  2. I often get the pop up message saying to update the software,this generally happens around 10 mins into the journey,but nothing seems to happen,I don’t get completed messages & the nav system is still in the original,I tried updating the nav with a usb stick, but it doesn’t seem to work, my car is a 20 plate Karoo 1.5 tsi sport line & has the Columbus mib3 system
  3. PhilH34 joined the community
  4. Not surprised really just reminded of the change in battery performance once we have colder overnight temperatures. It got down to 3C, ie 276K, so battery was on the cool side. Energy efficiency took a while to climb from much over 3 miles per KWh.Had electric cars for near 2,000 days now and not one of them regretted transitioning to EV from ICE. A cold snap means one needs to recalibrate and tweak ones behaviour in a few areas. But the continual flow of economic advantageous, added to this month by the removal of VAT on home supply and therefore when home charging is ICE'ing on the cake. Also seeing the harm that added CO2 is doing to the planet going EV please me that I have stopped adding to that disastrous situation we are sadly leaving our offspring. When I see the reduction in range I start thinking about how much better the new version of the Scenic is, particularly the new 67 KWh LFP version with 220 hp. I could charge to 100% regularly rather than only 80% with my current NMC battery as well as having about 30 miles more range with a full battery, much cheaper as it is LFP tech and 50 hp more are all Scenics will have the 220 hp motor. Press release attached and the improvement is staggering and for less money. Not going back to ICE for a main car ever as far as I can see as EVs just have too many advantages and aspects like the reduced winter range, even with heat pumps on all out cars, minor inconvenience and charging up for little money, free or being paid to charge up, cheap servicing etc and the cars getting cheaper and cheap is holding nearly all the cards. if I needed to do silly miles in a day I would probably hire a Polestar or European Car of the Year Mercedes CLA. Previous European Car of the Years, 2024 and 2025, got both of these but will not be taking on a CLA but impressed by its long range if not its price even though down to £39k now. Press_release_-_2026_Scenic_prices_-_01092026.pdf
  5. Today
  6. KevCoop joined the community
  7. Hi Alasdair, thanks for the insight! Would you say this is something to be concerned of, regarding further troubles down the line? Or once this is fixed should I be reassured do you reckon? Thanks !
  8. Reckon all the bolts on my old 1.9tdi are similar but its 19 year old. Thats not good at all. You dont expect it on a 6 year old car unless its been parked in the sea. I assume the same bolt is used on other parts of car as well so may take them some time to find and recall them all. Alasdair
  9. Thanks for the advice. To be fair the car is on 86k miles, doing about 15k miles per year for the last 3 years, so maybe the tires being shot makes more sense in hindsight. Cinch have finally given me the list of repairs and rectifications they made before selling the car. I’ll attach the list below. Do these fixes give cause for concern, or should I be happy that these have now been sorted before my ownership? I know the cooling system is a common fault from what Ive read. Thank you so much, I appreciate any insight you may have!
  10. CJJE replied to royread's topic in Skoda Karoq
    I get Kamiqs as a courtesy car each time my Karoq is serviced, and I definitely find the Kamiq is smaller and lower down. I need the Karoq for its boot size, and would not fit my holiday luggage in a Kamiq as easily as it goes in the Karoq. I can't really judge the performance and ride of the Kamiq as I only get the basic version, while my Karoq is the 2.0TSI 4x4 with DCC. Chris
  11. The accelerating hard then stumble and limp mode but cleared when stopped and restarted does sound like what warrior said sticking actuator or if its variable vein turbo they may be carbon up. My old 1.9tdi used to do exactly the same thing. Slight blow off noise then down on power. Pull into layby and stop then start and back to normal. Slightly sticky actuator in my case. Alasdair
  12. What mileage has this vehicle recorded? Your mention of it having had 'plenty of tyres' might possibly be of some concern. Check .gov website for recorded mileages at MOTs for past 5 years.
