  2. New Dacia Spring, sister product of the new Renault Twingo etech, will go on sale in Spring 2027 reportedly. Same small 27 KWh LFP battery and therefore 150 summer range and 120ish winter range so very much inter town or county rather than cross country. Price should be sub £15k. Bigger than the 45,65, 100 old model Spring and 80 hp. Apparently the 100 hp, sub 1 tonne Spring was as expensive as a Gilf GTI to insure ! 12 seconds to 60 in the new Spring. Torque presumably lowish line the power. Weight now over 1.2T but it does look much more sturdy.
  3. Alfordfabia joined the community
  4. Peter64 joined the community
  5. fabiarveen joined the community
  6. VladtheImpailer joined the community
  7. You have a dying ABS sensor at the back. Maybe two. Scanning with a decent tool will help identify which one.
  8. Battery is new 2 year ago. Abs Intermittent o/s/r wheel speed sensor range/performance Intermittent n/s/r wheel speed sensor, magnetic field low. Intermittent EPB control unit wheel speed sensor implausible. Engine Sporadic database error value received.
  9. I guess you meant 2% petrol?
  10. yes, its roughly 2% diesel. AI agrees with you - harmless. The main worry is lubrication of the pump but at 2% not an issue. No or a beneficial effect on DPF - apparently.
  11. Today
  12. Could be a voltage drop. Whats the condition of battery and also is alternator charging ok. On the other hand my octavia had random warning lights appear some bright and others dim. Cluster needed connector cleaned and reseated. Were there actual fault codes stored to match warnings? Alasdair
  13. @MarioVrs What Superpro arms did you use? I've ordered and received some TRC1070s and now finding conflicting stories about whether they're right for the car or not. Do you still have them on?
  14. Joseph96 joined the community
  15. Hmmmm - I found nothing definitive on it and thought these were fine. Have since seen your post but then Mario's seem to be fine... MarioVrs' post
  16. Glad its superficial damage and alls well. You were lucky. Could have been a lot worse. Alasdair
  17. Skoda parts list 3 interchangeable part numbers for the 5K0 part, with applications limited to Superb 2, Octavia 2 and Yeti. https://www.skoda-parts.com/spare-part/5k0907659-air-quality-sensor-european-union-38255.html Maybe just buy one of their non-genuine offering?
  18. Having said all that I have 2 trouble codes for the 5F unit, dab antenna both open circuit. Apparently that failing can cause distortion on all audio sources. I have discinected the fakra connector to see if that resolves it bit srill the same, also possible break in door harness can also cause it, so hoping it's one of those that is causing it. Quick look and found a new one but for 75 quid for a tiny little box.
  19. Compression test was good! 13bar in all 4 cylinders. Have put 4 new spark plugs on and just driven to the shops and back with no issues! So it looks like my bro was wrong and it doesn't need a new engine. Perhaps I was lucky and have got away with just a bit of surface damage. Cheers for the help
  20. StorminBen joined the community
  21. I believe that a supersession automatically implies compatibility, but I guess I could try to see which other vehicles use the newer part and see that their circuits don't mark up the signal line as 'LIN'. Remind me this evening!
  22. I know that you've said that 5K0907659 supersedes 1K0907659 but is it definitely compatible? i.e. Do we know that the 5K0907659 part is definitely not LIN bus based? On the catcar.info, if I look at the diagram for the 2013 Yeti, it only lists the 1K0907659 part. However if I look at the 2014 year and onwards it lists 1K0907659 with 5K0907659 in brackets. I'm just surprised that so many sellers on eBay have the wrong part advertised and this makes me suspect that they are only partly wrong and it works for some years but not others.
  23. If all the wheel bearings are smooth and no play (as said they can still make noise but feel ok) It might be the centre bearing in rear propshaft thats failing or propshaft coupling. Had one go on an old volvo 940 and made a droning sound varying with speed. Alasdair
  24. CrisArnold joined the community
  25. Hi! Thanks for the answer. I left the part inside the gearbox. Impossible to get it out. On the links you sent me, they are out of stock 😢
  26. It must be coming from somewhere. Check the join between engine and gearbox in case its the crank seal that gone and it getting blown backwards Alasdair
  27. You lost that white teflon look Worm gear (cochlear atermonas) ? A mechanic may ''grab'' it with a special tool otherwise it will be shattered in pieces inside the gear box. Briskoda.net search 002409191B 002409191E Cost about 9 euro or 7,7 GBP
  28. 146 diesel hatch. Walsall. Am currently looking to sell/break this if anyone is interested?
  29. Radiator Cover 6U0121283J ,differs from Radiator Support https://www.skoda-parts.com/spare-part/6u0121283j-radiator-cover-1-3mpi-china-3089.html https://www.naskodovku.cz/kryt-vodniho-chladice-vedeni-vzduchu-pro-skoda-felicia-facelift-6u0121283j--6u0-121-283-j/ @keywacat It's a very crucial part,it ''drives'' the incoming air on the radiator otherwise the incoming air will lost some amount inside the engine bay with no benefits.
  30. Your description points to a wheel bearing which is worn. They can start to make a droning noise linked to road speed before they are worn enough to feel play or roughness when testing by hand with the wheel off the ground. The drag from the transmission on a 4 x 4 will make it hard to spin the wheel and feel for roughness. Sometimes the noise is louder when cornering, due to side thrust and changing load, but I had a rear bearing go and it didn't show this behaviour so its not an infallible test. You might be able to find a good diagnostic workshop who can put the car on a rolling road with a vibration sensor attached to each suspension assembly in turn, to pinpoint which bearing has failed. Alternatively you could carry on using the car until the noise has got loud enough to identify the culprit, it will gradually get louder as it wears more. I no longer work on "heavy" stuff like suspension and wheels, as I don't have impact drivers or the space to swing a long breaker bar.
  31. I've tried listening to them, feeling them... Never been able to hear of feel anything, even on my front sensors which I know are all working correctly...
  32. All my dashboard warning lights come on intermittently especially when on a long journey. Went into garage who cleared faults but couldn’t identify what caused them. Just back from a long drive and they came back on. Any ideas on what might be the cause so I can advise the garage were to look first thanks.
  33. I've read many times that you can easily work out which one is faulty - by listening to them - that has never ever worked for me over a total of 6 VAG cars! VCDS does let you know which one has failed, as will a few other VAG compliant scan tools. So, has anyone successfully managed to find the faulty one by listening to them while they are operating? Second "detection" option is by feel, ie finger tip - again, doesn't work for me annoyingly!
  34. Excellent thanks 👍🏻 Been living without the rear sensors for a while, but finally getting around to doing something about it!
