is unlawful. But you can reasonably argue that paying to be mobile while they fix their own fault is a cost of the repair, and being back a third time is the kind of inconvenience the Act is talking about. Put that in writing to the dealer principal rather than arguing at the desk. The bigger point is this. Under section 24, once a car has had one repair for a fault and still doesn't conform, you can ask for a price reduction or reject it (the final right to reject). As the squeak has come back after the first fix, you're already at that stage. On a car, rejecting at this stage can come with a deduction for the use you've had, but with a squeak you'd more likely go for a price reduction or a proper fix this time. The point is that it gives you leverage. As it's within 6 months of delivery, the fault is assumed to have been there from the start unless they can show otherwise. So I'd let them have the third go if you're happy to, but tell them in writing it's being repaired under the Consumer Rights Act, that you won't pay for the courtesy car, and that if it comes back again you'll be asking for a price reduction.
SparePartAlam started following Vertu unfair charges
Buy a new one... It'll cost you that in your labour time to fix it
A GOOGLE-search on car dealerships charge for courtesy car will reveal that this has become 'normal practice'. A couple of the many several-years-old discussions on the subject: https://www.pistonheads.com/gassing/topic.asp?h=0&f=23&t=1996303 https://www.reddit.com/r/CarTalkUK/comments/yda1yd/why_have_garages_suddenly_started_charging_for/ (Since 2009 I've used a local Skoda dealership for servicing my cars. I've never needed a courtesy car, so I can't say whether they used to provide this free-of-charge but now no longer do so, but I do know that a free valet and wash used to be offered and became a charge-option some years back.)
Debris or a leaf touching the heater fan. It is not a difficult task to remove (and clean its housing) the motor/fan from underneath the glove box. I am talking from a LHD perspective and do not know the RHD layout of the hvac system.
Agent327 started following Can anyone diagnose what might be causing this noise?
@Wlad69 Hi, sorry to bring up an old thread. I have the same problem on my Yeti 5L 2015 (halogen, front fogs, BCM 1K0937087AN): I changed byte 18 and lost the original light config. Could you tell me which byte 18 calculator you found, and which value worked on your Yeti? It would help me a lot. Thank you!
@langers2k @claudiu2s Hi both, I found your posts in “BCM module in YETI” (2021): https://www.briskoda.net/forums/topic/488992-bcm-module-in-yeti/ You mentioned having Yeti light configs and VCP. My Yeti 5L 2015 (halogen, front fogs, headlight washers, BCM 1K0937087AN PQ35 M) lost its original light config after I changed byte 18. Could you share a halogen Yeti light config (.bcm1), or prepare one I could have written with VCP here in Italy? Happy to pay for your time. Thanks a lot!
Thanks. Yes it's a pre-face lift 2016 model. Looks easy doesn't it. However, mine won't budge. The whole front bumper is flexing when I pull on the trim & both sides are not coming out. The cold weather is probably not helping (currently 1-2c on my driveway & raining hard) so I'm going to try & warm the trim up a bit with hair dryer / heat gun & use a thin plastic trim removal tool where those locating tabs are. I just don't want to break the tabs as the guy in this video did 😒
edop84 joined the community
Is DCC important?
+1 With the OEM setup, the only acceptable mode was Sport. With Bilstein B6 Damptronic + Eibach Pro springs, Normal became the new acceptable baseline, while Sport is now spot on." Since they share the same parts, I guess that decision comes from VW to keep the VW Group hierarchy.
nicolo92 started following Yeti 5L: byte 18 changed, need BCM light config (VCP) - halogen
Hi all, I have a Skoda Yeti 5L 1.2 TSI (2015 facelift) with halogen headlights, front fog lights and headlight washers. BCM is 1K0937087AN (BCM PQ35 M). In March 2025 I changed byte 18 in module 09 with OBDeleven (wrote 01, then FF, then set it back to 00). Since then the original light config has been overwritten: front parking lights don’t work (faults 02394 and 02395, bulbs are fine) with the light switch at 0, the front left parking light stays on rear fog light switch turns on the front right parking light instead of the rear fogs left reverse light turns off when I switch on the parking lights The Skoda dealer already wrote the factory coding online, with no result. I know byte 18 was 00 from factory, so there is no “correct” value to write. I’m looking for someone who can read the BCM light configuration with VCP from a Yeti with the same equipment (halogen + fogs, ideally same BCM part number or at least BCM PQ35 M) and share it, so my coder can write it back. Only the light config is needed, not the full BCM dump. Reading it doesn’t change anything on your car. PR code sticker attached. Any help or advice is much appreciated. Thanks! Nicolò (Italy)
nicolo92 joined the community
2016 Octavia vRS – AFS Error (Offside Light Not Sweeping) – Anyone near Guiseley (LS20) with VCDS?
Hi all, I’ve got the "Error: cornering light (AFS)" warning on my 2016 Mk3 Octavia vRS (pre-facelift Bi-Xenons) and wondered if anyone local with VCDS or OBDeleven could scan Module 55 for me—happy to send some cash your way. Symptoms: All bulbs work fine (dipped, main, and lower cornering fogs) and the beam aim is level (it passed its MOT like this with no advisories). On startup, the left headlight does its full sweep/dance, but the right (offside) stays completely still. I’m no expert, so I ran the symptoms past Gemini - it suggested the rear level sensor is likely fine since the left side still moves, pointing instead to a dead offside AFS module (1T0941329B), a wiring issue, or a jammed internal swivel motor. We’re selling the car in a few months, so I want to understand the exact fault code before deciding whether to fix it or leave it as-is. It might be a long shot, given I’ve seen very few Octy VRS’ in the area, but is anyone around the area of Guiseley / LS20, willing and able to plug in for 5 minutes to help me? Happy to drive to you of course.. Thanks!
