  2. Good news, I've solved the problem! Following an internet search and an AI list of suggestions, I cleaned the boot catch (which didn't look dirty but I cleaned it anyway) and the boot seal (which had some moisture and leaves). Then I turned on the engine and magic! - the flashing and chiming had stopped. I've driven a few miles today with no recurrence.
  3. Could you advise how you did it please? Some simple steps and what problems you hit please?
  4. Faulty microswitch in the boot lock or wiring to it.
  5. @Fortress53 Welcome. How many miles on the car and what age? What about the service history on the car like when did it get the Haldex Serviced?
  6. Hi @pab567 could you help me with this please ?
  7. Hi All My 2011 octy head unit just died Have a Columbus Been playing up a bit now dead. Been wanting an android up grade so now seems like the time What are these Facebook jobbies like? Android/GPS. Dab plus You see for about £300 Mate had a joying in another car and it was crap Recommendation please
  8. Welcome to the forum. Was this bought from a Skoda approved used dealer? Do you have a service history for it?
  9. Today
  10. After uploading the latest available map version to our SIII I was wondering if anyone with lots of computer knowledge had ever tried to simply copying speed camera data to the raw files and let the car upload them off the USB stick. I am sure that idea would be far too simple.
  11. Could be the wire from alternator. Its the smaller exciter wire. If it breaks (they are prone to) you get no light at preignition. If its broken then the alternator may not be charging properly and causing low battery causing random warning lights. On my old Octavia I had random warning lights some full brightness and others dim. It was the cluster connection that needed cleaned and reseated. Finally worked it out when DPF light came on and as it didnt have one realised it was electrical contact issue. Alasdair
  12. Welcome to the forum. The alternator indicator should light with ignition switched on - then immediately extinguish when the engine starts (alternator supplying power) If you have a multimeter, test the voltage at the battery terminals to check if the alternator is actually supplying power - should be significantly above 13 volts when engine running above idle speed. Lack of indicator light with ignition on, engine not running suggests the indicator itself may have failed.
  13. Oh, it sure is. Race Blue with Winter Pack and whatever the boot junk kit is called. I wouldn’t have mentioned it otherwise.
  14. I get you, but this is so otherly broken in that it's completely functional now and will be replaced by a slightly probably longer lasting one in a few days. it's POSSIBLY the most useless thing I've ever done since being born. At least TRYING to fix something and failing, then buying something is just accepting loss and moving on. Maybe I'll mount the old fixed gear shifter on the garage wall as a testament to my idocy, but tbh the truck on the drive does that fine....
  15. That's like trying to fix something but breaking it more then throwing it away and buying a new one anyway (which I have to admit is sometimes my modus operandi too).
  16. Hi folks, I’m having issues with various warning lights popping up uninvited on the wife’s Fabia, but one is staying annoyingly dim - the battery light. I’m assuming like most cars this comes on during ignition and the goes out on start up normally? Only its not coming on at all. Any guidance much appreciated. Thanks
  17. I've had the car in today for it - I am about to go and pick it up - its very loud on bad roads and happens pretty much every drive, its really bad. I videoed it several times for the dealer, I have just been told they have done nothing about it and to bring it back when its worse! I'm about to loose my rag! I also have the same one in the drivers door as well.
  18. Tqm joined the community
  19. lazou joined the community
  20. I have the OBD11 device without pro subscription. It retracts/"opens" no problem. To reset, pump brakes before "closing" If the parking brake is still flashing try "close" again. It was obvious from short buzzing sound second time around that the first "close" had not quite made it.
  21. Sigh, you're a genius, but I'm so next level I did BOTH
  22. ok, 100% of this post is useless. I gave the snapped bit a tickle to make it shiny Hot snotted it to DEATH on 150A That's an in progress shot, it got a full messy bead all the way around, i didn't bother V grooving it to get full depth because it only needs to last a weekend. Wasted some grease on things: But we're FULLY REBULT! HAHA. That went back under the car and I used the old roll pin to re-attach it to the gearbox, no point wasting the spare I have. I tried using a push back tool on the caliper but it didn't want to do very much so a flat bar in the face of it and a couple of C clamps shoved it in sufficiently. I've not done the left hand side yet, or bled all the brakes properly but look, it drove out of its grave! At the VERY least I can clean that bit of drive now! There was no point doing ANY of this, because new parts will be here next week, BUT I've learned a bunch of stuff, experienced a bunch of stuff, solved some problems and actually fixed the truck. If I couldn't get parts for any reason it's great to know I COULD sort out the ones I have. Honestly the gear shift feels NICE now.
  23. Could be. Estimated £4-£5k excl to sort it
  24. CJJE replied to ian-inhome's topic in Skoda Karoq
    I had one of those messages, along with the normal software update message (which I think is now solved, but that's another story!) I wasn't able to scan the QR code with my phone as I was driving, and then it went away. As you say, the only change in the app is the profile / smart home section which seems to be offering to link my car to my non-existent smart home app. No idea what this is about unless it is offering to warm the car up before you use it?
  25. peterfr joined the community
  26. I understand Thank you Maybe someone else once read few of comments have some experience
  27. According to Rosstech 00532 is either voltage too low or too high. Check battery first and also when running in case the alternator is puting out too much. If thats ok then it may be a bad earth/broken wire. Depending on what you used to reset airbag I heard that it should be VCDS etc as some other non VAG scanners cant reset them properly.
  28. Garmin GPS sat-nav devices can be connected to a USB port https://support.garmin.com/en-GB/?faq=zPmeeDJGFP8qMbgHObM1j7 but, for reliable operation and simultaneous charging, it's simpler to use a car's 12V 'cigarette lighter' socket-outlet.
  29. All depends if the job went straight forward or they came accross a problem like seized bolts etc. I would ask the garage if the job went as planned. How many hours did they charge you for the job. It may have included taking it to and from MOT centre/road test/alignment etc. Alasdair
  30. I have been told by a garage that a flap is broken, and that I will need a replacement intake manifold for my 2006 Octavia 4x4 FSI 1984 cc. I cannot find an after-market replacement, and even a used one costs near £500(!), which doesn't make economic sense... Is it possible to replace the flap, or should I live with less than perfect performance?
