  2. urban3k joined the community
  3. Yes brick like but only aimed at city travel really, standard battery is 15 kwh i gather, bigger battery option a massive 20 KWh. Should be good round town. 15 KW motor so top speed only 90 kph, not allowed on motorways, classed as quadricycle. Expected to be £10k or less.
  4. ^ Looks very elegant and aerodynamic. 😆
  5. fdani started following Ash load in DPF
  6. Hello, I would like to ask for your help. I have two different engine. DFGA and CXXB. 2.0 liter with adblue and 1.6 liter without adblue. The oil ash mass quantity is: DFGA - 60g CXXB - 11g The ash mass limit is 80g. Both cars have the same mileage and are used in the same way. Why is there such a big difference between the two numbers? Is 60g a lot? How effective is DPF cleaning? I'm not talking about regeneration. Thank you!
  7. I'd think that the only way to get anything from VW Group at some time in the future, will be to report this failure via the DVSA website - doing that might, just might, eventually get UK Gov to point a gun at VW Group over this issue!
  8. Today
  9. @Eric_DK Skoda MIB2 (MST2) unit. · Software train version: MST2_EU_SK_ZR_P0359T · Installed SW MU version: 0359 · Part number: 5Q0035820B · Software version: H28.28.133_STD2_EU · Hardware: H30 · Media Codec: 3141.0.0.1 Fabia 2017
  10. Your automotive controller is no longer synchronizing with the graphics controller, which indicates a timeout issue. Updating or reflashing the same firmware might help. Otherwise, buy a used unit and find someone who can perform a full backup of the automotive controller, transfer the data to the replacement unit, and adjust the mileage.
  11. You might want to tell which infotainment system is installed in your car. Perhaps you could also say which model year your Fabia is from?
  12. Dacia Hipster could be another success in the Dacia Renault marque...
  13. GevaarlijkeGek joined the community
  14. Thanks for listening, My octavia 2025 g-tec is not facelift version due to the headlights (I think facelift has SFD2) and I would like my digital cockpit to show the gas range. I tried change skins with vcds 25.3.1 but I couldn't find the vRS skin, I think i need unlock SFD due to VCDID code, see image attached. When going to 17 Instruments > Adaptation and typing "view" into the filter, I activated several views -such as 4, 7, 8, and 9- but I was only able to see a new skin by activating "view 8." I tried typing "Display depiction" into the filter, but whenever I attempt to activate any variant (Variant 1, Variant 2, etc.), it asks for a security code. Do you think this security code implies that I need to purchase an SFD token or is possible unlock security code writing a code in 17 Instruments > 16 Security Access ? Do you know how can I get the vRS skin in my CNG 2024 Octavia?
  15. danidani joined the community
  16. Hi all, Just wondering what the cambelt interval on a 1.6 Greenline III is. I’m seeing conflicting information online. I’ve just bought my old Octavia back and the belt was done before I originally bought it in 2020 at 90,000ish miles. The car has now done 140,000 miles so I’m guessing it’s overdue? It’s been owned by a family member so I know the car hasn’t had the belt done during their ownership. Looking to get it booked in if it is actually due, but just wanted to make sure it definitely is before I shell out. Also what’s the going rate for a cambelt & water pump change at an indie currently?
  17. Hello, I feel I am late to the party and haven't updated my firmware since 2017. I believe I am after MST2_EU_SK_ZR_P0480T - (currently on P0468T). Can someone help point me to where I might find it? Thank you.
  18. Does the SD card fit in the extra slot in the glovebox unit? I'm a bit of a Luddite when it comes to electonickery, give me an engine to work on any day! Thanks, that looks the very dab.
  19. Something like this means you can rip your CDs easily. https://amzn.eu/d/0iICC1YP
  20. Filtering search by VIN gives same part number for cover as I suggested so if that looks unlike what you remember I think that leaves two possibilities: An earlier cover type had been fitted by someone in the past, or Maybe that's not the car's original engine.
  21. thelee79 joined the community
  22. Is this just the anti-stall software not allowing you to trickle along at (too low) revs? What revs is it doing at 38mph in 5th?
  23. Lee01 replied to Lee01's topic in Motoring News
    https://www.skoda-storyboard.com/en/skoda-world/what-was-racing-like-half-a-century-ago-skoda-120-s-rallye-delights-a-champion/
  24. Top Cowling 1.2HTP Škoda 03E103929A ? Need VIN to check properly, but that's what comes up for 2012 CGPA engine. Maybe it had something non-original on it before, if that doesn't look like what you expect. I will message you to ask for VIN. Dirt on the outside of the engine doesn't matter, clean oil inside is much more important
  25. Yes, I know it's dirty as hell 😂 I have tried several places, plus shops, but we are struggling to find the right fit. None of the covers I have found has the oil cap where mine is placed. Ps: its scheduled for a proper clean once the parts are in place
  26. Thanks Dave, that's what I was afraid might be the answer. The problem I have is that my new DELL laptop doesn't have a CD/DVD player built in so unless I can find an inexpensive CD player to plug in, I am stuck with what I have.
  27. Looks like an engine cover's the least of your worries I assume you've tried eBay, Amazon and Skoda?
  28. Tomas525 joined the community
  29. A couple of years back i had my car in the shop, and upon the return my engine cover was gone. I am struggling to find a replacement, and was hoping some here could help me. It's a Skoda Fabia Monte Carlo, 1.2htp. I'll attach a photo. Hopefully someone here can help me get what I need.
  30. Miastubb started following Engine cover
  31. Let's hope that fixes it then. I assume it's being done free of charge under warranty?
  32. The latch on the tailgate springs back to the open position even when forced with a screwdriver. I have reversed right up to the garage door for overnight security. Skoda roadside assistance are due to fit a new latch on Monday. My elroq has only done 3100m since new in May.
  33. Has anyone managed to get a goodwill payment for this fault? My Leon 1.4TSI broke down a couple of weeks ago, fuel leak from the fuel rail, 1 bolt ‘missing’ and others loose. 3rd party warranty would not pay out because it was a bolt issue and bolts aren’t covered!
  34. Shamblerc started following Fuel Leak!
  35. Shamblerc joined the community
  36. Miastubb joined the community
  37. Found similar in cluch kits Bought an LUK kit and it had a valeo clutch disc. I would have thought that as INA are a premium bearing manufacturer they would use their own unless they also now make them for Gates and you got one branded for Gates . Reckon a lot of companies supply each other with parts and are rebranded to suit Alasdair
