New Superb wipers leaving a hazy/milky film after rain – anyone else?
In Romania, for the Superb Sedan\Liftback, you can choose the rear wiper for an extra cost, so it's not included by default.
Kamiq seat question.
Don’t think I’ve ever seen electric seat option on the Kamiq.
NorbertD joined the community
1.5 TSI MPG: Octane vs additives (>4,000 miles longitudinal road test)
I bought the additive https://www.mannol.de/products/additives/ester-additives/mannol-benzin-ester-additive and I add it as it says 0.1% to 95 gasoline, it's a very weak mixture, I wonder if it has any effect in such a small percentage. I was thinking of increasing it to at least 0.2%, shouldn't it be a problem?
Many thanks for your reply. I have ordered a pair of the compatible Bosch ones from Amazon. I’ll keep them in reserve and see how the OEM ones perform to start with. I don’t think my new model actually has a rear wiper at all, from what I can see of the spec, which is a shame, as it helps visibility in very wet motorway driving. On the plus side, it does tend to give the dog a bit of a jump scare if travelling in the boot on the old one, as it makes a racket when it first wipes the rear screen🫣.
mike33 started following Skoda Kodiaq MK1 (2017-2023)
Solved-> Overheating problem Skoda Superb (year 2018)
What's your oil temperature getting to at say 220-230km/h after 3-5 minutes of driving now that the shutters are removed? My numbers (Mk3 Octavia CUNA TDI 184bhp) are about 107degC - 109degC at 200km/h, about 115degC - 117degC at 215km/h in ca 20degC environment, and I got to 125deg C on one occasion driving at 230km/h before I started watching oil temperature... I try not to exceed 115degC, even though the engine can take more, the oil pump is belt driven ( and the belt is in the hot oil).
EPC warning light and limp mode
Well that was quick and painless, thankfully! 👍 It turned out that, when the Turbo Actuator arm was replaced a couple of years ago (before I got the car) the housing hadn't been put back quite right, so it was rubbing on the arm and it had caused enough friction to register as a fault. A couple of minutes with a screwdriver and pliers and it was moving freely again Whilst having my own OBD reader might have told me the problem, I wouldn't have known where to look, so that's £60 well spent.
mike33 joined the community
OBD2 reader
I've used a Carista reader for years, its been pretty good and definitely saved a few £££. I pay for the subscription version and would say I get good value out of it each year and will continue with it.
TasMan started following OBD2 reader
- Oil Change
MIB 3 SW update
Hello I have a Fabia 4 with MIB 3, OE 3V0.035.816.L, but with the old SW 0306. Carplay, or rather the phone, is often disconnected. A known thing on old SW. I would like to put the latest possible SW there. I would probably flash it via ODIS rather than via USB. Has anyone encountered a situation where the flash did not go through and the unit was gone? Is there then any possibility of restoring the unit, for example on the table? It's my car and the system is not exactly cheap. Thanks!
eMvoc started following MIB 3 SW update
Melco joined the community
- Solved-> Overheating problem Skoda Superb (year 2018)
Warrior193 started following Solved-> Overheating problem Skoda Superb (year 2018)
- Direct Firmware Download needed for Bolero in Octavia III
Is it possible and thinkable for you to contact me via dm or email <Removed> There are some units in PL for sell. Maybe we can discuss options and I have questions (read- I need help) with CP obviously. Email removed Only send this information via the PM (Private Messaging) function to trusted members. If the PM function is not yet available to you, tagging the member and asking them to start a conversation will work. Briskoda admin.
DGW started following Solved-> Overheating problem Skoda Superb (year 2018)
Pudnig joined the community
Callumholt joined the community
caroline73 started following Skoda Superb Mk2 (2008-2015)
Something is killing my battery - where should I look?
looks like a standard EFB rather an EFB+ EFB+ models generally provide higher amp-hour capacity and slightly stronger cold-cranking amps (CCA) than baseline EFB tiers from the same brand family.
- Yesterday
Door Umbrella
Thanks for the comments, sorry for the delay in replying but we have been away for a few days. We decided to take the Fabia as it doesn't get alot of use and longer runs - I really enjoyed driving the car which as you say is my wifes. Bit disappointed that it didn’t come with an umbrella given that it was quite expensive with all the extras. I should have checked when we first got the car but hey-ho!
Dpf help
Possibly a blockage in one of the smaller pipes. Sadly if a couple of longer runs don’t resolve it you may need someone who is an expert in DPF’s most garages and dealerships don’t really have a clue Take a look here, he is good https://youtube.com/@orileysautos?si=yawAXYQ-RRBloGeD Don;t get the idea a quick delete will resolve it. Most likely it won’t
Dpf help
I started digging deeper into the issue and noticed that the measured soot mass is increasing twice as fast as the calculated soot mass. That’s where the problem lies: either one of the sensors is malfunctioning, or they need calibration.
- help.. octavia
jimcwestie joined the community
cooling fan unit advice
BlueWagon Thanks for the response...... I thought so too. There's always that old adage...'If it's not broken, don't fix it'. I've ordered one controller for £32 odd on ebay....... I will fit it when it arrives and report back. Thx again, BlueWagon for your response. Regards Tom
Front Headrests
Thanks for your help both, all sorted.
Oil Change
What he said ^ I wouldn’t bother doing it every 5k - it’s not remotely a performance engine and with newer oils, you get a fair bit longer before degradation. I just use the standard C5 0W-20 in mine. I spent a fair while thinking about swapping to 0W-30, before realising it didn’t really matter and I wasn’t really bothered. As long as you’re using decent oil (Millers, Castrol, OE, whatever), you’ll be fine. Opie Oils has some good information.
OccyVRS started following Oil Change
token_454 started following Solved-> Overheating problem Skoda Superb (year 2018)
Hello everyone, I would like to give feedback to this topic: https://www.briskoda.net/forums/topic/534598-overheating-problem-skoda-superb-year-2018/ Brothers from the Skoda Superb Facebook group in Turkey solved my problem. The problem was the lower bumper grille shutters. They were stuck. I removed the shutters, and now the coolant temperature no longer rises above 90°C under normal driving conditions. It reaches a maximum of 100°C when I drive at 230 km/h with an outside temperature of 26°C. The oil temperature is still quite high, but I think this is either a different issue or simply normal for these cars. Best regards
Rory started following Oil Change
How to reset airbag error message
Thank you, but no. I'm in Portsmouth, Hampshire.
