RogueWagon started following SuperSkoda Shipping
SuperSkoda Shipping
Searched a lot of topics over the past week or so A fair few comments say that superskoda don’t ship to the UK anymore Is this true as there a few things I need to buy off there
1.5 TSi - engine mods - intake / exhaust etc
Legend
Merc E-Class E450D, just sayin'...
And the fishing tackle
Temp issues.
Temperature issue. Currently getting issues still with my 2018 skoda octavia vrs dsg 2.0 tsi. I have replaced thermostat water pump belt and temp sensors all with original dealer parts. My car doesnt have a dsg incline thermostat as symptoms all lead to that potentially being the cause but confirmed it hasnt. On idle start up the car temp after 5-10mins slowly climbs to 90. Upon turning blowers on they are hot but within minutes the gauge slowly drops. Once i drive mostly at higher speeds rather then round doors the gauge then goes nearly back down eventually to near on 0. Has anyone expierenced this. After a day or 2 the eml tends to come back on. Literally cannot think of anything else along with mechanic. I tried a aftermarket thermostat previously to a dealer part but no diffrence. Could it be electrical. Its as if a brand new thermostat doesnt want to work. Thanks in advance
Brydon90 started following Temp issues.
Brydon90 joined the community
Dq250 is used in the 190ps 2.0tdi with 400nm torque so I’m sure it will be fine!
Jack Point
If it needed a hole cut around the pad, I thought maybe cut the hole large then fix a piece of rubber sheet (Old inner tube or something) to the cover with a hole in the rubber that sits snugly around the pad. A bit of a faff but probably worth the effort as only needs doing once and will help keep the worst of elements out. If you can check the fit over the pad when you do your job that would be appreciated. And do you think the Powerflex pads are just as good as the OE VW items? At half the price, it's only the OE modified cover at the front that is making me pause!
I had a Mercedes E Class E350 Premium Plus Estate for 8 years before I changed to my current Superb estate. It was a very nice car, extremely comfortable, fast when you wanted or needed it to be and at around 40 mpg reasonably economic for a 3 litre car weighing about 2 tonnes. It was reliable and not unusually expensive to maintain. I had a Mercedes service contract for 3 years which proved good value, although customer service from my local Mercedes dealer wasn't great and after that I used a local independent garage. Being a much newer car, the Superb has a higher level of tech than my E Class - not entirely a good thing given the software niggles. The Superb is almost the same size as the E Class, but one thing that is worse in the Superb is the boot. Although it's much the same volume, there is a lip to lift luggage over, and the back seats aren't quite flat when folded down. The boot on the Mercedes was flat all the way in. Much easier for sliding the golf clubs in!
pgfife started following Merc E-Class E450D, just sayin'...
viflor joined the community
edrew97 joined the community
The only practical experience I have is with my Leon and a mate's A3. Both cars had the MQ250 box and 150ps, although mine was a 1.4 TSI and his a 2.0 TDI. Both cars were mapped, and his still runs to this day, albeit with a new clutch. Mine was sold before it became an issue, although I had no issues. His has more torque than a stock vRS, so it makes sense.
Lucky643 joined the community
Not building it to race around Just a little more pull would be nice 👌
- Activating SmartLink on Swing 3
Jack Point
The undertray design is different, IIRC. The two small covers on the Skoda are utter garbage. You need to undo a screw and slide it back and off. You'll figure it out. Getting it back on is a nightmare. I almost gave up - three slidey clip things, one screw, one locking tongue and a locating tongue. Only VW. Uhmmmmm... I think it'll be a tight fit with the covers on over the pad. I can try it for you in the next week or so if you do want to know, as I need to lift the car up. You can absolutely cut a hole in the cover, or just leave them off. I'd try and keep it covered during winter, but I don't think it'll die.
Apologies, I was thinking of the 1.0 Octavia with the MQ200. I don't often come into Superb land. The MQ250 will fare better, but again, just watch it. While the 'factory limit' for the box is 250nm, you should be able to put 300nm into the clutch without any immediate issues. Just drive it sensibly, and you'll be fine!
Trav's 2021 Superb 280 L&K
I can't say it looks any worse than the one that was on there before. At least the RL parts are interchangeable between EA888.3 and 4. Be a shame if something happened to them...
Škoda Octavia Mk2 headlamp upgrade
Hi Friends, Has any one upgraded there Octavia Mk2 headlamps to newer style projectors.
Gixon-T-Jose started following Škoda Octavia Mk2 head unit upgrade. and Škoda Octavia Mk2 headlamp upgrade
Jack Point
Thanks, My plan was to fit a set and leave them there. How do they fit at the front, do the removable covers fit back over the top or do you need to leave them off? If the covers foul the pads, maybe they can be modified by cutting out a circle around them, obviously leaving enough clearance for the jack. I've found this set of OE pads which come with modified front covers. More expensive .. mmmm... https://www.akstuning.co.uk/shop/home/976-12156-genuine-vag-jacking-point-replacemementupgrade-kit-mqb-platform.html#/1013-jacking_point_options-skoda_octavia_mk3 Not sure why the MK7 Golf version which is cheaper is not the same as that that shown for the Octavia III. The rear is different, wonder if it fits?
Gaz59 joined the community
Hi I need help to know which is the best Headunit upgrade for mk2 Octavia
Who needs a sports car?
A bit off topic but Proper car. No frills or tech plus bet it puts a smile on your face every time you drive it. There is one in Inverness and the guy driving it always looks happy. Daughters got a classic mini with the 1275 engine plus a mint Peugeot 205gti. Both are brilliant to drive and if you ever need cheering up I would reccomend it. Alasdair
Alasdair1 started following Who needs a sports car?
I normally run on 'individual' driving mode, which is basically a combination of comfort suspension and normal drive. That actually dealt surprisingly well with most of the journey and noticeably helped to smooth out the rougher surfaces in some areas. For the particularly twisty parts, I flipped to full sport mode - having the physical dial to switch mode is really useful sometimes. That was more for the improved pick up out of the corners than for the reduced body roll. I didn't bother with the paddles; the auto drive was fine. The other change from my usual set up was that I switched to speed limiter mode instead of my default ACC/Travel Assist. I always do that on bendy country roads where I know I will be continually blending between brake and accelerator. It makes sure I don't accidentally get caught out and breach speed limits, which is easy to do with all the power under your right boot. The only downside was that I had a little brake pad glazing after the 45 minute hard workout. The brakes squealed for a few stops after the end of the trip. But they were soon re-conditioned and back to normal with just standard stop-start driving; no need for any hard braking routines to burn off the glazing.
Škoda Octavia MK2 ABS upgrade
Hi, As anyone upgraded ABS model on Octavia MK2 1.8tSI
Gixon-T-Jose started following Škoda Octavia MK2 ABS upgrade
fmartine21 started following Usb port
Dead battery in Sardinia — EFB vs AGM replacement & DIY registration (Superb Mk3)
Provided the BCM is correctly adapted to the replacement battery type, there will be no problem replacing a EFB with AGM.
Gixon-T-Jose started following Need Steps to swap BCM on mk2 Octavia
Hi Friends, Can you help me in swapping the BCM on a Škoda Octavia MK2 to enable more functionality.
- EPC Light On During Drive Home From Purchase Of Car
- Locked out :-(
JackTurner joined the community
Matrix headlights with auto high beam
If the high beam is activated, pulling on the stalk (like you would pull on it to manually flash, not toggle) should deactivate it (so disabling manual toggle or automatic highbeam).
