Past hour
Regular False Tyre Pressure Faults
In the last month I have had 6 Tyre Pressure Faults arise (5 of which have been for the same tyre, Rear N/S). However every single one has been false as when I check the pressure it is fine and matches the opposite side tyre. I was leaning towards a faulty ABS sensor but my assumption is that I should also be seeing ABS/ESC faults also as it's my understanding the sensor controls this elements also. Octavia III Estate L&K 2015 Anybody have any ideas or guidance?
CaptainHaddock70 started following Regular False Tyre Pressure Faults
DCC Slider adjustment option mod
Sadly changing the Gateway is no trivial matter - sorry. It's at the centre of everything. Everything talks to it. I personally wouldn't change it just to get the DCC Mod.
- Octavia VRS 2.0 TSI 265 - Oil breather hose
Merc E-Class E450D, just sayin'...
Dang! I hadn't noticed that additional downgrade from the previous models' spec. I had the automatic headlamp wash on my Mk3 SE L model, so not having it on a new L&K is indeed astonishing. 😠 I always carry bottles of Autoglym Active Insect Remover (for the midgies) and Fast Glass spray in the car. I find them essential on longer trips in case the windscreen needs a quick clean-up beyond what the screen wash can handle. So now the glass cleaner will need to be pressed into additional duty during the winter. Sigh.
Winter roads, ice, snow and wet or dry driving in an EV..
Annoys me that sales of cars in Europe you can opt for All Season of Winter tyres to be fitted, extra 200 Euros or so, rather than only coming with Summer tyres which are compromised below 7c ! Please give the UK choice too.
Octavia Mk1 1U5 2004 - N/S/F wing required - ideally Diamond Silver Metallic (Code 9102)
Hello folks A kind soul stoved in my NSF wing whilst my car was parked in a side road 🤬 Anyway, I'm looking for a wing panel in good condition, ideally already painted Diamond Silver Metallic (9102), the OEM part number is 1U0821105B Anybody breaking a late Octavia? Mine's one of the last Mk 1s and has the facelift square-ish repeater hole. If not, any suggestions about where to get one would be appreciated (in case somebody knows a source not on-line etc.). TIA.
Battery light 1.0 mpi 59bhp
I'll look up later where the exciter wire originates. BCM I expect.
@Tqm What are the other warning indicator lights that are lighting up? What are the actual voltage readings you are seeing?
I can definitely confirm that a MY18 Mk3 Fabia does. I cannot recall any ICE vehicle that hasn't had a 'battery indicator' illuminate when the ignition was switched on if the charging system was functional.
Greetings from an RS220
Hi Everyone, Owning my RS220 for more than 5 years now and I'm loving it. Had some maintenances work to do already to keep him running but the support of the community and a good workshop is always great. Now I'm trying to fix some sw related issues that's why I ractivated my account here ;) BR, Lord_Diablo
Today
- Amundsen MIB1 Firmware update finally completed - MSTD_EU_SK_P6230 MU0490
StairBundy joined the community
Fabia 2024 SE comfort mpi fault
'Limp Mode' began to be introduced on cars in the 1990s, so it would necessary to go a long way back to find a vehicle without it. Besides my 2023-built Skoda Fabia that has automatic transmission and a turbocharged motor, I own a 2009 Skoda Roomster with manual transmission and a normally-aspirated motor. The standard specification of the Fabia includes a lot more 'kit' than the Roomster's, so, logically, the Fabia has a lot more to go wrong. My Fabia has a 'limp mode' feature, but so does the Roomster (as mentioned in this 2017 forum topic) https://www.briskoda.net/forums/topic/441876-limp-mode-on-roomster3/ The Honda Jazz has an enviable reputation for reliability, but that doesn't mean earlier versions are 'simple' or that problems with them are easily/cheaply diagnosed and cured, as this 2022 clubjazz.org forum topic proves. https://clubjazz.org/forum/index.php?topic=14521.0 Any doctor will tell you that obtaining from a patient sufficient background information to allow a reliable diagnosis to be achieved can be extremely difficult. In bazz2004's Fabia's case, the car was producing DTCs (Diagnostic Trouble Codes) and these needed to be cleared to allow the car to run properly. But, in Slinda's Fabia's case, the car has just suddenly lost power (Did any dashboard lights illuminate when that happened?) and, after the car was restarted, it recovered and no DTCs were subsequently found. In the 1980s one of my VW Golf GTi cars developed a starting problem in very cold weather. The vehicle was within its 1-year warranty period, so the VW dealership had it for a week, I was given a courtesy car, and parts were replaced. When I collected it, the workshop-manager said "It's still doing it, you know it's not right, I know it's not right and VW know it's not right, but it always starts within 30 seconds and VW says that's 'acceptable'" I didn't like it, but they had done their best. It seems to me that slinda's dealership is doing its best to help, but, as there are no symptoms to explain why the car had lost power and then self-corrected, it's not easy to see what more they will be able to do unless the fault worsens.