  13. It's Highway, I believe, as Jaguar thinks they are American these days but my point is they openly admit that WLTP figures aren't really applicable to their cars' real-world performance. A bit more honesty with these things is good imho
  14. Have a look at the wheel shop in Manchester (online). I found them very helpful when I bought a spare wheel and tools from them a couple of years ago.
  15. N 105 524 2 bolts holding steering wreck, M12x1,5x70, 10.9 class, passenger side, change both of them. https://www.skoda-parts.com/spare-part/n10552402-screw-m12x1-5x70-skoda-19278.html
  16. @mikeng Welcome. Maybe your Word Search just never showed something there is on this forum.
  17. 5 x 17” Ratiken alloys with 225/55 R 17 97H Continental TS850 tyres. No cuts or damage to tyres and no dings to alloys. Wheel 1: 6 mm tread Wheel 2: 6 mm tread Wheel 3: 6 mm tread Wheel 4: 8 mm tread Wheel 5: 7 mm tread Used on Karoq SE 2.0 TDi 4x4. These wheels have been stored indoors and in covers when not on the car, covers included. Collection only, located in Cobham, Surrey. Any questions please bung me a PM or post here. Price £295.
  18. Thanks a million for getting back to me, I have the maxidot and the amp at the parcel shelf. I bought a DX unit cheap enough locally but the actual plug that goes into the back is different to the one currently on the loom. If I get a chance when I get home I can send a photo.
  19. There seems to be a couple of other threads about this steering bolt issue, not surprisingly as a range of models are affected: I've just put my VIN (2018 Golf 7.5 GTI) into the main VW website as 17016R may affect me, and I just get red text saying it's not a recognised VIN: So I phoned my local VW main dealer, who checked and advised there was nothing outstanding at the moment, but if that changed I would be contacted. Not completely inspired with confidence. Gaz
  20. I ran the OBD11 again this morning. It shows the exhaust as a passive fault with no error code - photo attached. I emailed the results to myself before clearing the codes. Nothing on them for the exhaust, they mostly relate to the doors! Any ideas??
  21. I've just seen you can get MQB to PQ steering wheel decoder/emulator for a few quid on AliExpress. Might try something newer. I can imagine it's a faff though.
  22. No surprise there, even less range if using the heating etc, far worse than it us with an ICE vehicle which use wasted energy for heating. . Why are you surprised by it, you always come across as well seasoned EV owner and driver of many years standing.
  23. Welcome to the forum. Best say what car, what miles, what engine it has. So is it a petrol engine? Has it been serviced yet? EDIT, I see, 1.0 Fabia. So a TSI or is it a MPI? . Best have a different dealership deal with the issue. a very obvious Warranty issue, Spark Plugs, Turbo Accuator, Software issue or what ever. A Mod can move this to the Fabia Mk4 section.
  24. Tory Boy Andrew Bowie MP thinks that the next Elected Conservative & Unionist Government can impose New Nuclear plants on Scotland. About time if there is to be New Nuclear in Scotland that they get building it. Start at Dumfries House, Balmoral Estate, Castle of May and any other Royal Residences. KC3 can just give his permission & lets see what the Local Authority Planning make of that. In England Jacob Rees Mogg's Estate looks like an ideal location for a Small Nuclear Modular installation. Maybe a AI Data Centre as well.
  25. Wow first journey in one of the EVs in the cooler period. Mych less range and lower energy efficiency. Hine to look for a newer EV perhaps. Will be happier when daughter has her home charger installed which is due soon.
  26. Indeed, but the reason why I commented on it in the first place is that A) it is not a PSA on TV where they normally show warnings/advice such as this, B) it is extremely early for such warnings and was possibly so because of the real threat to global oil because of the Donalds' illegal war, and C) it appeared on a site that I just happened to be one of long standing local moderators on, and this is the very first time that such a warning has appeared, and hence why I thought that EVr's might like to know.
