  2. Please ignore. I'm a doofus. Had forgotten to peel sticker off new battery. Key works fine.
  3. VW group / Skoda refer to them as Semi Automatics just because that is what what DSG,s and S-Tronics are we them dry or wet clutch.
  4. Hi all, I tried to search the forum but couldn’t find anything that would help. Last month when I was about to leave for work, I noticed that rear licence plate lights were on (the car was locked). I unlocked the car and they turned brighter once the car was unlocked. I locked the car and they dimmed but remained on. I unlocked the car again and tried to open the boot, but nothing happened (it’s a manual tailgate), it was like it was still locked. I used the emergency release from the inside and it worked. After I arrived to work, I was able to open it, but the lights remained on. This went on for few more days and then it suddenly went back to normal - lights off when the car was locked and boot opened just fine, when unlocked. I should mention that this happened after driving in very heavy rain. Anyway, it was then ok till now. It started happening again and the last rain was on Wednesday. I managed to open the boot in the afternoon and I heard water splashing inside of the tailgate and then noticed water coming out from behind the plastic trim as I opened it fully. Google suggested to remove 3 rubber plugs at the bottom of the tailgate to let the water out, which I did. My guess is that water gets in somehow and messes with the cable harness causing the lights to remain on 24/7 and tailgate release not to work at all times. I checked everywhere and everything seems fine, so no idea where the water gets in. Has anyone else had similar issue? Thank you
  5. Hi, Self seal means that You do not have to reipair the tyre. Hoewvet, you still should remove the screw. I had such dituation and the screw was jyst simply removed. Then the tyre was pumped to higher pressure for few minutes an that was it. I have driven after that for 6 motnths and paid attention to pressure - there was no drop in the pressure at all. So it works. Regarding repairibg such tyre - yes it can be repaired. However, it is work and time consuming as they have to remove the sealant. As long as it is just small puncture - repair makes no sense as the self seal feature works ok.
  6. https://www.webuyanycar.com/?glbtrd_src_ind=wtxv-GDWlE-GZf8_oNVxXw%2F&utm_source=google&utm_medium=cpc&utm_campaign=Brand%20-%20London&utm_id=16880063734&utm_source_platform=Google%20Ads&utm_term=we%20buy%20any%20car&utm_content=Phrase&gclsrc=aw.ds&gad_source=1&gad_campaignid=16880063734&gbraid=0AAAAAD-VJQY5QLJFybJ9F7WumJmOZ80Bf&gclid=EAIaIQobChMIruakqNmZmAMVKpJQBh3BBh5SEAAYASAAEgKwS_D_BwE
  7. Hi All, New here so apologies if I have missed something or am posting in the wrong place. I have read the previous posts on this thread as I have a MK2 2015 Superb Estate with a saggy rear...... Ironically I am also moving to France next year so judging by the previous posts I should certainly sort this before moving! To get through the recent MOT my car had the following replaced: Nearside rear suspension arm (left) Offside rear suspension arm (right) Nearside front anti-roll bar drop link (left) Offside front anti-roll bar drop link (right) I have always had issues with the odd speed bump scrape, especially if a tyre or two has lost any pressure, but this summer holiday trip with luggage, dog and towbar mounted bike rack was too much for it. Rear was very low and towbar was regularly making contact with bumps etc. Since those parts being fitted the problem seems to have reduced, which surprised me a little as i assumed I most likely needed new coils, uprated coils, or auxillary coils? I'm keen to solve this problem as I am intending on keeping this car and running it into the ground, I also need to spend a small fortune getting the clutch and DMF replaced which is going to painfully expensive too! Any tips on: Which coils to fit/how i check compatibility. Can this be a DIY job (what tools req'd?), or is it garage only? Any help much appreciated! Ross
  8. Alternatively you can code start stop not to activate or install a control module that prevents it from activating too