.....although I have, during this freezing weather where salt is being kicked up, discovered that there are no headlamp washer units on our car 🤔. A bit retro, and maybe a bit penny pinching? I'm back to 1990 and a small plastic bottle of diluted washer fluid in the boot, plus a microfibre. At least LEDs don't run hot. TBH, somewhat surprising and not something I thought necessary to check. The body of the front bumper looks too narrow for pop-up washers. Hardly uppermost in the list of life's issues but an odd omission. But in the interests of fairness, I think you would get this on an E-Class 😅. Have a nice day!
Can other mk3 owners confirm that battery light on with ignition is the expected behaviour please? I wouldn't necessarily assume that.
actually it is no charging mode, its much simple. it is switch for off button that works on/off after install. so you turn on or off start stop and it stays in that position when you like to change just press it again. https://www.ebay.co.uk/itm/405999540429
Cuoresacro joined the community
- 1.5TSI Axial bearing (2018 car)
Thank you both. Voltage at battery does vary in line with expected on a ‘smart’ alternator. I have changed the battery and all was good for a few days and then the christmas lights came back on! I have checked the exciter wire to the plug/socket on the front of the engine block and it is good to there from the alternator. I don’t know where the wire goes from there, whether it is straight back to the ecu or to somewhere else so I can’t check further back annoyingly.
Thanks for this. I don’t know what a “CP Master” is, but with the need to involve a Skoda partner, who’ll no doubt say of course we can do it, it sounds like an expensive and a potentially disaster-filled project, so I’ll swerve it….
- Ceratec diesel additive to Octavia mk3 2.0 tdi
Gateway Change, but it is CP Master, you need a Skoda Partner with odis online You will need to re-enable the functions; otherwise, certain features will not work. Do not forget the coding and the dataset.
Ahh. Yeah. Good point! 😳 The gateway is a 5Q0 so it’s a no-no then? Could the gateway be changed JR or would this create issues with other systems?
Expert help required
Yesterday my 69 kodiaq went into.limp mode but i managed to get it home , noticed smoke coming from the bonnet and upon lifting the bonnet I discovered this mess when I unclipped the heat cover .. day before I replaced the dpf pressure sensor with a new bosch one but the car was still coming up with the sensor error .. any ideas guys ? Thanks in advance
tommyboy68 started following Expert help required
Anyone had success requesting a key code to get spare key cut?
Since the introduction of the MQB platform with Immo 5A, there is no longer a "key code" in the traditional sense. When you order a replacement key, it is requested based on your VIN; it comes directly from the factory rather than a central warehouse. The key blade is manufactured by a supplier to match your specific lock—as recorded in the vehicle documentation—and the electronic component is programmed with your VIN. This allows the dealership to officially register (teach in) the key to your vehicle. Alternatively, you could purchase a key from a source like AliExpress and find a skilled CNC operator or locksmith capable of accurately cutting the blank (note that there are two different versions of the key blade). Furthermore, the CS (Component Security) code—which is essential for preparing the key and registering it to your vehicle—resides within the instrument cluster, which acts as the "Immo Master." The tools required for this process typically cost around €1,000.
Cairus started following Anyone had success requesting a key code to get spare key cut?
Yesterday
Melted Mess !
Hi guys been having trouble with my kodiaq 2.0 tdi 69 plate , then yesterday I managed to get home whilst in limp mode and discovered this damage to my newly fitted dpf pressure sensor .. Just kept flagging up a dpf sensor fault even when it was replaced.. do you have to code the sensor to the car at all ? Just ordered replacement parts from a scrapper of the same year kodiaq ... my car in the last couple of weeks seemed to be in constant regen mode .. any advice would be greatly appreciated..
tommyboy68 started following Melted Mess !
Red 2017 Skoda Superb Sportline TDI DSG hatchback
Message sent 👍
