Best Mid Range Tyres - MK4 Estate 1.5TSI
I appreciate that the question has been answered time and time again, but so many conflicting answers. Need to replace the factory-fitted tyres on my January 2021 Octavia Estate 1.5TSI SEL First Edition after a very respectable 51,000 miles. Do a combination of urban driving, but regularly do 500 mile round trips of motorway driving. Live in the South of England, so we don't really get much snow. Driving style is sensible rather than sporty. What do people recommend where the priorities, in order, are grip, fuel efficiency, longevity, and noise levels? Mid-range, known tyre brand preferable but open to suggestions. Thanks in advance
spcdust started following Best Mid Range Tyres - MK4 Estate 1.5TSI
How can i tell what fuel filter i need?
This one worked for me, same engine and year as yours, engine code CRLB: https://ebay.io/m/OO378P
272 Superb OPF stageIII
Hi everyone, Time for a quick update on my Superb after a bit of an absence... Mod-wise, not much has changed since my last posts. After going back to the OEM engine mounts and reinstalling the factory exhaust tips, I haven’t done any further tweaks. The car went right back to being the absolute perfect sleeper. Maintenance has remained top-notch: I’ve changed the oil every single year despite doing very low mileage, and replaced the spark plugs every two years. It has exclusively been run on premium fuel (98-100 octane), and I’ve always added a bottle of octane booster at every fill-up just to keep it around 102-103 octane in the tank and ensure the injectors stay in perfect health. It has been 100% bulletproof—never a single issue. The only minor thing worth mentioning is that the rear brakes have recently started making a sound similar to worn-out pads. However, both the discs and pads are actually in great condition; it's simply due to the car sitting parked up for most of the year. Despite the noise, they still work perfectly fine. I am pretty sure it can be easily sorted out by just taking the car out for a proper spirited drive for a few dozen kilometers and doing some heavy braking to clean them up. Unfortunately, precisely because I rarely get to drive it anymore, I have made the very difficult and bittersweet decision to put the Superb up for sale. To close this chapter, I want to leave a sort of "message in a bottle": I will be passing this thread's URL over to the next owner, and I warmly invite them to jump in, take over the thread, and keep updating you all on the future adventures of this amazing car. I’ll leave you with one last photo taken yesterday, with just over 24,000 total km on the clock. Thanks to everyone for following the journey!
Skoda Scala 1.0 TSI 2023 - Stiff Gear Change
If fluid was low and disenaging clutch and re engaging helps with gear changes it might be a leaking master/slave cylinder or the seals on either are going and allowing fluid to pass them when engaging clutch so clutch isnt engaging fully. Monitor fluid level and check at base of Gearbox/engine join for signs of fluid. The master on my octavia failed but the fluid ended up on undertray. It could also be the gear linkages need lubricated as you said and also might be worth resetting cables. As its had a fluid change and no improvement I assume theres no air in clutch system. Meant to ask did the clutch pedal come back up on its own or did it need lifted with toes. Alasdair
Alasdair1 started following Skoda Scala 1.0 TSI 2023 - Stiff Gear Change
Park Assist when stationary
Hi All, Something I find most frustrating is pulling up to any junction or stationery traffic the park assist screen insists on appearing and remains until I pull away. Annoying when you've got the nav running and somewhere new and need to see where you're going (I know you can see the high level in the dash but the wider view for me is preferred!). I've scoured all the options turning things on/off to see what changes but cannot find an appropriate option. Does anyone else have this and/or know how to resolve? Previous models/vehicles I'd only expect to see when engaging reverse. I've never used the optional parking assist (I didn't spec the car) but surely you can just hit the parking button to engage when required... Hoping someone can confirm this. Model is 2025 vrs Thanks
mork23 started following Park Assist when stationary
DGW started following DPF cracked?
- Yesterday
Fabrizio956 joined the community
Amundsen MIB2 Firmware Update
Carlinkit's adapters are very good. I am using it (mini ultra 3). It is almost as good as using it with cable. Most importanlty no delay while listening songs. Sometimes while playing songs it can glitch for 1 milisecond and after that it continues normally. Glitch happends rarely. If I was in your shoes I would first try with some better cable, like Samsung's original, if that doesn't help then I would continue with other methods. Good luck.
I had read that they were problematic but considering I'm only looking for android auto have gone for the latest Motorola one from Amazon. I like that it has a physical power button and fast switching between phones. Good suggestion.
Thanks @pab567 for such a quick response. Have a few follow up questions on procedure via pm thanks again.
DPF cracked?