  9. For recoding you can do this easily as a diy job using an app called carscanner and an obd dongle for about £30.
  10. Binx1310 started following Start Stop Stall
  11. Heron91 joined the community
  12. Buy from skoda-parts.com is the right way to go never had any problems with the parts or service contitech belts are the OEM prodùcer for Skoda and INA tensioner are OEM If you can freely spin the tensioner òr the idler pulley they need replacing as there should be slightly difficult to spin
  13. ian-inhome replied to ian-inhome's topic in Skoda Karoq
    Thank you for the reply mumpsim. That is all as clear as mud. I can't see many average owner making use of that feature
  14. Thank you Alasdair. Will call Kennys Monday for a quote. Graham.
  15. lui19 joined the community
  16. I have pretty much the same issue, from another post I have the impression changing the battery should solve it. I've bought a 2017 TSI around 18 months ago but no idea of battery age. I'm now slightly concerned your stop/start issue has returned with the battery reported in good condition. I'll keep looking for answers on the forum, so far I understood it was an issue caused by a failing battery (AI search also suggested this), your experience is making me wonder if there's anything else causing issues.
  17. Today
  18. Hello, I'm new to Briskoda and I'm having the same issue, stop/start doesn't operate at all until I have driven for quite some miles, operates normally then suddenly after stop/start driving the engine stalls when the system tries to restart the engine. The central info screen says restart manually but takes several attempts to get engine to run. Even attempting to rev it doesn't appear to help, it just brings up a comment on the info screen that I'm wasting fuel! From the sound of your postings, I need to replace the battery and have the system recoded. Thanks, your post and the replies are exactly what I have been searching for.
  19. I'll also add that the whisling noise doesn't change whether the tank is full or empty, same when the fuel tank cap is closed or open.
  20. I'd like to echo Pete's comment. Hope you're going to stay for the chat 👍
  21. Chalmers garage inverness havent used them for years but heard there still pretty good. You could also try ROM garage walker road just along from them for another quote. My old mechanic garage owner Robert brown when he retired put his customers there as he reckond they were good. Did my MOT a few weeks ago and very helpful old school garage. Another to try is Kennys autos on seafield road. They are vw/skoda specialists and have a good rep. Alasdair
  22. JFH joined the community
  23. KedarCZ joined the community
  24. What follows is the result of a AI Overview based on a GOOGLE image-search using the image in this topic's original enquiry. The Volkswagen T-Roc Forum and Skoda Kamiq Forum references come from these links https://www.trocforums.co.uk/threads/number-indicator-at-top-of-infotainment-screen.3387/?utm_source=google&utm_medium=organic https://www.kamiqforums.co.uk/viewtopic.php?t=149 (As my religion prohibits me from using a smartphone in a car, I've no idea if the above information is correct.)
  25. I'd love to know what that means. I have my doubts that they'll even have opened it. Who checked the chain timing and how? There are two aspects to investigate; crank to cam, and cam to cam. Cam to cam can be readily checked DIY from above, crank to cam is a bit trickier.
  26. Our Karoq 1.5l petrol 2018 60000 miles went for a service this week. The report said "Vacuum hose off inlet manifold has damage to connector and will not clip into place. Advise this is replaced". Car seemed to drive as per normal with this 'failed' part after service The part has now been replaced - separate visit - part details off the bag are "5Q0 612 041 BM Brake booster vacuum hose with a non-return (check and pressure sensor". So I am wondering how often this part fails and requires replacement? Perhaps this connection tab suffered from plastic ageing? Does this part require disconnection as part of a normal service which included the spark plugs so the plastic top engine cover has to come off, etc.? Photos below/attached: old part on the drive which shows is wiggly shape - yellow arrow indicating failed connector offside of engine bay with hose identified in red nearside of engine bay with hose identified in red. Yellow arrow indicates failed connector failed connector, shown with red line - the 'push' tab seems to have broken and is missing non failed connector with green showing the bit of the tab that has come off
  27. That's the bit i'm after - the 4 digit code for the key blade - if it's stored somewhere I must be able to request it right?
  28. Good luck Dave, hope you'll not disappear completely from here. 🙂
