Past hour
Autodoc - avoid!!!
Do you work for them?
Autodoc - avoid!!!
I'd recommend using the Autodoc app to search for car parts it's actually quite convenient. It makes tracking your order easier and reduces the risk of mistakes.
Rear springs...replace?
Here I look at the lowered ride height front springs and the standard ride height front springs for the Superb MK2 1.6TDI. These front springs will be the same on both the hatchback and the estate versions of this car. It's the rear springs that usually vary depending on whether the car is a hatchback or estate, with the estate usually having slightly stiffer rear springs than the hatchback version...all other things being equal. Although 338mm-306mm=32mm, that's not the difference in the front unladen ride height because when you take into account the different wire diameter and number of coil turns the difference in the front unladen ride height is about 20mm. This could be useful if you decide to fit standard ride height front and rear springs. Kilen came up with the OEM part numbers and Sachs has supplied the specifications of each spring. Superb MK2 1.6TDI lowered ride height front springs 3C0411105P Length 306mm Wire diameter 13.00mm Number of coil turns 5.25 Superb MK2 1.6TDI standard ride height front springs 3C0411105B Length 338mm Wire diameter 12.75mm Number of coil turns 5.75
- Model help
Routemaster1461 started following Model help
ItsChrisW changed their profile photo
Today
Facelift taillight retrofit
Yes, that's correct. However, the original poster also wasn't able to activate the taillight animation.
The superb mk2 parts catalogue only lists two rear shock absorbers for the FWD lowered ride height cars. One is for the softer springs, and the the other is for the stiffer springs. Aftermarket rear shock absorber brands will often sell you the same rear shock absorbers for lowered ride height, standard ride height, and increased ride height, ie. a one size fits all approach. So at least you have rear shock absorbers that are specific to lowered ride height and FWD...assuming they haven't already been replaced with aftermarket shock absorbers. Bilstein B4 19-151083 rear shock absorbers are sold to replace ten different rear shock absorbers including both 3C0513049BD and 3C0513049BE lowered ride height rear shock absorbers, and a number of standard ride height rear shock absorbers. Lowered ride height is also known as sports suspension. Superb MK2 rear shock absorbers (1JC=Lowered ride height/Sports suspension) (1X0=Front Wheel Drive) 3C0513049BD Rear shock absorber for sports suspension 0YB, 0YC, 0YD,0YE 3C0513049BE Rear shock absorber for sports suspension 0YF,0YG, 0YH,0YJ, 0YK
Broraaen joined the community
I assume you've read that Installation of rear dynamic lights from FL on Skoda Octavia A8 (NX) Pro
milloo24 started following Facelift taillight retrofit
Установка Електропривіда багажника шкода Октавія а7 універсал ліфт 2017-2020
"Hello. I need a wiring diagram and a step-by-step guide for routing the wiring and connecting to the CAN bus for the installation of an electric tailgate actuator on a 2017–2020 Skoda Octavia A7." Вітаємо! Мовою спілкування на Briskoda за замовчуванням є англійська. Будь ласка, скористайтеся онлайн-перекладачем для публікації повідомлень. З повагою, адміністрація Briskoda. Hi, the default language of Briskoda is English. Please use an online translation tool to post. Regards, Briskoda admin.
Доброго дня потрібно схема як підключити та Покроковий процес прокладання проводки, та підключення до CAN-шини схема електропроводки Установка электропривода багажника на Skoda Octavia A-7. 2017-2020
Lotte joined the community
aleks0603 joined the community
Fabia Spare Wheel
It will not raise the Floor. It will fit in the spare tyre well. You may have to put something on top of it to support the floor.
- Apparent stalling
Yeti 2.0 litre tdi temperature problems
I can't give you the part number but we had this issue on our previous Yeti and I followed this 2018 thread. I bought both parts but the main one was wrong, despite trying to carefully match and even the garage said it's very easy to get the wrong one. I would have a look at LLL Parts schematics or Skoda-parts.com as a starting point.
Hi everyone! I’ve wanted to install the FL taillights for a long time. They fit perfectly in terms of mounting points and are plug-and-play (pin-to-pin). However, when locking and unlocking the car, I was getting turn signal errors, and the animation wasn’t working. I fixed the turn signal errors by changing the Leuchte 18 and 19 parameters. I replaced the pre-FL lamp type “LED Blinkleuchten mit Ueberspg absch” with the FL setting “LED Kleinleistung ohne Open Load Diagnose.” The turn signal errors are now gone, but the animation still doesn’t work. Does anyone know if the animation can be made to work? Is it coded separately? Does this LIN version support it? IMG_2779.mp4
RazorG started following Facelift taillight retrofit
Rear fog light(s) not receiving 12V
Meant to add if yours has a towbar fitted they sometimes were fitted with a microswitch in connector to disconnect rear fog light to stop back glare from trailer. If its failed it could be the cause. Alasdair
Alternator fuse
Seems one has to push the fuse cover down a bit, then they slide after a bit of fiddling. Thanks, answered my own question.
Hola, desde España
Hi, the default language of Briskoda is English. Please use an online translation tool (e.g. Google Translate) to post in English. Thanks you. Briskoda admin Hola, el idioma predeterminado de Briskoda es el inglés. Por favor, utiliza una herramienta de traducción en línea (por ejemplo, Google Translate) para publicar en inglés. Gracias. Administración de Briskoda
Alternator fuse
I think I have an alternator rectify leak as my battery has gone flat twice. How do I open the engine bay fuse box. There are lock slider, but I can't seem to move them forward, is there a knack to it? I can the isolate the alternator and check for a drain. Thanks
Try the cable connector itself not the contacts but if theres still no voltage its probably a broken wire as I think the fuse does front and rear unless its the actual switch for the rear thats failed? Not sure what route the cable takes from rear Alasdair
Software Update available for Bolero?
Hi @bluebill , I have exactly the same HW and SW versions. Please keep us posted if you successfully update to 0742 (engine On?). It would be great to know whether it also resolves Android Auto connectivity issues. Thanks!
- Now Sold: Skoda Superb V6 FL Hatchback 2013/63
@bluebill Lookie here...
Common issues and what to look for
DQ381 has issues till mid-2020, I believe. After that it doesn't. So for 2022/3 this isn't an issue anymore.
fr1nklyn started following Common issues and what to look for
Offered an OTA update today
I got a new update this morning too. Seemed to drop on without issue. Didn't get a chance to read what it was about, as I was moving and the screen gets auto-hidden, and by the time I'd stopped it was finished.
Octavia 2l tdi cupa egr cooler bypass what is needed and how to do it ?
Are you getting like a sloshing noise from the heater matrix behind the dash ? I've done the bleed on vcds and still getting the noise from behind dash , have you checked that because the original ones can leak . I've just ordered a sniff test to check if the pressure in the coolant tank is just air or still exhaust gas .
Hi all! 2019 Scala, Bolero MIB3, HW 033, SW Train MEN3_EU_SK370_P9305P, MU SW 0463. Could someone kindly PM me the files for 0469, 0741 and 0742? And has anyone done this on HW 033? Thanks a lot!