My son has a 2013 Octavia 3 purchased from a dealer about 11 months ago. The dealer has proved deeply untrustworthy and has lied about many things. That’s another story. In spite of this the car has mostly performed ok. However, with MoT looming he’s mentioned again that the check engine light is on. Code is PO401, insufficient EGR flow. Car drives fine so I’m suspecting that the EGR filter in the LP circuit is blocked. This in turn likely means that the the DPF is cracked - a theory supported by the sooty tailpipe 🙁 We could clean or replace the filter pipe, which will probably keep the light off briefly (until it clogs again), but this is probably pointless as even if the MoT tester doesn’t spot the sooty tailpipe, the machine will spot excessive particulates? Anyone else travelled this way? I’m thinking aftermarket DPF replacement and a through washout of the filter pipe is the budget option. Looks like genuine parts exceed the value of the car even before fitting! Thanks Nick
VitesseEFI started following DPF cracked?
Wheel spacers?
I definitely type stuff filling in blanks in my head; then go back and re-read it and wonder how on earth I’ve let that go out the door.
Photography Thread
MargaretandRob joined the community
Incorrectly Identified NSL Speed Limits
I sometimes get this when on the A303 heading east coming to the Sparkford turnoff, it ' sees ' the 40MPH sign sometimes , especially if I'm in the overtaking lane ! I just carry on and reset the ACC and it recovers about a mile further on.
@red-ireland friend of mine had similar problem. Then he tried with higher quality cable and there was no more issues. Did you try using any carplay bluetooth adapter ? CarPlay requires a high-quality cable that supports both power and data transfer (at least USB 2.0 speeds of 480 Mbps). "Charge-only" cables will not work.
Suspension upgrade installed
Ride is great. No issues anymore with shocks and springs. B6 damptronics with Eibach pro kit. Racingline links and H&R bars front and rear. I have three sets of Lower front arms on the go at the minute. I’ve been trying different front bushes to stop them eventually making a slight noise when they dry out during the summer. I’ve tried pre fitted, I’ve worked my way through suoerpro, and powerflex. I’m starting with polish now. I have the blue fitted but it’s starting to emit the odd creak again. So I’ll pull them out and try going up to the orange. I’ve also tried all the others refitted with a range of grease from polybush specific to marine grease to no avail. Just the front now though. The front lower with the tts solid bush is quiet. Obviously for reference, it’s always rebuilt with new bolts and tightened on the ground along with setting the adjustable links again everytime. Otherwise the thing drives really well and still makes me chuckle evertime I use it. The rear bar and links were a great help as well to handling and cornering. Yellowstuff rear and blue stuff on the front with their floating discs. Needs tyres on the front, but I’ve PS5’s coming again hopefully next day or two.
- Moving over
iPhone 12, pixel 8a, oppo find x9 ultra. All of these phones came with USBC and the car is usba so not able to use original cable but most of my other cables are ugreen.
@red-ireland regarding your problem which phone do you have and are you using original cable for connecting to android auto/carplay?
Download link for MST2_EU_SK_ZR_P0480T sent in PM
I have a 2018 skoda octavia and Wondering if there is any update for my unit? @pab567 I have a problem where smartphone disconnect frequently from car play or android auto. Might just be a problem with usb port. Anyone have a doc or video on how to check for loose connection or replace the USB unit? I replaced the original battery less than 2 years ago and the latest one is not dead. I checked for parasitic draw but not found any. Wondering if mib intermittently causes the problem. Thanks Red
red-ireland started following Amundsen MIB2 Firmware Update
Sorry @UndertheRadar didn’t mean to exclude you from that question! Cheers for confirming. Think I need to review your project thread! Cheers @MarioVrs Eibach is a def! Alu subframes all round…?
- 01276 ABS Pump
Same thing happened to me intermittently and annoyingly on minor roads in North Yorkshire. I just pressed on regardless
vade04 started following Incorrectly Identified NSL Speed Limits
I fitted mine dry as well as per their instruction. Felt weird doing it, but no issues since.
rudolfo10 joined the community
- Owners manual
01276 ABS Pump
Yeah so it hummed for a few seconds but on my output tests using obdeleven, it hummed for a long time. I got the connector off, it was much easier than expected, no signs of corrosion. The cable was fine, I learnt that trick a bit late. I got a used pump from a breaker for 70e (including shipping). Got it changed at a garage, the job was very easy as you said, I could have done it on me own. Guy charged me 140 for the job including coding (not sure if that was even required, feel like he fleeced me there). All's well now, hopefully I don't see that error anymore!
