JeroenvdBerg joined the community
Assistance services suddenly become unavailable during journey
@gareth71 Weather at the time was dry and about 17C. Like you I've had problems with assistive devices if it's icy. The heated windscreen clears everything but the camera aperture!
Skoda Service Plan - paying for spark plugs
I ended up having to write several strongly worded legal letters, but I did get the money back from the garage
the truth about electric cars
Trump is the best EV salesman..... New Trump Promisero car.... https://youtube.com/shorts/-cH9OQ560Hg?si=V6cSZt_wHT8C68G2
DAB knobbled by Dashcam
I'd think that ferrite beads on the supply wire could help - Skoda dealership should have known that this would be an issue as lots of people on VAG motoring forums have been reporting it for years.
OTA updates or the impossibility thereof
At the top of the infotainment screen slightly right of centre there should be a number in a circle, this is the amount of notifications of updates you have. Swipe down on the small bar at top centre of screen and press on notifications, any updates will be shown there and you can press to update and will update in the background or when the car is stopped. No need to stop and leave engine running.
Hi all, Fairly new to the website so apologies if this has been raised before. I’ve just had a front and rear dashcam fitted by the local Skoda dealer and the rear one knocks out the radio. If I unplug the rear and leave the front on all is fine. I’ve googled around a bit and it seems to be an interference thing with the DAB signal. Of course I’ll take it back to the dealer to sort it out but was wondering if anyone had seen this before and what the solution was ? Cheers
Hi, new to the site
Hi all, Just got my Kodiaq a few weeks back after my Superb I’d had for 13 years was written off by a bus. 😡 Look forward to find out out more from the site, looks interesting 👍🏻
Marshall Skoda MK - any experiences?
Hi - interested in any positive/negative experiences particularly around servicing as I am looking at a possible used Skoda to buy which has some prepaid service plan to transfer and I would have a few options on where to take it. Thanks
longbloke started following Citygate Watford - recent experiences? , Marshall Skoda MK - any experiences? , Marshall Skoda Letchworth - experiences? and 1 other
Citygate St Albans - any experiences?
Skoda Superb Alloy Wheels 18 inch from 2013 Superb Elegance Mk2. Set of four. Plus steel spare.
Hi, splendid I was going to send a private message but being new to the site it won’t let me. So not sure how to make arrangements.
2.0 TDI 115HP dry or wet dsg?
Hello, I want to buy a Skoda Octavia MK4 estate with 2.0TDI 150HP but I can't find any in my country with specific options. I saw one with 2.0TDI 115HP with almost every option, and maybe with a soft i can get to 150hp. From what I read, DQ200 can sustain up to 250NM and the 2.0TDI 115HP have already 300NM stock. I want to know if the 2021 Octavia MK4 with 2.0 TDI 115HP comes with DQ200 or DQ381? Thank you.
vp1x started following 2.0 TDI 115HP dry or wet dsg?
- Amundsen MIB1 Firmware update finally completed - MSTD_EU_SK_P6230 MU0490
vp1x joined the community
Advice on an Octavia I'm on the edge of going for
Thanks - good to know
Advice on new (to me) 25-plate Scala SE 116 TSI
If the car was registered at Northampton, KM-KY prefix, it was a Skoda UK staff car. Their HQ is at Milton Keynes.
peter3197 started following Advice on new (to me) 25-plate Scala SE 116 TSI
P25AB00 Piston Cooling Oil Control Circuit High - Superb
Honestly, I’m just completely baffled by this whole situation. How is it even possible that on a 2022 modern car, with all the advanced diagnostics, live parameters, detailed Freeze Frame data, and full ECU logs available, nobody—including the main dealer—can pinpoint the actual root cause of this error? We have clear, repeatable patterns (ignition ON, cold boot vs. warm engine, instant re-trigger with live Freeze Frames), yet the troubleshooting relies solely on throwing parts at the car and blindly waiting for factory support. It's frustrating to see that with all this technology and data at our fingertips, an electrical cold-start glitch can still completely stump the entire service network. ☠️
Thanks for the suggestion! However, it can't be related to the oil viscosity itself because the fault code P25AB00 triggers instantly on ignition ON alone (engine OFF) during a cold boot, before the engine even cranks or any oil pressure is built. Appreciate the idea, though!
2011 Superb VR6 Starts then dies, Fuel Issue??
a bit of an update, have now repaced the camshaft control valves, i dont think this was causing the issue but needed to be done some time. also new plugs, cleaned & reset the throttle body, there was no obvious crud in the body & butterfly operated smoothly. overall removed cleaned & connected all sensor plugs & fittings. Still have the same issue, car starts first time every time but immediately dies. Have been able to look at the engine controol module data in live mode, fuel pressure reads around 105 initially, then drops away to mid 90's when it dies. If I push accelerator pedal down on start up I see the pressure is around 120 then engine dies again. still have some misfires registering. Is there a fuel relay(s) or the like that I can test. Is there an easy way to test the coil packs
Side trim removal
I don't know how helpful it is to document the steps needed to remove the trim - I didn't find it easy to follow the manual. As a taster - the first step is to remove the horizontal bar at the side of the luggage compartment that has the hooks on it. The hooks can be snapped off (probably before removing the bar, just by manipulating to the right angle) The bar is held on by two bolts which are hidden behind a strip of plastic on the face of the bar. To remove that strip of plastic - it is clipped into the bar at each end but it also clips in about 1/3 the way down which can be accessed through small rectangular apertures at bottom and at top. There may be a special tool, a bit like a caliper, that presses in each of these holes at the same time but I managed to get it off by levering with screwdrivers in the holes.
Yes I put a lot into my focus, constant coolant issues engine replacement and various other things. So I researched for reliability. The 3rd gen Octavias came up highly. As did the Toyota corolla but octavia was more in budget. Highly recommend and test drive. Just aim for full service history every year / mileage interval. And budget in a timing and aux belt change if it's not been done recently. Then keep up it's servicing.
Is it something to do with oil being too higher viscosity? Piston cooling sounds like oil jets, so maybe try a thinner oil (specifically the cold viscosity) see if that helps the cold starting error problem
Dashboard warning lights
There are some pictures on the Octavia MK3 forum from when I changed my left rear abs sensor. It's an easy enough job just a bit fiddly to remove the sensor and electrical connector. In the thread I also show how to diagnose a faulty sensor using Car scanner or equivalent OBD dongle to monitor the individual wheel speed sensors...
RobOz joined the community
Replace rear parking sensor Octavia mk3 combi
Can anyone out there tell me if a rear parking sensor can be replaced on an Octavia mk3 combi(estate) without removing the bumper ? If the lower panel can be removed with the main part of bumper still in place how exactly is it released ? Hoping to hear from someone who's actually done this as failed parking sensors are fairly common. Thanks in advance for any assistance. Bazz
BazzY started following Replace rear parking sensor Octavia mk3 combi
Hi, I'm interested and able to collect
